There are a couple to possibilities. Either the Evaporator coil is iced over or the fan is not circulating air. All of the cold air comes from the freezer if no air circulates the refigerator will not get cold. check to see if the evap coil is frozen over. If it is deforst it with a hair dryer. for continuity with an ohm meter if it is open replace the heater if not check the defrost thermostat. If it is open replace it. If not replace either the defrost board of the defrost timer depending on which it has. If it is the fan not working check for voltage going to the fan. If you don't have any replace the defrost timer
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
