Question about Sony PlayStation Portable (PSP) Console
PSP ok my psp wont turn on the green light flicks on and off fast ive tried playing with only the charger ive tried taking out the battery for 5 mins and then playing ive tried keeping it on the charger i dont know what to do this happened the last week of november and i know i didnt brick it cause ive never turne it off when updating or put it to sleep the last game i played was ben 10 then i put it on the charger the next moring it didnt work i dont know what to do if i should buy a new one or get a new battery please help me thank u
    Problem Solver:
  • 12 Answers
Yeh this may be your batery has gone but if it had it would alow u to play with the charger in. have u updated to the latest software?
Posted on Jan 01, 2008
0 characters
3 Points
Need help my psp is not working when I turn on I can only see the green light no sounds no display just green light and after a few seconds later it turns off the last thing I did I update with something...
First you have to take out the battery and use charger to turned on and when it turn on just put on the battery or take out the battery and wait for minutes then put it on and tur on,if that doesn't work when you turn on just hold R and start or repair it
Feb 06, 2013 | Sony PlayStation Portable (PSP) Slim...
I have just gotten my psp and i started using yesterday. i only played for about ten minutes, then the game just cutt off. The green light was blinking all the time and i charged it but it still will not...
If you are playing games from custom firmware then follow these steps:-
1) take out your psp battery
2)put on charge direct from charger(make sure the battery is not in psp)
3)turn on psp holding right trigger to move on psp recovery menu.
4)reset all flash settings(it's somewhere in advanced tab)
5)after resetting fullt turn off psp and put psp battery in and turn on here you go.
Jul 26, 2011 | Sony PlayStation Portable (PSP) Console
PSP screen turns on to a black screen and don't turn back off
When you were taking out the chip out of the slot, you most likely scratched the motherboard below, which takes care of WiFi and the memory chip yourself. Your best bet would be to call Sony if it is on warranty, if not, buy the part from eBay and have someone install it.
Aug 27, 2009 | Sony PlayStation Portable (PSP) Console
My PSP Light Turns Green, But wont turn on.
try charging it for a FULL day. if that dosent work replace the battry with a new battery from best buy or something
Jul 14, 2009 | Sony PSP-3000 Silver Console
Psp wont turn on
try leaving it in the charger and playing it, happened 2 mine ,once the battery is full take it out. if not then just take ot the battery for a while
May 28, 2009 | Sony PlayStation Portable (PSP) Console
My PSP wont read my battery
Try putting it in a bag of rice for a day or so, because rice absorbs moisture, so it might draw out any water still inside. Hope this helps.
Mar 17, 2009 | Sony Battery Charger for PSP
My psp wont turn on ,but the green light stays on for a couple of seconds....
hey guy's can you help me i was upgrading my psp from 5.03 gen c full to 5.50 gen d full and when the installion is completed it said reboot your psp or shutdown i click the reboot button and suddenly the screen was all black i let it stayed black for 10 minutes but it is still black the green light is working but the screen is black
Jun 12, 2008 | Sony PlayStation Portable (PSP) Console
Psp battery problem
the problem 's if u kept ur psp battrey without changing the battery it will bad , you have to wake up the battery by open the battery ,you remove the battery from the case .use solding iron to remove it after that , use ur psp changer to jump start the battery for just 5 min , after that solder it back it will start working ,,,,,,, bye
Dec 20, 2007 | Sony PlayStation Portable (PSP) Console
Power problems
Hi Gohan102,
Open the battery compartment, and remove the battery.  Look at the bottom inside corner for a little square sticker with has marks on it. is it dark or light,  If it is dark, your PSP has come in contact with moisture. I suspect that your PSP has gotten wet or damp.  If the sticker is dark, you need to keep your battery out for about 2 days, and keep the UMD door open and the whole PSP kept in a dry environment.  Try it after 2 days of drying to see if it is recovered. Good luck Gohan....
Oct 17, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
76 people viewed this question
Top Sony Video Game Consoles Experts
Troy Gorman
Troy Gorman
Are you a Sony Video Game Console Expert? Answer questions, earn points and help others
