Dishwashers
Generic problem for all Dishwashers
Dishwasher problem
posted by skagit17 on Dec 31, 2007
Our Asko 1353 dishwasher stops halfway through its's wash cycle. I suspected the thermostat, as it seemed loose in it's holder and not tight against the tub. After I tightened the holder the problem is still the same. Also, the on/off switch (pressure switch?) does not stay in the on position and when I looked it over I found one of the crimp on terminals had melted. Short circuit? Too much resistance from bad thermostat? How do I check the thermostat before I order a new one?
Thanks, RG
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Dec 31, 2007
Not Rated (0)
bigg t
Rank:Guru Guru
Rating: 85%, 389 votes
i think your switch may just be bad,but to check the t-stat remove both wires and use a multimeter,set the meter to ohms and connect the two leads to the terminals on the t-stat.with the t-stat to off you should read an (ol) open condition,when you turn the dial on the t-stat you should get a reading of continuity.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Dishwasher problem:
I don't want to Accept this solution
Can you Help with these Dishwashers problems?
Kenmore 24 in. 15932 Built-in Dishwasher
We have a Kenmore Ultrawash model 16912001, the dishes are...
Dishwashers
We recently "inherited" a GE Automatic Grill and...
Bosch 24 in. SHU53 Built-in Dishwasher
My SHU5314UC/u11 will only work in the power scrub plus...
Maytag 24 in. MDB8600AW Jetclean II...
Just installed a dishwasher and water leaks out under the...
Dishwashers
E-mail address is jchesher@xit.net I put a new on/off...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Repair Service
Find Dishwasher Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
