Home | Nikon | D80 Digital Camera with 18-135mm Lens | When taking indoor pho...
Nikon D80 Digital Camera with 18-135mm Lens
Problem for Nikon D80 Digital Camera with 18-135mm Lens
When taking indoor photos, sometimes i get shadows
By wldcard56 on Oct 25, 2009
when taking indoor photos, sometimes i get shadows on different placesof the photo
Comments:
Oct 26, 2009
- yes
Clarification Request
Posted by joustcom on Oct 25, 2009
Does this happen when you are using the flash?
Best Solution
posted on Oct 31, 2009
Very Helpful)
steve_con
Rank: Guru
Rating: 91%, 90 votes
If you're getting shadows on the bottom center of indoor photos when take with a flash, it is most probably due to the length of the lens on the camera.
A long, telephoto / zoom lenses will create the largest amount of shadow, while shorter and wide angle lenses will be least likely cast shadows. You can reduce the amount of shadow in pictures by removing the lens hood that may be on the end of the lens. The lens hood is to primarily to shield the lens from direct (sun) light, and probably isn't needed for indoor flash photography. Also, rely less on the zoom function of the lens on the camera and physically moving closer to your subject instead. The flash will need to provide much less light output and result in more flashes per battery.
You could use a separate flash - held off the camera so that the lens is not obstructing the light of the on camera flash. Using a Nikon Speed Light, you can set the on camera flash to provide a low output, that would be used primarily to trigger a Nikon Speed Light held by someone or arranged on another surface etc. Youtube is a great source for real life, practical "How To" videos for many operations of the camera and accessories.
I hope this was helpful!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Nikon D80 Digital Camera with
Questions and Unsolved Problems for Nikon D80 Digital Camera with
Do you recommend Nikon D80 Digital Camera with 18-135mm Lens?
Answer
Answer
When pressing the shutter release button two different event occur: 1. either the battery shows... (More)
Answer
I just got my new Nikon D80 but cannot get the LCD screen to light up. Where do I find the setting... (More)
Answer
I get a fEE on my control panel after adding a 28-85 lens in addition there is a bell sound that... (More)
Answer
My D80 doesn't read the F anymore. I don't know if the problem is on a lens or on the camera. I... (More)
Answer
the flash no longer goes off automatically, the unit clicks but the flash doesnt come up? what is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nikon D80 Digital Camera with...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
