Question about Durabrand DWT1304 13" TV
Remote my remote just stopped working even with new batteries .... or is there anyway to get the "game mode" with the menu???
  • Mumsi Mar 06, 2008
    I also would like to access the game mode thru the menu but can't figure it out. Anyone know. I will go and see if I can find a remote control that states durabrand, but they don't have a game button either. Thanks
  • Bonsignore Jun 01, 2008
    Bought the set second hand and it was in game mode. Took it off to check channel reception and now can't get game mode back. No remote.
Unless if there is a remote control code for this specific one< DWT1304> i need to figure out to put on "game mode" with out the remote control and apparently am stuck with nowhere to go> i cudn"t find the remote control codes< ya have em or?
Posted on May 27, 2008
I have a Durabrand as well and can relate to your frustration. my solution...get a new TV.
Posted on May 09, 2008
Yeah the solution in the first place doesnt help AT ALL!! HOW DO YOU DO IT WITHOUT A REMOTE!!!
Posted on Jan 12, 2008
    Problem Solver:
  • 17 Answers
Try taking the batteries out of the remote, then pressing the power button on the remote for 5 seconds. Then replace the batteries. This should have reset the remote and should work.
Posted on Dec 31, 2007
How to get universal remote to turn the tv to game mode
I don't know if this can be done with a universal remote, but if you can let me know which brand and model of universal remote you are using, I will check if it is possible. If your universal remote has an "AV", "SOURCE" or "INPUT" button, try these but make sure the game system is switched on so you are able to see if/when you have changed to the correct mode.
If you don't have the original Symphonic remote, you should be able to switch the TV to game mode using the buttons on the front of the TV as follows:
1. Switch the game system on
2. Press the "MENU" button on the front of the TV
3. Highlight "PICTURE" using the CHANNEL UP/DOWN buttons
4. Press the VOLUME UP button once to enter the PICTURE menu
5. Highlight "GAME MODE" using the CHANNEL UP/DOWN buttons
6. Use the VOLUME UP/DOWN buttons to set "GAME MODE" to "ON"
7. Press "MENU" to exit the menu and play games.
The menu should automatically close anyway if you don't press any buttons for about 15 seconds.
When you have finished playing your game, repeat the above steps to set "GAME MODE" back to "OFF" and return to watching TV.
Hope this helps. Please post back for further assistance if needed.
Dec 23, 2010 | Symphonic ST419E TV
Wii remote is not turning on
You probably need to re-sync the Wii Remote.
Standard Mode SynchronizationNote: Make sure you have placed batteries in the Wii Remote.
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
Oct 20, 2009 | Nintendo Wii Console
The remote just magically stopped working, even after new battery
Have you tried pressing the 'input' button again this time to switch from video to tv? This happens in quite a few cases where 1 remote is used for many products. Please try and let me know.
Aug 21, 2009 | Televison & Video
My remote will not work and the tv menu is on the screen and goes through all the diffrent setting options automatically without stopping. TV buttons will not control the menu. Unable to make any setting...
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6 hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when it starts to work,set new pin code.use your instruction book,to set all blocks to N,,Clear all favorite channels + erase channels in tv 's memory if there in there yet,takes a lot of will keep resetting,remote won't work.let it run awhile. then push exit, hold 5 to 10 seconds remote will eventually come back,check your settings reset them, be sure menu is set to STOP, it may start running threw all its modes again,let run couple hrs, then push exit 5 to 10 seconds to get your remote back.keep trying this. when you think the tv is working right,turn it off for 10 seconds then back on. If it starts resetting, let it run an hr,then push exit again to get your remote back,it has to reset everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I don't have working is the pic size button,Don't need that anyway. GOOD LUCK.
Jan 17, 2009 | Toshiba 36A43 36" TV
Remote doesn't work
Slide the bottom part of the remote control down. Switch the bottom right button to DVD 1. There might be a white sticker that covers it so remove the sticker first. Then hold down the "Enter" button and the "1" button down at the same time for a few seconds. That should make the remote work again.
Feb 25, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Game Mode
On the TV itself, press the MENU button. When the menu opens, "PICTURE" should be highlighted in pink and the rest of the menu items will be an aqua color. That means you are in the right place....Press the volume "up" button... this will open up the Picture menu items. When the menu opens, start pressing the channel "up" button. You will see (bright, color, etc.) options in this menu. Keep pressing the channel up button until you see "Game Mode"... the options will be ON and OFF. Use the volume "up" and/or "down" buttons to toggle back and forth between ON and OFF... if you want to watch TV, be sure to turn the Game Mode OFF... otherwise the picture will be VERY dark...
Dec 24, 2007 | Symphonic ST419E TV
DS not going to the menu but straight to the game. This annoying
When turning your NDS ON press the select button a while and the main menu must appear instead the game.
To disable the Auto Mode go to:
Manual Mode: if you would like the main menu screen to appear or;
Auto Mode: if you would like for the game cartridge to run when you turn on your DS.
Anyway at this time you know how to access the main menu screen in auto mode so if you like the game to load instantly then let the setting in auto mode and access the menu only when needed.
Good Luck...
PD: I am not Daniel, dont even know him XD...
Dec 07, 2007 | Nintendo DS Lite Console
Dwt 1905 tv stuck in game mode
Comcast universal remote code for dwt 1905 is 0171, just tried it, it works
Nov 26, 2007 | Durabrand DWT1905 TV
Getting tv off of game mode without remote
Have you checked to see if there is a setting in the menu under Picture? Mine has the option to turn Game Mode off or on. It is listed as a Durabrand Television but the # DWT1304 is the same...I have to use the Menu button because my remote stopped working. Good luck
Sep 24, 2007 | JVC AV-27530 27" TV
Game Mode
not familiar with this model but ill try try in the menu puting it on game mode then look for external input mode in the menu and turn it too dont work fix ur remote or bye a new one (be sure that the new remote will activate the game option) good luck windman
Jan 02, 2006 | Sylvania W4913LT TV
Durabrand DWT1304 13" TV Logo
290 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
