Question about Sirius Starmate ST2 Satellite Radio Receiver
I have a starmate I think it is a older one and the sound doesnt work
The sound from the line out doesnt work and the fm transmitter doesnt send sound, I looked for a mute button on the radio but there isnt one there is one on the remote but cant find it and I have never used it. any suggestions on what could me wrong thanks
My Sirius Starmate did the same thing last night. Playing with the line out got it to work for about one second.
Posted on Jul 16, 2008
The FM function starts off great but loses reception after a couple of minutes and now the AM function has so much static you can not hear
AM FM TV Reception Guide and Directory ยป FM Reception ...
www.amfmreception.com/fm-radio/fm-reception-guide
Coax is a source of loss of signal from the FM antenna to the FM receiver and can also .... I believe the FM sound quality would strictly be a function of the tuner when ...It picks up the least off the side, but it does pick up some of the side. ...... THE ELECTRONICS so as not to short anything or to start the Great Chicago Fire of ...Missing: video
How to Avoid Distortion in Audio/Video Transmitters ' eBay
www.ebay.com > ... > Audio/Video Transmitters
An audio / video transmitter, or AV transmitter, is a wireless device that sends audioand ... As with all wireless signals, one can experience distortion or signal loss. ... AV signals are usually transmitted via wideband FM (frequency modulation) ... that of indoor transmitters, but the range drops off significantly the moment an ...
Jan 17, 2016 | Audio Players & Recorders
I installed the FM transmitter module which came with my samsung LCD TV model LA40C530F 1R. I tried accessing the FM transmitter menu in order to turn the transmitter On and to set the frequency but that...
1. Press the menu button(green)
2. down arrow once - (a picture of a speaker should appear with sound written vertically next to it)
3. Right arrow once (selects the sound menu)
4. Down arrow till you see FM transmitter (down arrow 4 times on my TV. If you don't see the FM transmitter option in the menu then upgrade your TV to the latest software (details at the end of this help file)
5. Right arrow to get into the FM transmitter menu
6. select the "FM transmitter: off" line and turn it on (FM transmitter : on)
7. Change the frequency to to one that is not used by a radio station or has interference noise (get a radio and tune it till you hear the choosh sound with no beeping or clicking from lightning - then set the tv fm transmitter to that frequency using the up and down arrow keys and enter.
8. You should here your tv sound comming through the radio even if the tv sound is off.
If you need to upgrade your tv software then:
1. format a usb stick
2. download firmware.exe from"
http://www.samsung.com/za/consumer/tv-audio-video/television/lcd-tv/LA32C530F1RXXA/index.idx?pagetype=prd_detail&tab=support
3. click on firmware
4. click on "Upgrade File(USB type)" and download it to your usb stick
5. when the download is complete double click on the file and extract it to the usb stick.
6. eject the usb stick.
7. plug it into your TV and slelect software upgrade when prompted - I didn't loose any settings even though it warns you that you will (samsung are just covering themselves)
Sep 03, 2010 | Televison & Video
Iwave fm stereo transmitter
This is a device that "Sends" FM stereo & Transmitts Radio waves, and sends sounds/music speech etc, over the airwaves to a suitable reciever an the same "Channel" You can hook up say your Ipod to it and say tune your Car radio to the "Station" it sends on and listen to ya compilations, in the car, thru the car stero system. The radio just "Sees" it as another strong station.
Jan 24, 2010 | Pyle PIFMDK6 iPod Car Stereo FM...
No sound when put on 88.3 fm
I didn't think this unit had an included FM transmitter - so I looked around for more info, and everything I've found indicates it does not.
It will however play audio via the built-in speaker or headphone jack. Use of a third party FM transmitter will allow playing audio (navigation, alerts, MP3 or audio books) when connected to the headphone jack and with both the FM transmitter and FM radio set to the same frequency.
The FM transmitter will work best when set to a frequency that is unused and has the least amount of interference from adjacent stations. Check by tuning the car radio across the FM band and note frequencies that have those qualities. Leave the radio on one of the clear frequencies and set the FM transmitter to the same displayed on the radio. You should try several to find the one that works best. Also, be aware that as you travel, you may enter an area where that frequency (or one close by) is in use by a broadcaster. This will require repeating the process as needed to reduce interference.
Oct 16, 2009 | Garmin Nuvi 350 Car GPS Receiver
Sirius starmate 2replay has no sound. how do I go
When you hit the menu button go to FM transmitter and make sure is is turned on, and sellect a frequency
to set it to that is not being used by a radio station, tune you radio to the same frequency. if you are using the audio out on the starmate to plug directly into an aux in on you stereo, there should be a audio level adjustment in the menu as well.
Aug 17, 2009 | Rio SIRIUS Starmate Replay Receiver
Everything works fine on the unit no problem until
3. If your Nuvi has a FM transmitter, is it selected to "FM" or "Speaker"? The "FM" setting will mute the internal speaker. Setting it to "Speaker" will send sound to the speaker.
if this side of it works then the FM transmitter is faulty
Check that the sound has not been MUTED
plug the earphone into the socket to see if any sound is heard. The socket is also a switch that takes sound from internal speaker to ephone and reverse.
If no sound is hear in either FM or normal mode your unit is faulty and needs repair
Jul 24, 2009 | Garmin nuvi 250W GPS Receiver
Are starmate 2 radios able to be wireless
as long as the used one is not actually a refurbished on.e The original ST2 has a stronger modualtor, so transmits very well. This modulator has since been ruled in violation of FCC regs, but unless there is an FCC cop, you should still be ok.
Jan 01, 2009 | Sirius Starmate ST2 Satellite Radio...
How to set up fm transmitter for sanyo gps nvn-4370
At the main menu press settings
press FM Transmitter
Turn transmitter on by pressing off. Will change to On
Press the Frequency button. Than change the frequency to one that doesnt have a radio station.
All sounds from the GPS will now be transmitted to the frequency set. Make sure your FM radio is set to the same frequency.
With my one vehicle this option does not work very well & is full of static because my radio entenna is at the rear of the car. The GPS only transmits a couple of feet.
Dec 27, 2008 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
GARMIN NUVI 350
HI Heather,
Make sure you don't have the sound muted. Have you tried plugging in a set of headphones into the headphone jack? If you can hear sound with the headphones, most likely, the internal speakers have failed. If you still can't hear any sound, the audio output stage on the motherboard has failed. In either case, you will need to send the unit back for repair. Be sure to have your serial number handy. Register it online https://my.garmin.com/mygarmin/marketing/register.htm
if you haven't already done so.
Hours:
Monday - Friday
8 a.m. - 7 p.m.
Central time (closed holidays)
1-800-800-1020 (U.S.)
1-866-429-9296 (Canada) or (913) 397-8200
More Info: If you can hear sound through the speakers and don't want to send the unit back for repair, you can buy a FM transmitter at Best Buy - the kind that will allow you to play a portable CD player through your car stereo. Just plug the transmitter's audio input cable into your GPS headphone jack, power the transmitter with your car lighter jack, set the transmitter frequency to a unsued FM channel and tune your car stereo to tha same channel. You should hear your GPS through your FM stereo.
Good Luck,
- Jim
May 15, 2008 | Garmin Nuvi 660 GPS Receiver
Sirius Starmate ST2 Satellite Radio Receiver Logo
200 people viewed this question
Top Sirius Audio Players & Recorders Experts
Steve
Oloyede Monsuru
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
