Hunter 20803 Low Profile III White Ceiling Fan
Problem for Hunter 20803 Low Profile III White Ceiling Fan
My Hunter 20803 ceiling fan only works at one
By jamesfransco on Oct 25, 2009
My Hunter 20803 ceiling fan only works at one speed. The part that controls the speed (5uf 250WV.AC) burned out.Home Depot & Lowes do not carry that part. Any advice on where to find the part besides replacing the fan?
Solution #1
posted on Oct 25, 2009
Not Rated)
VtToolMan
Rank: Guru
Rating: 97%, 651 votes
The part you are making reference to is a capacitor and you can very likely get a replacement one at any local Radio Shack store. It is best to take the defective part with you so they can review all the markings to get the best replacment part you need.
If the capacitor isn't connected with wire nuts, you'll want to cut the wires as close to the capacitor as possible, so you'll have some wire to reconnect the new part. I also suggest you take a picture with your digital camera or camera phone BEFORE you remove the bad part, that way, you can refer back to it, when you are installing the new part.
With any electrical device, you will want to disconnect it from the power source before doing any repair or service work on it, to prevent electrical shock hazards. In the case of a ceiling fan, you can either remove the fan from the ceiling or turn off the breaker that provides power to that room (check to make certain you got the correct breaker turned off!) Also, you can make sure the wall switch that controls this fan, if you have one, is turned "off". You can tape over the switch to remind others not to turn it on, etc. while you get the parts to make the repair.
Hope you find this Very Helpful and best regards!
Was this helpful?
Yes
No
Popular Solutions for Hunter 20803 Low Profile III
Questions and Unsolved Problems for Hunter 20803 Low Profile III
Do you recommend Hunter 20803 Low Profile III White Ceiling Fan?
Answer
Answer
Replaced receiver and remote for Hampton Bay Windward II ceiling fan. Fan has only one speed in... (More)
Answer
I need a Blade mount assy. yhe one you attach the blades to for a pc-52 ceiling fan
Answer
I have a flameright ISIS which will not switch on, . I get a very slight flicker when its plugged in... (More)
Answer
It's a stealth model with a remote control. It was running a few days on "Winter" -- very... (More)
Answer
four armed light went out but fan works.dosen't look like you can replace light only. can u?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Electric Fan Experts
Top Small Appliance Repairmen
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
