Hello. In the "Start Search" box, enter "cmd", press Enter, then enter "Net Start". If that doesn't work, roll back your system to an earlier time when everything worked OK via System Restore. Select: Control Panel- System - Advanced System Settings - System Protection - System Restore. Note that your documents, etc. will roll back to that date as well. Hope this helps.
Open control panel.
Start->controlpanel ->printer and faxes.
Right click on printer then click on property.
Click on advanced
Then enable start print immediately.
Also go to start ->run type "cmd" in run then press enter
Then type in command prompt "net start spooler"
then press enter.
Then check.
If still same issue then change usb cable and also uninstall old driver then reinstall driver.
Let me know if you need further assistance.
Thanks.
in this windows vista home basic ,i see no run at start manue
then press enter.
but see no "run" at my start manue
did it at "run" cmd ,typed net start spooler ,
then got massage .system error 5 has occurred ,access is denied
entered net start ,but got system error 5 has occured access is denied
i have to withdraw problem for the time bieng ,since the owner want to be here when doing further your advise .
for now i got a worse problem my printer is connected fine computer restarted port is fine print offline is unchecked ,still it showes printer offline ,in pending box and in control panel ,how can i change it to online
