Question about Kodak 4200 Slide Projector
New lamp need lamp
  • 142 Answers
This link tells you the lamp type you can use. EXY, EXR or FHS. has the FHS for around $10.00. Seems like a good price for the lamp. Other suppliers range from $8 to $25.
Posted on Mar 14, 2008
Help me, problem epson ex 7210. on start 15 second flashing power, lamp, tempurature red.
There could be two reasons.1.the lamp life has come to an end.
2.The ballast that powers the lamp could be defective.
for solution to first possibility open the lamp and check the lamp burner in the centre of the reflector for breakage. also check if the lamp has a small pcb on the side.if the lamp lamp has exhausted then this pcb is at fault. You need to procure new lamp.
if 2nd possibility then u need to replace with a new ballast.
Dec 04, 2014 | Epson EX 7210 LCD projector
I have replaced my Projector lamp, i have had a picture but has shut down and now will not give me a picture and led light blink five times, do i know i didnt reset the lamp setting when i first got my...
You have to check the lamp ballast supply board. If the Lamp ballast board is faulty the it will burn the new lamp installed. 5 blinks means the lamp is faulty. can be caused by faulty lamp ballast. To deal with the lamp ballast you should need a good knowledge in electronics. Because electric shock risk is involved. Also you need a new lamp
Sep 07, 2011 | Sony KF42E200 TV
I have an ge proline magnetic t12 ballast it has two red leads two blue leads and two yellow where as my fixture has one red one blue and the hot and nuetral are wired through the other side of the bulb...
Need more information, how many lamps are in the fixture? The new ballast is for how many lamps? Basically you need to follow the diagram on the new ballast. If the new ballast is for a four lamp fixture one yellow gets capped and the other yellow goes to one side of each lamp on a two lamp fixture. Then on the other side one set either red or blue goes to the other side of the lamp one wire per lamp and the other set gets capped . Hopefully this helps parkeroc68_0.jpgparkeroc68.jpg
May 22, 2011 | Electrical Supplies
Replaced the optical block a few years ago to correct the yellowish hue problem. Recently I had to replace the lamp. I had bought one new about 2 years ago. I put the lamp in and the TV is much dimmer than...
Lamps only last Between 5,000 hours some last 8,000 hours
So what that means For Every hour TV is Playing it is burning up hrs of lamp. These sets are not like projection that you can run day and night .
Most Lamps need replacing every 2 yrs Depending on how many hours you watch TV?
It could be that the Lamp you have is defective ,Mats has Lamps for $99.00 1-800-628-1118
Get New Lamp then see if that corrects the problem.
Sep 18, 2010 | Sony KDS-R50XBR1 50" HDTV
Need to replace NEC Lamp Unit in VT75LPE. Unit is bolted to ceiling in library and unable to be detached easily. What is procedure for replacing lamp?
Hi. You are most likely going to have to remove the projector *and* the projector mounting plate in order to access the lamp door. Mark the orientation of the projector mount plate with a marker and set aside. Remove the lamp door with a proper screwdriver. The PROJECTOR MUST BE COOL TO PROCEED!! The lamp will be secured, usually with 2 screws. Loosen these screws--new screws should come with the new lamp--already held in position. Using the hinged metal handle, pull the old lamp straight up and out of the projector. ( you might have to wiggle it and work it out steadily--its a precision fit) Take your time and *don't force* it! Carefully slide the new lamp into position, taking care that the power connector on the lamp assembly is properly seated. MAKE ABSOLUTELY SURE YOU DO NOT TOUCH ANY LAMP GLASS WITH YOUR FINGERS!!! If you do get finger prints on any glass surfaces, carefully wipe them off completely with a dry, soft cloth--DO NOT USE CLEANER!! This is critical to the life of the new lamp--finger oil attracts heat and will cause the new lamp to fail pre-maturely. Re-attach the lamp door--make sure you don't over-tighten any screws on lamp or door--they need to be firmly tight but not "gorilla" tight! lol Clean any dust filters thoroughly before re-attaching the mounting plate--you'll be glad you did! After re-mounting the projector, power it up and go into the menu in order to reset the lamp timer.--Hope I helped you!---Rick
Dec 30, 2009 | NEC (VT75LPE) Projector Lamp
I bought a new lamp for my sharp XR-11XC. Standaby/on light is flashing and lamp light is red. TI tried two new lamp. all has the same problem. Need help, Thanks!!!
have you reset the lamp timer yet? can't remember the procedure for that one exactly often hold power and down and left arrows whilst plugging in power. Check info on instructions that came with your new lamp.
Nov 18, 2009 | Sharp Projector lamp Projector Lamp
Green projection lamp not working
  1. you will need a manual screwdriver to remove the panel. You need a soft non-abrasive cloth to avoid any contact with your fingers and the lamp assembly.
  2. Turn off the Projector. After the unit has cooled down properly, remove the power cord from the outlet..
  3. Remove Lamp Compartment Door. The lamp compartment on projectors islocated underneath the projector unit. For Rear Projection TVs, the lamp compartment is located in the rear bottom left or right side of the TV.. Remove the screws and the lamp compartment door.
  4. Remove Lamp Assembly. pull out the lamp assembly disconnect any power cords that is still connected to the lamp assembly. Put it aside and don't get it confused with your new lamp!
  5. Clean Lamp Compartment. Dust gets everywhere and while you have the projector open, use a soft cloth to remove any loose dust from the lamp compartment.
  6. Insert New Lamp Assembly. reconnect any power cables to the new lamp if present and slide the new lamp into the compartment in the same orientation that the original lamp came out.
  7. Replace Lamp Compartment Door. Set the lamp compartment door back into place and securely screw in the door without screwing it in too tight
Nov 03, 2009 | RCA P52939 52" Rear Projection Television
Optoma RD50 Lamp Issues
replace the fuse thats on the little board beside the new lamp. that will reset the buld to new. I understand that the fuse will blow right after a new lamp is installed. It will reset the counter to 0.
Hope this helps
Dec 30, 2007 | Optoma RD50 50" Rear Projection HDTV-Ready...
Lamp replacement
Just replace the lamp! It's just a fluorescent light you can get anywhere. You don't need a new scanner, if I had to replace the scanner every time the lamp died I be in the poor house!
Sep 17, 2007 | Agfa DuoScan Flatbed Scanner
Kodak 4200 Slide Projector Logo
112 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
