GE Profile Harmony DPGT750GC Gas Dryer
Problem for GE Profile Harmony DPGT750GC Gas Dryer
I am having a problem with my Ge dryer catching my
By michellea30 on Oct 25, 2009
I am having a problem with my Ge dryer catching my clothes somewhere in the front by the top of the door it rips the clothes when trying to get them free can you help
Solution #1
posted on Oct 25, 2009
Not Rated)
rocksursox
Rank: Master
Rating: 90%, 5 votes
HHHMMMMMmmmm...seems like if it is an older dryer, the drum support rollers may be worn out. This can and will cause the drum to rub against the front of the dryer and snag the laundry inside.
To fix this, the dryer must be disconnected from the power source and the back panel removed. Before going any further, manually push and pull the drum to and from the front of the dryer and see if there's slack in the rollers. You'll probably need a helper for this.
If there's slack, remove the belt then the drum, and replace ALL the rollers at one time. There should only be 2 or 3 depending on the machine, they're not expensive nor are they difficult to replace once you're inside the machine this far. But do them ALL and you won't have to do this again more than likely.
After you reassemble everything and before you reconnect the power, see that the dryer is level. You can adjust this by turning the "feet" under the front of the dryer. This will prevent laundry from "migrating" to the front of the dryer and wearing out the rollers again.
Was this helpful?
Yes
No
Solution #2
Not Rated)
tcochuck
Rank: Guru  Washers & Dryers  Expert
Rating: 93%, 35 votes
it may be snagging clothes on a sharp edge or flashing on the plastic light assembly overhead of the door. you might just need to take a small piece of fine sandpaper and remove the burr or sharp edge thats snagging stuff..
also one or both of the rollers in the front may be worn, allowing the drum to bear down on the seal more, opening a gap at the bottom to grab your clothes then pulling them around with it, you just happen to catch it when its stopped and sitting still just hanging there.. while u have it apart u might as well check the rest of the rotating parts out for wear, etc and replace while you have it opened up..
hope this helps,
best of luck,
ttfn
Was this helpful?
Yes
No
Popular Solutions for GE Profile Harmony DPGT750GC
Questions and Unsolved Problems for GE Profile Harmony DPGT750GC
Do you recommend GE Profile Harmony DPGT750GC Gas Dryer?
Answer
Answer
is it possible toswitch the exhaust on a gas HE dryer from rear to right side (when facing it)?
Answer
I went through all the tests and the only test that did check out was the Ignightor, I ordered a new... (More)
Answer
My dryer is not heating and someone has said it is not heating element or the coils that send the... (More)
Answer
GE Gas Dryer. Replaced sensor and ignitor. Heat comes up temporarily then goes out.
Describe your Dryers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryer Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
