Whirlpool washer i have just changed the motor to transmission coupling now the motor is difficult to turn upon running the machine the motor over heated and it shut down it ran again after cool down but there is a god awful smell from the motor laboring any suggestions HELP
    President:
  • 1,314 Answers
There are two things i can suggest number 1 pull or inspect the agiator i once had a nail get under one and jammed it im assuming that if you changed the motor coupling and got the case off and on you can pull the agitator with out detailed instructions just pull the detergent cup and go down lol if that's clear then remove the motor again and turn the inner part of the coupling if it doesn't turn freely by hand may have a tranny problem
Posted on Dec 31, 2007
Whirlpool LSR8010PQ0 motor hums and leaks water
Somethnig is wrong with your transmission. Since it is leaking, the seals are broken or damaged. The water leaked in your transmission. The problem with Whirlpool washing machines, the motor is directly coupled with the transmission. There is a high probability that the leaking water corroded the transmission, thereby freezing it. Your best bet is to have the transmission and the water leak fixed. Do not run the washing machine till you have this fixed, otherwise, you face the chance of losing your motor.
Jun 22, 2014 | Whirlpool LSR7333 Top Load Washer
Tip
Washing Machine Motor Coupling Repair
How do you tell if your washer motor coupler has gone bad? Motor couplers are used on "Whirlpool" direct-drive washing machines. In some Whirlpool or Whirlpool-made washing machines, the motor coupler connects the drive motor to the transmission. It operates under extreme conditions and stress. Mostly during start-up and stopping of the motor. The main symptom of a bad motor coupler in the Whirlpool made washing machines is that there is no agitation or spinning action, along with the sound of the motor running. Since the motor is running, but there is no connection to the transmission, the machine will not agitate or spin the clothes out. The motor will simply run, but nothing else happens. In this case, the coupler is most likely cracked. To replace the coupler in the Whirlpool made washer, you must first unplug the washer, remove the top console by either removing the screws or using a putty knife to unsnap the top clips, rotate the console back, pull the washer front off by tilting back,and set the cabinet aside. Remove the clips holding the pump and motor on. Remove the bolts holding the motor on. Inspect the coupler and replace with a coupler if necessary. Re-assemble the motor and pump assembly. Re-assemble the washer in reverse order of disassembly. Plug in and test by running the washer through it's paces.Here is a video on repairing the motor coupler.
on Oct 18, 2011 | Whirlpool Washing Machines
I have top washing machine,will not spin out the clothes.Tub will not spin.You can hear the motor running
You probably need a new coupling. It is the part of the washer that allow the motor to turn the transmission. The part number is 285753A it will cost about $20
Jul 15, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator inside the drum is not moving during wash
Seems to be a common problem with Kenmore and Whirlpool machines. Follow this link to a good explanation of what's going on and how to fix it.
http://fixitnow.com/appliantology/wpdd_dogs.htm
Oct 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Strange noise upon initial start-up
try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
Jun 01, 2009 | Whirlpool LHW0050PQ Front Load Washer
Washer will only wash.
A Clothes Washer with the complaint of "Fills, Agitates, But Does not Drain or Spin" can be:
Defective Door/Lid Switch (Very Common): The lid-switch "that clicking sound you may hear when opening/shutting the door" can become defective after constant "slamming or dropping" or the door. This switch is a relatively simple repair. The lid switch can be located on the inside top of the machine and can be typically removed by (2) screws and un-plugging the electrical from the inside. The lid-switch costs about $15 or so for the part.
Drive-Belt or Coupling (Common) - You may have either a belt or coupling that may connect to the motor, transmission (pulley) and pump (on direct-drive machines). The belt and coupling is the driving force that engages your tub to spin and drain. Typically, upon receiving power from the lid-switch at beginning of rinse cycle, the "drive-train" (motor, transmission and water-pump) is "kick into action". Belt-Drive Machines: The belt is fairly simple to replace and runs about $20 or so. The belts circles and inter-connects with the Transmission Pulley, Motor Pulley or even with the Water Pump Pulley (Metal Cylinder type with belt groove). Direct-Drive Machines: The coupling runs about $10 or so is a little more complicated to repair. The coupling is a total of (3) small - inter-locking plastic components located and attached between the motor (mounted to shaft) and transmission (mounted to shaft) and enables the transmission to spin, upon motor receiving power.
Timer Control - (Very Uncommon)
Jan 28, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultra Care II
I believe this is a similar model to mine, which did the same things. This is a direct drive style (no belt). What possible happened is the coupling in between the motor and transmission has broken partially, and it "grabbing" only under a light load. It's a relatively inexpensive (under $5) part, and can be changed pretty easily.
These couplings can be found on Ebay:
http://cgi.ebay.com/285753-Whirlpool-Washing-Machine-
Motor-Coupling-Coupler_W0QQitemZ170183665420QQihZ007QQcategoryZ20714QQss
PageNameZWDVWQQrdZ1QQcmdZViewItem
If this link doesn't post correctly, just search for "whirlpool coupling". Good luck.
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Washing Machine Top Load LSC9355AN0 agitator frozen
Had the same problem, just hade to replace the agitator.there are teeth on it and it was stripped out.
Nov 13, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
