Question about Microsoft Windows XP Professional for PC
Window xp while opening hard drive i get message application can not be run in win mode
  • 31 Answers
The problem may be due to curruption of the system file.
One of the solution is :- Go to Start > Run and type 'sfc /scannow' (without the quotes). This will run the System File Checker that will replace any damaged or corrupted system files.
If it is not solved yet, try with a updated antivirus for a trojan or spyware.
Posted on Jan 01, 2008
My old computer with a Borland dBase 5.0 program on it crashed but the hard drive was salvaged and I have hooked it up to my new computer. However, my old computer ran Windows XP on 32 bit, the new one...
Do I need Windows XP Mode?
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs many older Windows XP productivity programs and that are not natively compatible with Windows 7, thus helping realize cost savings and reduce possible operational downtime by extending the life of existing software. Visit the Windows 7 Compatibility Center to find software that works with Windows 7.
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
It's the best of both worlds: The new Windows XP Mode lets you run older Windows XP business software right on your Windows 7 desktop.
Designed primarily with small- and medium-sized businesses in mind, Windows XP Mode comes as a separate download and works only with Windows 7 Professional, Ultimate, and Enterprise. Windows XP Mode also requires virtualization software such as Windows Virtual PC. Both are available free on the Microsoft website.
Download
Learn how
Jan 23, 2011 | Borland DBASE 5.0 Upgrade Version Academic...
When Windows XP tries to load, I get the following message: "We apologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might have caused this." My...
indicates that the hard drive is starting to fail
save everything to an external hard drive
have the system tested by an computer repair shop and if faulty install a solid state hard drive that has no spinning disc
also up grade to win 7 operating system as win xp is no longer supported by Microsoft and many other products are not compatible with win xp
Aug 10, 2017 | MSI Wind U100-423ES Notebook
Computer won't start; hard drive failure?
What version of Windows is that?
There are: Win XP Home, XP Media center, XP Professional... First time i hear 2002.
Best think for you to do is to backup your files and reformat your drive.
Because you can't access Windows safely, you should take your hdd to another PC.
I suspect on : MS Windows bug or hard drive error.
Jan 28, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
When i try to run an app i get the message not a
1. It's the main problem with Vista! It don't support applications / softwares which are 16-bit (Only 32-bit applications are supported!).
2. It hardly support any application older than Windows XP (which runs on Windows 95/98/NT/Me)!
3. Try to download the updated version of your applications from internet which are Windows Vista compatible.
4. Then install these updated versions.
tell me if it don't works...tc! :)
Jan 06, 2010 | Toshiba Satellite A305-S6859 Notebook
How can i desable sata hard drive in laptop for installing win XP
in the BIOS you should change the following option
sata native mode should be disable.
Feb 02, 2009 | HP Pavilion dv2000t Notebook
I have a hard drive with windows 95 and i am trying to install windows xp professional addition but it comes back saying you can't intall this version of windows on this system
Windows 95 uses the FAT 32 system and uses a boot-up partition that will not recognize a windows xp default system install that uses the NTFS system. You can do it the other way around though, if XP is installed first, or another drive you have with XP on it is the first drive set to boot in your BIOS XP will recognize WIN 95 on its FAT 32 partition and either let you boot from that partition when you first start up your computer or when in XP right clicking a WIN 95 application and setting its properties to run as a Win 95 environment. Solution I would use if I were you would be to download Microsoft's free Virtual PC application from their website and run a full version of WIN 95 in its own virtual environment. Win 95 will run about 10 times faster than it ever would on its own partion if run under XP.
Aug 26, 2008 | Computers & Internet
Error: "The application cannot be run in win32 mode"
Open my system, click mycomputer and then opening only c drive, but D,E,F drives are not opening, if telling application cannot be run in win32 mode ( how can i solve the problems.)
Jan 07, 2008 | Microsoft Windows XP Professional for PC
PC is frozen when I press WIN-key
Do you see the Hard Disk Light ON during the time your computer is frozen? If that is the case there maybe an issue with the Hard Disk Controller.
When you installed a new version of Windows XP, did you format your entire Hard disk? (Just to make sure that your computer doesn't have a viral infection?)
Also, is it that the computer freezes when you press Alt+Enter ...or is it like the computer freezes after you press the Windows Key and then Alt+Enter?
Have you tried the Alt+Tab Combination?
Oct 16, 2007 | Compaq Evo D500 PC Desktop
Microsoft Windows XP Professional for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
