Question about Konica Minolta magicolor 2400 Laser Printer
Minola print smudge
My Konica minolta magicolor 2400w has a regular mark on the printout that has no color about 1 inch long 4mm wide. It looks a bit like the toner has been dragged off before fusing. Its always in the same place and it appears in a second place on the same line but not as big?
This question was in the troublshooting guide....answer seemed rather vague.....I have the same problem..... it occured just before or after I replaced the imaging unit.....I can't remember as I replaced the black toner cartridge a few days later thinking that would solve the issue.....it didn't...It seems like it started just after the imaging unit was replaced, but I am just not sure
I had a similar problem, but just a vertically colorless stripe. After changing the resolution from 1200*600 to 600*600 and then printing a page the error disappeared. Setting back to 1200*600 had no further effect. The stripes were no longer printed out. Driver bug?
joe
Posted on Dec 21, 2008
    Champion:
  • 214 Answers
Pleas check the imagine unit drum, is it clean or does there are the same marks as in paper.
if yes, the IU drum cleaning or drum itself is damaged and needs to be replaced.
Try:
after sending a print job, when printer has take a paper from tray, open cover, open cover before the paper enter the fusing unit, then you can see, if the mark is allready in the paper then the problem is in the IU or toner cartridge, if not, then fusing unit rollers.
Posted on Jan 11, 2008
2 Suggested Answers
J PENGUIN
  • 12 Answers
SOURCE: Regular toner drag marks on printout
MACHINE DRUM UNIT, IMAGE BELT, AND TONER UNIT NEED TO BE REMOVED AND CHECKED AND CLEANED IF THEY LOOK GOOD THERE MIGHT BE A PIECE OF PAPER BLOCKING THE LASER SITE AREA INSIDE THE MACHINE IF ALL IS GOOD, CHECK THE FUSER FOR WOREN HOT ROLLER ,DIRT OR PAPER WILL BLOCK THE IMAGE TH THE PAPER
Posted on Dec 31, 2007
Smudge and missing ink
remove all image units. clean the class where the laser writes on the drum with machine no laser. so clean. smudge what color replace the that color image unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 07, 2014 | Konica Minolta Magicolor 1600W Printer
Konica Minolta 2430 DL has Smudges or dots on page
Not an expert on this brand of printers but it looks like dirty feeder rollers to me. Try cleaning them and Print a Blank document and see if the marks show up
Jan 24, 2014 | Konica Minolta magicolor 2430 DL Laser...
Magicolor 2400w
What color? Replace the image units All colors? Transfer belt or fuser unit.
Dec 08, 2013 | Minolta magicolor 2400W Laser Printer
How to deactivate toner colour errors?
if any toner ends in a printer, then replace it.otherwise error will show continuously.
Apr 22, 2010 | Konica Minolta magicolor 2400 Laser...
Printer smudging caused by self-sealing envelope glue on drum
Drums are not hot, you can try to clean them, are they smudgy? More likely the glue came off when it hit the hot section check this area, be carefull not to scratch anything.
-Carl
Apr 09, 2009 | Ricoh Aficio CL3500N Laser Printer
Error light flashed when trying to print with Magicolor 2400W
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Jan 20, 2009 | Konica Minolta magicolor 2400 Laser...
Smudged printing
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Konica Minolta Magicolor 2400W -- Only Prints on Reboot!
I've had that problem before too, and found out that there were copies of the printer that had somehow installed themselves on my computer. All I needed to do was to choose to print with "konica minolta copy 1" instead of the one that I *thought* was installed and it worked. I then deleted the original printer and just stuck with the copy.
Jul 22, 2008 | Konica Minolta magicolor 2400 Laser...
Konica minolta magicolor 2400w printing proplem
pleas check transfer belt, and drum unit, probably these lines are caused by drum unit and you have to change it. also you can clean laser glass, what is under the drum unit. if both look fine you can also look at the fusing rollers.
May 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Dec 30, 2007 | Konica Minolta magicolor 2400 Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
224 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
