Question about Technics SA-AX530 Receiver
Conrad johnson converter connection
My D/A 1 works great with the CD player, but I tried to run an optical cable from my new Samsung HDTV to the converter, but get only static.
The LED shows that I have digital input to the Aux port.
It isn't so much static as it is dot-dash sound.
  • 2 more comments
  • Roger Johnson Dec 31, 2007
    Howdy:
    This is a new cable from Radio Shack, the connections seem tight on both ends.
    I do have the LED on the converter lit that shows it is getting a signal.
    I can see light from the cable when it one end is disconnected.
    Did I mention that this is an optical cable and ports?
    I am not sure that your solution is appropriate for this mode.
    This may be the start of the solution:
    Only in the reverse,
    the connection works when I am NOT receiving a digital signal, does not work when I switch to a HDTV signal.
    I am using an indoor antenna.
  • Roger Johnson Jan 01, 2008
    The television is a Samsung T3242H,
    the D/A converter is a Conrad Johnson DA1.
    The source is over the air broadcasting.
    Sound comes through the stereo when I have a non-hdtv signal tuned;
    it is when a hdtv signal is tuned that this hard dot and dash sound comes through.
    Here is something that I just realized:
    the hdtv stations are sending Dolby sound, the non-hdtv send the analog non-Dolby.
    Is this relevant?
    Is there a way of telling the tv to either turn on or off the Dolby translation?
    I uses the optical cable for tv, a coaxial for cd to converter.
    Those are all the facts that I can come up with--and hope that you have some flash of insight.
    President:
  • 1,950 Answers
Did you make sure that your TV is outputting audio via the optical port (optical out enabled)? Also, if your TV is not receiving a digital input source, it won't output a digital signal via the optical cable.
Posted on Dec 31, 2007
  • 1 more comment
  • Damen Wong
    Damen Wong Dec 31, 2007
    Could you please tell me what your the exact model number of you Samsung TV? What input source are you using when the optical output works?
  • Damen Wong
    Damen Wong Jan 01, 2008
    Did you try turning off the TruSurround XT?
  • Damen Wong
    What you suggested about the Dolby 5.1 could be the source of the problem. I don't see any way to turn off Dolby 5.1 from the TV. The TV is programmed to output 5.1 if it's receiving 5.1. You convertor probably doesn't know what to do with the 5.1 signal. The convertor is too old perhaps?
    Sergeant:
    Champion:
  • 347 Answers
Hi sherring, have you cheked that your cable isnt damaged? the connecton at either end might be loose.
  • Santiago Vallejo
    Santiago Vallejo Dec 31, 2007
    If you hear static sound and our cable is ok. Then you have to open it up, locate the potentiometer and spray some electrical contact cleaner. You can get that in an electric supply store. Try to clean any visible dirt,
    If the problem continues then you have to repace the pot.
    If your not sure of opening it up and spraying the potentiometer, i suggest you to take it to a electric store, this problem is not that easy to solve sorry..
  • Santiago Vallejo
    ehm, well im running out of ideas then. I dont understand what your specif problem is.
    You mean you hear static sound insted of the sound?
    If you turn the mute on, will the static sound stop?
How do I connect my Sony smart tv to my old onky o amp
Your TV probably has an optical audio output. Go to Amazon and get an Optical to RCA converter, like an FiiO D3.
Works great and bridges your new TV to your old audio technology (which is just fine).
Feb 12, 2018 | Sony Audio Players & Recorders
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
How should you connect your CD player to your av amp (both Technics) using an fibre optical cable?
It sounds like your CD player does not have an optical audio output. If so, you will need to get a "Digital to Analog Audio Converter". You can find them on eBay or Amazon for as little as $10. Connect your CD player's analog/RCA-style stereo cables to the converter.Then connect the converter to your receiver with a single optical cable. 6_20_2016_11_27_39_am.png
Jul 01, 2015 | Audio Players & Recorders
Can't plug optical cable on MDS-JE500
optical will work any way you connect................connect mini out( play mode) to cd-r rec (in) recording or cd player (out) to mini (swithch to record, optical/line in/mic) the optical cable you have should work if all connection are fitted well. i record cd to mini using optical and vice versa all the time. just make sure you are connected correctly to what you wanna do
Mar 01, 2009 | Sony MDS-JE520 Mini Disc Player
Cant get the wiring figured out.........
I have a similar set up. For yours, I would run one optical from your Sat box to your 407 and connect the DVD player optical to the Kenwood as well. This will allow you to get whatever your watching, DVD or Satellite to your speakers. For Video, use the component cables to connect DVD player to TV. For the SAT box, coaxial to TV or S video to TV will give you about the same video quality. I hope this helps. A couple of suggestions: Your new screen size will greatly magnify the quality of your video, what looked good on the Sharp may not look good on the Samsung due to the size difference. I REALLY suggest you get a new SAT box with a HDMI connection. Also you can get a blu ray player in the $120 range. The Blu ray will play blu rays and upconvert DVDs to a higher quality picture through its HDMI connection. You will be amazed at the difference HDMI will make on how your TV will look!
Oct 29, 2008 | Kenwood VR-405 Receiver
Onkyo HTR500 no sound from the surround speakers or subwoofer
insted of running it thru the tv an to the reciver try doing it directly from the DVD player to the reciver just the audio jacks
Sep 08, 2008 | Onkyo HTR500 Receiver
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Digital optical from DVD player produces no audio
Hi, It sounds like your receiver is still looking for audio on the coaxial connection, rather than the optical.
1. Make sure the optical connection is between your DVD player and the LD/DVD Optical In on the back of your receiver.
2. If you have a monitor connected to the receiver to show the on-screen display, click Setup from the main menu, click Input Mode, then, next to LD/DVD choose Optical. It may be set to coaxial, analog or auto.
Alternatively, choose the input source on the front of your receiver (LD/DVD), then press Input Mode button (bottom right, near the input selector) till it displays Digital Optical.
If all else fails, reset the receiver by:
1. Turn off the receiver
2. Hold down DISPLAY and PANEL UP/DOWN buttons and press power.
3. All Clear should appear on the screen.
Use caution, however, as this will erase all the settings in your receiver.
Nov 28, 2007 | Sony STR-DA90ESG
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
Technics SA-AX530 Receiver Logo
195 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
