Spin cycle The spin cycle is WAY TOO POWERFUL! It's like a jet airplane that's taking off. It has been leveled already but it still shimmy's right out the door! I have even put it on LOW spin cycle and it still does the same thing. It's like it has TOO much power.
  • stephnscott Dec 31, 2007
    We have ran it with just water and the spin cycle is still very powerful. Is there a way to adjust the speed of the spin cycle? We have leveled it as well, it sits very sturdy with no wobbling at all. When it goes through spin cycle it is so powerful that I stand there with my eyes as large a saucers because it sounds as if it's going to take off!
You have a mechanical issue that will likely require a service person. It is not 'powerful'...it is a shake caused by some kind of imbalance or broken off item.
Posted on Dec 31, 2007
  • 833 Answers
This is usually a balance issue. Try to use the machine with only water in it...no clothing and see if you get the same result. If so, the problem is in the machine...not...you're not loading the clothing evenly or putting in too much.
Loud noise during spin cycle
Yes unfortunately. but it's not terribly difficult to do. There are many how-to videos online
Mar 16, 2015 | Maytag Bravos MTW6600T Top Load Washer
Whirlpool washer WTW6400SW very loud spin cycle, sounds like airplane taking off
Most likely it is the spin tube bearing worn. Reguires some know how and special tools. Requires a major dismantle of the machine and usally I did these repairs in the shop. Bearing will eventually sieze over use and time. Labor will probably exceed the value of the machine.
Jul 06, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Shimmy really bad during spin cycles what can i do
hi rick. Check the level of your machine front to back and left to right. Level it if necessary. If the shimmy is still bad, your machine's shock absorbers may have to be replaced. If it has always had a bad shimmy cut a piece of heavy carpet and place it under the machine. Joe
Jan 17, 2011 | Washing Machines
When the machine gets to the spin cycle, it beeps....
When it beeps it will be showing an odd sequence of lights across the top row.take note of these as they will be a fault code.now il tell you how to interpret them.128.64.32.16.8.4.2.1 you need to add together the lights that are on only.that will be your fault code.
Be careful.your pump may be on it's way out & if you keep trying to get the machine to drain the water you could damage the main board with the bad pump. code 37 is pump.
May 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
Maytag Epic front load washer spin cycle sounds like an airplane is taking off
If you mean a jet aircraft, that is normal. Front loaders achieve amazing spin rates.
Feb 14, 2010 | Maytag MAH2400A Front Load Washer
Unit shimmy's across floor
Remove the two support bars from below the washer drum from the front as instructed in the installation manual
Jan 18, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Roars when spin cycle
You are right it is the bearing also called a tripple lip seal and there are special tool to do that job if it has a metal outer tub I would not repair it. If it has a plastic outer tub the repair will fix it
Mar 29, 2009 | Maytag HAV4657 Top Load Washer
Washer is extremely loud
defective back bearing and spin basket..onthejob
Feb 03, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Sounds like an airplane taking off!
check your drive block under your agitator if metal shavings replace
Nov 08, 2008 | Kenmore 22422 Top Load Washer
Loud noise on spin cycle
How did that answer get an 83% rating? It is absolutely useless. My washer has the exact same problem as described above.During the spin cycle it sounds like a jet engine. It kinda sounds like the belt hitting the drive wheel but may be bearings in the motor.
May 03, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
