Question about Samsung WF337AA Front Load Washer
How to replace a door gasket Samsung WF-J1254
The door gasket has a split and I need to repace it. Do you know where I can find instructions on how to repalce?
Thank you very much. gabriela
  • squeakey Feb 06, 2008
    how to renew the tub bearings on a b1245...
SOURCE: Samsung WF-J1254(V/S/C/R) leaks water around
I have finally found a reference in Samsung's own knowledgebase, online in which they indicate that this appliance was designed for European water pressure systems and that in the US and Canada, often water pressure can be much higher than in Europe (although the manual says it is good for 800kpa, which is a darn sight higher than they use in Europe, I think European domestic supply is regulated to 400kpa).
Whatever the case may be, I have noticed that my house has what appears to be rather high water pressure (subjectively of course). So, first I checked the leaking with it set to a cold only cycle, and low and behold, greatly diminished (since it was only drawing water from one line, hence a lower volume of water). Then I closed both supply taps about 2 thirds the way, and voila, problem is gone.
It makes way less noise now when filling, and I cannot really tell that the washtime has been extended excessively due to the longer fill times?
Would love some feedback if this fixes your problem?
Posted on Jun 09, 2008
SOURCE: Detergent drawer
I ended up having to call Samsung support for this same question. Left to right two vertical bars = detergent (liquid or Powder) flower = softner, single vertical bar = bleach.
Posted on Nov 11, 2008
  • 54 Answers
SOURCE: ma samsung wf j1254 is not stable, i leveled many times before
It could be. The front feet have to be manually adjusted but the rear feet are self leveling. If the wood is giving enough to allow the frame to touch ground then it could cause a leveling problem. The front feet are made of plastic on the newer machines if the plastic foot is stripped out, it could be allowing the machine to become un-level during operation.
Posted on Feb 23, 2009
  • 27 Answers
SOURCE: Samsung Front load washer WF-J1254 stops mid cycle
motor control board is bad and needs to be replaced, contact sears or someone like that to replace.
Posted on Jun 14, 2009
  • 93 Answers
SOURCE: i set washer to be on cold/cold but it comes hot??
CHECK YOUR HOSES- SEEMS LIKE THAY ARE ON THE WRONG TAPS
Posted on Jul 06, 2009
How do I remove flapper bar left French door Samsung RF266 fridge to replace gasket? Thank you
here is the manual on removing the doors. This will show you how to remove the door, then replace. http://downloadcenter.samsung.com/content/UM/200909/20090913021004593/DA68-01812H_RF266_RF263.pdf
Sep 20, 2016 | Samsung Refrigerators
SAMSUNG WF-J1254 washer very shaky when it's spinning, Help.
machine must be level there are 4 adjustable legs (1 in each corner) place a level on machine , level left to right and front to back.also check manual for initial set up there may be shipping screws that need to be removed on the back of the washer. good luck
Jun 11, 2012 | Samsung 3.7 Cu. Ft. Stackable Front-Load...
I set washer to be on cold/cold but it comes hot??
Jul 06, 2009 | Washing Machines
No water is going into my bowl after I fixed mt SE problem
This is a defective inlet water valve assembly. replace it asap.
Jun 24, 2009 | Samsung WF203ANW Front Load Washer
Ma samsung wf j1254 is not stable, i leveled many times before
Feb 22, 2009 | Washing Machines
Detergent drawer
Oct 19, 2008 | GE Energy Star WCVH6260F Front Load Washer
Refrigerator Door Gasket Has Split
I FIND IT VERY STRANGE THAT THE ENTIRE DOOR NEEDS TO BE REPLACED IN THE EVENT THAT THE RUBBER IS FAULTY.I NO FOR A FACT THAT SOME SAMSUNG FRIDGE RUBBERS ARE QUITE HARD TO REPLACE AND THE QUICKEST SOLUTION FOR THE TECH IS TO REPLACE THE ENTIRE DOOR.TO ESTABLISH IF THE RUBBER IS REPLACABLE I SUGGEST YOU LIFT THE GASKET IN ONE CORNER AND LOOK FOR A GROOVE OR SCREWS.SOME RUBBERS ARE BASED ON A PUSH IN PULL OUT BASIS.IF YOU FIND IT HARD TO ESTABLISH WHICH IT IS I THINK ITS BEST YOU ASK SAMSUNG TO SEND YOU A MORE ADVANCED TECH TO ASSIST YOU IN THAT REGARD.ALSO YOU CAN VISIT SAMSUNG WEBSITE AND FIND A TECH NEAR YOU.
GOODLUCK.
MOHAMED
Sep 19, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Samsung WF337AA Front Load Washer Logo
408 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
