Question about Coleman (100076) Compact Refrigerator
Koolmate No Heat or Cold
My Koolmate 40 is about 5 years old and while the fan motor still operates fine and I replaced the power cord about a month ago it abruptly stopped cooling (or heating when reversed). I checked for continuity across the theromelectic cooler so while it obviously isnt functioning correctly it is still a viable circuit. Any other troubleshooting tips and or knowledge of where to simply find a replacement thermoelctric unit would be appreciated.
    Master:
  • 619 Answers
Please visit to www.tetech.com
Posted on Jan 01, 2008
Unplugged fridge 9 months and now it doesnt cool at all
it's 20 years old,replace it,don't waste a penny into that machine,most likely you have a problem in the sealed system compressor and freon so don't waste any of your time or money.good luck,if you say the compressor and fans are running and it's not getting cold one of the lines could have rotted out and the freon gas leaked out,you can remove the back inside wall of the freezer and look at the evaporator coil,if it's running fine you should see an even frost pattern covering the coil,if you only see frost where the lines connect to the coil you have a freon leak but i wouldn't even waste my time doing that on this machine just repace it.
Jan 01, 2014 | Refrigerators
Fan will not work
mcdevito75 here, Most likely yes, Check the fan by carefully turning it just a liitle by hand, also check for heat at the fan motor base, close to the ceiling. If heat or fan won"t start by hand, replace it.
Jul 25, 2010 | Hampton Bay 24002 Ceiling Fan
Compressor works but compressor fan does not
It is possible the capacitor has gone bad, cause, possibly a power surge. Suggest replacing capacitor first and see if problem happens again then I would change fan motor and capacitor. Good luck on your repairs
Dave
Dec 07, 2009 | Heating & Cooling
Fridge not staying cold, periodically
CHECK FAN OPERATION   MOST OF THE TIME IT IS THE THERMOSTAT
Aug 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
AC fan motor keeps burning out bearings
Hopefully they have replaced the start and run capacitors for these motors and they are rated properly by voltage and microfarad specs. These capacitors properly start the motors during each run cycle and are a vital component to the motors well being and operation. Replace capacitors
Jul 22, 2009 | Heating & Cooling
My whirlpool refrigerator (8 years old) is not cold and hums
hi..Sounds like one of the solenoids is acting up.Solenoids are
electromechanical devices that can be used to turn the water
to the ice maker on/off and also operate the door/screw that
dispenses ice.It could also be a fan or motor that is making
the noise.
check it out..
thank u..
kindly rate my response..
May 14, 2009 | Refrigerators
Amana ptac
you have the white wire on the wrong terminal put it on the same terminal as the red wire on the capacitor and you should be fine,
Dec 27, 2008 | Amana PTH123B25AJ Heat Pump Air...
Electric Cooler 40 problem
blow out the dust around the outside fan and heat sink
Jul 01, 2008 | Coleman Electric Cooler 40 Beverage Cooler
Coleman (100076) Compact Refrigerator Logo
1,112 people viewed this question
Top Coleman Home Experts
john h
Tom Chichester
Are you a Coleman Home Expert? Answer questions, earn points and help others
