Epson Stylus Photo R220 InkJet Printer
Problem for Epson Stylus Photo R220 InkJet Printer
Printer does not print a proper testprint
By kees_terlouw on Oct 25, 2009
printer does not print a proper testprint only two or three colors printing.
printhead may be damaged cleaned the printhead several times.
and try to make testprints but no result.
Solution #1
posted on Oct 25, 2009
Not Rated)
cq92
Rank: Wiz
Rating: 84%, 88 votes
You have an interesting printer ! I have two of them. Same problem. Basically to use ink refills one must have a chip reset utility. The cartridges are filled from the bottom and consequently leak if not sealed properly. The only solution is to use the blue grey plugs that come with some refill kits- Dell Refill kits have them - but only give you three. The next best is to use black electrical tape heated with a lighter then applied after the fill. What appears to happen is that the ink indicator may say there is ink but the cartridge is actually dry. Additionally I have found some new cartridges seem to have a vent problem - what happens is a vaccuum is created in the cartridge on head cleaning and a color will print, then not print , then the next one will do the same. Some brand new cartridges have chips also that the printer does not recognize. The solution is to use a chip reset tool and the old chip from the empty cartridge on the new one. There is a software called SSC Service Utility that works for deep cleaning and also resetting the ink pad counter - it will stop printing if the pad counter runs out. Basically if it refuses a nozzle check print - it is not getting ink or has no ink left.
Comments:
Oct 25, 2009
- You have an interesting printer ! I have two of them. Same problem. Basically to use ink refills one must have a chip reset utility. The cartridges are filled from the bottom and consequently leak if not sealed properly. The only solution is to use the blue grey plugs that come with some refill kits- Dell Refill kits have them - but only give you three. The next best is to use black electrical tape heated with a lighter then applied after the fill. What appears to happen is that the ink indicator may say there is ink but the cartridge is actually dry. Additionally I have found some new cartridges seem to have a vent problem - what happens is a vaccuum is created in the cartridge on head cleaning and a color will print, then not print , then the next one will do the same. Some brand new cartridges have chips also that the printer does not recognize. The solution is to use a chip reset tool and the old chip from the empty cartridge on the new one. There is a software called SSC Service Utility that works for deep cleaning and also resetting the ink pad counter - it will stop printing if the pad counter runs out. Basically if it refuses a nozzle check print - it is not getting ink or has no ink left.
Was this helpful?
Yes
No
Popular Solutions for Epson Stylus Photo R220 InkJet
Questions and Unsolved Problems for Epson Stylus Photo R220 InkJet
Do you recommend Epson Stylus Photo R220 InkJet Printer?
Answer
Answer
My Epson printer works with my new snow lep., but i can not find the drivers for the print cd part... (More)
Answer
I'm having trouble printing on cds (they won't load) with my epson stylus photo r220. I've followed... (More)
Answer
keeps coming up jam when trying to print cd. After a few times it does print. I got a new tray but... (More)
Answer
clear plastic strip which runs along back of ink cartridges from one side to the other
Answer
When switched on the far left red light continues to flash. There does not appear to be any blockage... (More)
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in Newport, KY
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
