Question about Thomson 28VK25US TV
Tompson 32WX411t the TV does not come on when you press the standby button but flashes, when you turn the TV on for the first time leave it for a few seconds and press the channel plus button ot flasehes orange and gos back to red, then flashning again. We thought the TV was locked but following instructions to unlock did not help, nor did changing the batteries on the remote? Please can you help?
  • dulypa Jul 22, 2008
    I've got the same problem with my tv...I think it's locked...you said you followed instructions to unlock the machine...Which are these instructions??how can I unlock the television? Thank u!
I had the same problem with a ten year old set when I was trying to connect a satellite receiver and after considering all the possibilities, like processor lockup, overloading the video input with audio, shorting the scart sockets, and of course voltage failure I concluded that the problem was caused by moving the tv so I decided that with nothing else to lose and having sorted out a similar problem with a computer hard disc I lifted the left hand side of the tv by four inches and dropped it. It now works perfectly and as I was actually looking forward to an excuse with my wife for buying a HD wall tv I am a bit fed up as it is still a perfectly working tv,
Posted on Oct 20, 2008
Ok, I'm not sure if I get this right, but if the telly is ok when you turn it on or change channel from the telly itself, then it may simly be that you need to use the actual number buttons to turn it on from standby.
Posted on Apr 23, 2008
  • 579 Answers
Sounds like high voltage failure and if the set is about 10 years old it is not worth putting any more money into it
Posted on Dec 31, 2007
Please my tv with on the standby mode when i try to put it back it couldn't the indicator now goes on and off with picture show please help
The standby light on a Sony television indicates when the television is turned on and operating, or turned off and in "standby" mode. However, this light also serves a secondary function: indicating when there is a problem with the television by flashing. When the standby light begins to flash, there are two reset options that can be performed to resolve whatever issue it's indicating -- a power reset and a factory reset
POWER RESET
1. Turn off your TV
  • 2. Unplug the television from the electrical outlet. If you're using a surge protector or power strip, disconnect the television from the strip itself. Only by disconnecting the power cord from the outlet can you ensure no power reaches the TV during the power cycle.
  • 3. Leave the television without power for at least 60 seconds. This gives the television enough time for all components to power down during the power cycle
  • 4. Plug the television back into the electrical outlet. If you're using a surge protector or power strip, plug the television directly into the wall outlet instead. The surge protector may otherwise interfere with the power-up cycle, especially if it is old or damaged.
  • 5. Turn on the television. If the blinking standby light continues, you'll need to move on to the factory reset process.
  • FACTORY RESET
  • 1. Turn on the television.
  • 2. Press and hold either the "Reset" or up arrow button on the remote control.
  • 3. Press and release the "Power" button on the front of the television, while keeping the "Reset" or up arrow button on the remote depressed.
    4. Release the "Reset" or up arrow button.
    5. Allow the television to reset after the "Reset" message appears on the screen.
    6. Make no adjustments to the television for at least one minute after the reset has completed. This is to allow the television time to finish auto-configuration and initial set up.
    7.Turn off the television and unplug the power cord from the electrical outlet.
    8. Wait ten seconds, then plug the television back into the electrical outlet and turn on the TV.
    9. Follow all on-screen instructions to complete setup. These are the instructions displayed the first time you set up the television, for configuring channels, menu language, time, display properties and more.
  • Dec 30, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    My sony kdl-46v3000 standby light blinks 5 times tv wont turn on
    The TV enters standby mode when there is no signal for 30 seconds. https://docs.sony.com/release/KDL46V3000.pdf
    I searched standby using Ctrl+F and found this information. It seems you should be able to bring it out of standby using the power button on the remote. You want to make sure there is an input connected and if it is connected to a PC that the PC isn't telling the TV to go into standby.
    Try pressing the input button and changing inputs once you press the power button and the Standby is flashing.
    If this doesn't work you may need to contact Sony Support.
    1-800-222-SONY(7669)
    Apr 10, 2014 | Sony Bravia V-Series KDL-46V 46 in. LCD...
    When turning on tv. screen will display Bravia image & then go blank. red light flashes SIX times
    Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TVicon1.png will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
    Good Luck Ed Pinero
    Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
    Feb 02, 2013 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
    My pioneer plasma tv in standby mode and wont turn on
    Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
    Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
    LCD tv won't power on...
    The power board is dead,replaced the board.Well get the power back.Tries Shopjimmy.com,Ebay.com for the part.
    Jan 26, 2010 | Televison & Video
    How do you tune Sky+ remote into Sony KDL46W5710 Television
    The Sky+ remote should automatically default to Sony TV's. Leave the batteries out for a few minutes and try again. The Code for Sony is 0000.
    Or try this :-
    With TV and sky box on.
    Press the 'TV' button on the remote.
    Hold down the 'select' and the 'red' button (of the four coloured buttons) together, until the red light on the remote blinks twice. (takes 2 seconds)
    Press the 'TV' button again.
    Now enter four zeros, the red light on the remote should blink twice.
    Press the 'standby' button (top right).
    If the TV turns off, then press 'select' and the light should blink twice again, job done.
    If the TV does not turn off then press 'TV' followed by 'standby' again.
    Alternate pressing 'TV' 'Standby' until the TV turns off.
    When it does, finish by pressing 'Select.
    Check the red light on the remote, if it blinks 3 times, then it has run out of options for 0000.
    Dec 19, 2009 | Televison & Video
    Tv wont turn on and has a high pitched sound while plugged in
    your flyback transformer and driver circuit are operating, but the horiz. output transistor that needs to be in circuit w/horiz output transformer is open and can't amplify the signal needed for the flyback xfmr
    Oct 09, 2009 | Televison & Video
    I want to find the Sky remote code for this Tv.
    Just got an LG 42LH2000 and code 0206 works
    May 16, 2009 | LG Televison & Video
    Televison & Video Logo
    453 people viewed this question
    Top Thomson Televison & Video Experts
     Grubhead
    Grubhead
    Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
