Refrigerators Logo
Posted on Oct 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Whirlpool Side by Side Refrigerator Model # ED25PQXFW01. It makes a clicking noise about every 2 minutes almost sounds like the compressor isn't turning off and the food is defrosting in frig and freezer. Any help?
Anonymous
Level 3:
President:
  • Master 1,218 Answers
  • Posted on Oct 25, 2009
Anonymous
Master
Level 3:
President:
Answers
1218
Questions
Helped
276961
Points
3870
Clicking sound is the protective overload mounted on the side of the compresser to shut the power to the compressor off, should it be unable to start.
After cooling down, it will repeat to try to allow the compressor to start.
Two possibilities.
1. The start components for the compressor are mounted on the side of the compressor and include the protective overload. The parts here are A.the start relay(two styles solid state or current type), B.on some but not all models a start/run capacitor, and C. The overload that you hear clicking. To test these components, you will need a knowledge of electical and ability to use a VOM meter. If you lack these qualifications take them to an appliance parts house and in most cases they will test them for you.
2. Compressor failed. To be totally safe, this test should be performed by a qualified tech.
Compressors carry a 5 year warrant from date of sale, and if the extended warranty is purchased. 10 years.
To allow yourself the most accurate responses in the future on any device you might need help, it is best you start by giving the age of the device. If you don't know, best guess will do.
1helpful
Knocking noise coming from bottom of refrigerator
check the compressor for operation adn check the fan in the back of unit to make sure it is running...whirlpool units are notorious for compressor relay failure normally they click in and out every few minutes... if it is a knocking noise and continuous make sure compressor is not trying to start and sitting there shaking... normally it will stop after a few minutes and then start again....
3helpful
Whirlpool gold refrigerator warming up and freezer defrosting
This clicking noise is the relay on the side of the compressor. It has been damaged and not working properly. Simply replacing this should be able to start your compressor! I would be VERY surprised if this was not the problem based on your description. If I can be of further assistance let me know! good luck!
Have a whirlpool side by side refriferator estate model. Freezer won't get cold. Cleaned off underneath,fan is turning, Unplugged for awhile and plugged back in. Keep hearing clicking noise coming from...
Plastic box you're referring to contains the start components for the compressor. The clicking sound sound you hear is the protective overload shutting the compressor off because it won't start.
Two possibilities
1. The components inside the plastic box (cover) are defective and need replaced. You can remove them, by snapping off the cover and pulling them straight off. Most appliance parts houses will be happy to test them.
2. The compressor has failed internally.
Note: In my personal experience when dealing with whirlpool Estate models, 99% of the time it has been a failed compressor.
Refrigerator won't get cold
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
1helpful
Whirlpool
How to check stuff>
2answers
Buzzing and clicking sound every few minutes
Compressor start relay - white plastic part - sitting right on the compressor, disconnect it shake it - u'll here it if it's damaged. :)
3answers
Whirpool GS6SHAXLB03 Refrigerator or freezer do not cool.
This sounds like it's out of freon. Not just low but out. That clicking noise is a thermal overload shutting down the compressor. If you continue let it just click away it will burn this overload out and the compressor will have to be replaced. If the refrigerator just started doing this suddenly it could be that the compressor is locked up. If it has external capacitors either the start or run capacitor could be bad. If the capacitors are good then you could try a hard start kit to try to unlock the compressor.
1helpful
2answers
Freezer quit freezing
HI,
you can try this suggestion first.
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
