Question about HP Photosmart C5180 All-In-One InkJet Printer
Paper jam Fix paper jam
  • 1 more comment
  • Anonymous Mar 12, 2008
    A paper jam.  I have cleared the paper that I can see, but there is still paper there that I can't get out.  Is there a lever I can lift to release it or what?
  • lima1990 Aug 21, 2008
    I cleared the paper jam, but the computer still won't print anything. It is stating there is still a paper jam. I scanned and printed a document without any problems.
  • Anonymous Aug 26, 2008
    I have a paper jam and I don't know how to fix it. So how do I fix it?
    Sniper:
  • 95 Answers
I have removed all paper , disconented USB and electric connection, cleaned rollers etc. Paper will still not come through from carriage to output tray
Posted on Jun 10, 2008
Canon 3010 problem jam indecate
If the error indicator light is lit, then the Canon printer is jammed. To fix a paper jam you must remove the paper tray, disconnect the AC power adapter, wait 5 seconds, then plug the printer back in. If the jammed paper does not automatically eject, carefully remove the paper manually. To help prevent further jamming, fan the paper in the paper tray to prevent the paper sticking together.
Great people delivering a superior customer experience. Canon Printer offers a complete line of printers, scanners, all-in-one office machines and paper jammed problem. Facing the problem with Bother printer, Scanners, Call our technical expert and get quick help. Dial Canon Printer tech Support Phone Number (18777788969) and fix your problem. For more information visit us: http://printertechnicalhelp.com/Canon-printer-technicalhelp.html
Sep 02, 2016 | Canon Office Equipment & Supplies
Tip
How do I fix and avoid paper jam error issues in a Dell printer?
Fix and avoid paper jam error issues in a Dell printer-
Paper jam is one of the most common issues among all brands printers. Dell printers also show such issues and you will be indicated this error by the light or beep noise when a paper stuck inside. To avoid such issues on your Dell printer or fix the paper jam problem read here the useful tips that would be helpful to utilize Dell printing service with better efficiency.
Watch this video and fix paper jam issues in your dell printer: https://youtu.be/4nGBQ0H1RQw
on Feb 13, 2018 | Dell A940 All-In-One InkJet Printer
Tip
How to Fix a Paper Jam in a Copy Machine
It seems inevitable that the copy machine will have a paper jam. You need the copies immediately, so how do you fix the jam? Luckily, ingenuity and a manual, can help you fix the problem yourself. Fixing a paper jam, can elevate you to hero status amongst your co-workers.
  1. Discover the location of the jam. Carefully open the cover of the copy machine and the paper tray to see exactly where the paper is jammed.
  2. Step 2 Turn off the copy machine before pulling out the paper.
  3. Step 3 Pull the page out, the opposite way it is fed into the copier. Pull the jammed sheet out gently. If you tug too hard, the paper may rip.
  4. Step 4 Check for any paper fragments and clean up any torn pieces.
  5. Step 5 Check the roller where the jam occurred to be sure none of the copier parts are loose or broken. The roller should be smooth all the way across with no possible snags.
  6. Step 6 Replace the cover and paper tray and turn the machine back on.
  7. Step 7 Press the button to cancel the paper jam message. This button will vary among copy machines. The display will tell you which button to push.
on Jul 14, 2010 | Office Equipment & Supplies
Fix paper feeder that keeps jamming. How to clear jam and fix on-going jamming problem
What thickness of paper are you using? Also is the paper new/fresh or are you re-using paper that has gone through the printer already?
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
Epson rx585 paper jam message but no paper jammed.. how can i fix it?? tried switching it off unplugging etc and its still the same..
The micro-switch that detects a paper-jam is still detecting a paper-jam.
Either there is paper-dust in the switch, causing the "false-positive" indication,
or the micro-switch is broken, or there really is a paper-jam that you have not detected.
Check the micro-switch, and look again for a paper-jam.
Aug 18, 2011 | Office Equipment & Supplies
CONTINUING PAPER JAM. I OPEN DOOR, CLEAR THE JAM, AND PAPER STARTS TO FEED, THEN AGAIN ANOTHER PAPER JAM, AM I USING WRONG PAPER?
I know the problem, Its the Exit paper sensor! if u make a short circuit on the pin 2 and 3 of the CN2 when the paper reaches the sensor it wont jam. Chainging the sensor resolves the continous paper jam or try to clean it!
Apr 08, 2009 | Samsung CLP 315 Laser Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Paper jam check drawer two t640 printer
Hello there,
If you are getting "Paper Jam check drawer two message" I would suggest you to check for any paper stuck inside the paper drawer two. If you don't see any paper jammed inside drawer two, you might also want to check out if its is stuck anywhere in the paper path. Removing the paper jam should fix the issue. Try cleaning the pick rollers (the rollers which pick the paper) in drawer two. This should help fixing this issue.
Merry Christmas!
Aug 20, 2008 | Lexmark T640 Laser Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
495 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
