Question about iLO (2 GB) MP3 Player
No device detected
I have a brand new (2) Mp3 player and no device detected windows media player etc
  • 8,596 Answers
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 05, 2008
Hi, my pc don't read the mp34 audio player =( help!!!
Why is my mp3 and mp4 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see mp3 and mp4 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the mp3 and mp4 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: mp3 and mp4 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 and mp4 Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for mp3 and mp4 Players when used with Windows OS.
The mp3 and mp4 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
May 05, 2011 | Digital Audio NAP256 MP3 Player
Windows media player does not reconise that my mp3 player is pluged in
go to device manager and scan for new devices.....this should solve the problem......
Jan 21, 2008 | Audio Players & Recorders
When i installed the media player into my computer. i get a little screen saying usb device not recognized. one of usb devices attachedto this computer has malfunction,and windows does not recognize it....
Hi, smpk4083 mp3 player not recognized by the computer
Why is my smpk4083 mp3 player not being detected by my computer when I connect it?
4. Power issue.
- Run the hotfix.
For MAC users, see smpk4083 mp3 player not recognized by a MAC OS
STEP 1 - Connect the smpk4083 mp3 player to the PC
NOTE: smpk4083 mp3 Players can connect to your computer in MSC or MTP mode. Exceptions are smpk4083 mp3 player Connect and smpk4083 mp3 Express which only use MTP mode. MTP mode is the recommended and default method for smpk4083 mp3 Players when used with Windows OS.
The smpk4083 mp3 player will show up on Device Manager's right pane as:
Hope it helped.
Have a nice day,.
Feb 22, 2011 | Sylvania Audio Players & Recorders
My sandisk is not detected
This may be caused by one of the following: 1. Minimum system requirements were not met. 2. Corrupted drivers. 3. Computer restrictions. 4. Power issue.
Try the following solutions:
For brand new player or first time connecting to a computer.
If you are using XP : verify the following operating system requirements are met. - Windows XP SP2 or higher - Windows Media Player 10 or higher
If you are using Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. - Download the hotfix from
--->> http://support.microsoft.com/kb/939211. <<----- - Run the hotfix. Solve your MP3 Player Connection Problem.
Mar 16, 2010 | SanDisk Sansa Clip MP3 Player
Windows media player says no device connected
Windows Media Player has a limit of 3 portable devices that can be detected at any one time. I would uninstall every mp3 player's software that is installed on that machine and try again.
Dec 14, 2008 | Audio Players & Recorders
Computer Won't Let Me Access the Device
hey there!
please do the following one by one
unplug the power cable going into the power supply. wait for a while and plug it back
install software with updated drivers. check to make sure you have the most recent motherboard drivers.download if necessary.plenty of sites available
update your windows media player
get Windows XP Service Pack 1 or Service Pack 2 if possible
goto Start Menu->Control Panel->System and then clicking the Hardware tab and going to Device Manager. in Device Manager you could delete all entries with "USB" in the name and reboot. let Windows redetect the USB devices.
uninstall your usb drivers and download the latest ones available and reinstall your usb drivers.
Dec 05, 2008 | Apple iPod nano
RCA TH1602 MP3 Player in locked
You should be able to force the Pearl into recovery mode by removing the battery, then hold down the "Play" button while inserting into USB port, after a few seconds, Windows should detect "USB Human Interface Device" (see Device Manager). Now you should be able run the firmware update. Worked for mine after it froze up one day and would not be detected as a USB device by Windows.
Nov 14, 2008 | RCA TH1602 MP3 Player
WINDOWS MEDIA PLAYER WONT DETECT DEVICE
i had a similar problem (would not load driver) and was able to solve with the following: 1. install version 10 or greater of windows media player. 2. in Device Manager (hardware tab on System in Control Panel) right click the ? Samsung YP-T7J and pick update driver 3. Select No, not this time, Next> 4. Install from a list...., Next> 5. Don't search, I will choose.., Next> 6. Select Portable Devices, Next> 7. Select MTP Device, Next> 8. The drivers are copied and the device is recognized. There are other prompts depending on your media player config, but only pertains to how the device is handled. jlw.
Dec 19, 2006 | Samsung Yepp YP-T7JX MP3 Player
Sync with windows media player
I have the same issue where my pc won't recognise my mp3, or only occassionally does, and then locks up. The problem with media player is it eats up so much memory while trying to synch files / delete / add etc and brings your pc to a grinding halt. So the solution I'm told is the MS Synch Tool, download off MS site and use it rather than the player to switch your files. I'm trying it now.
Dec 09, 2006 | Samsung Yepp YP-Z5QB MP3 Player
iLO (2 GB) MP3 Player Logo
23 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Jon Piercy
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
