Question about RCA 25414RE3 Corded Phone
I can hear the radio on the phone
I hear a faint radio station thru the handset of this phone. it doesn't appear to happen when using a headset, but i can't always use the headset. any suggestions?
    Problem Solver:
  • 10 Answers
I have two of the 2541YRE3 units (where Y is a 3 or 4) and both pick up the local 1620AM radio station. Good to know it's only in the handset. I tried swapping the handset and cord with that from the 2540YRE3 model (which does not suffer this problem).
But, I have no solution. I am getting them replaced by finding 40Y models where I can.
Posted on Jan 31, 2008
No and we have two phones and neither of them can hear the incoming call yet they can hear us. Nothing happened to the phones they were working and then they did not.
Not likely defective, just need to be reset. If I understand correctly, no ring with an incoming phone call, but the intercom feature works fine. The ringer on the handsets is either "off" it will say no ringer or the base station is not communicating correctly. Intercom is handset to handset. Phone calls pass through the base station first. Of course, check the base unit: power on, phone line plugged in, antenna attached. Then try the phone line to check for dial tone with a regular, "old" analog telephone. If you are using these with a PBX, you must have an analog line installed.
Jul 05, 2014 | EnGenius DuraFon 1X-HC Long Range...
Handset on panasonic cordless only works with headset
It appears there is something internally wrong with your handset. We recommend you use the below link to setup service.
Apr 28, 2014 | Panasonic KX-TG5422M Cordless Phone
I can hear callers through my s11 plantronics headset but after using and trying all configuration no.'s they can't hear me at all
Make sure the Plantronics S11 headset is plugged into your handset jack on your phone, not the headset jack, this will make a difference on most phones. After plugging the S11 into the handset jack on your phone, you will need to pick up your handset receiver and sit it off to the side of the phone to place a call or to receive a call, after you are finished with your call sit the handset receiver back in the cradle on your phone.
Good luck from Headsets Direct!
Nov 07, 2011 | Plantronics S11 Headset
I can hear, but not talk, on my ATS RA2184BB cordless phone.
Have you tried unplugging your base station and all the handsets?
Sometimes the base station, where the power and the telephone line plugs into needs a reset. Just like a computer sometimes it needs a reboot.
If problem presists, take a regular analog phone and plug it in to the same jack as the cordless phone bas station, and see if it is a cable issue/ telephone company issue.
Mar 19, 2009 | Lands Phones
Vtech cordless phone appears to be mute
Try the "hard reboot". /1/ Unplug power from base station. /2/ Disconnect battery in each handset. /3/ Wait a few minutes. /4/ Reconnect battery. /5/ Re-plug-in power to base station. /6/ Place handset in base station, and wait a few minutes for it to recover.
You may have to reset time/date and/or the handset ##.
Aug 24, 2008 | Vtech 9009111 Cordless Phone
Cross talk
The easy way is to buy a radio surpressor. You can find them at Radio Shack, I think. Unless you live very close to a radio station you probably have a ground on your phone line. this can happen either inside or outside you business. Also if you are using a long mounting cord, 25' and up this can act as an antenna and cause radio pick up. I would try to detremine if your problem is on the phone company lines or inside your business.
the question said cross talk, are you hearing the other lines while you are on one line? If so you may have inproper wiring inside your building. Multiple phone lines must be on twisted wire. If two lines are parrell for any measurable distance they will bleed over to the other line.
Jan 29, 2008 | RCA 25414RE3 Corded Phone
Lands Phones Logo
88 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
