Question about Toshiba 52HM95 52" HDTV Projection Television
Permanent white spot
I own a Toshiba 52HM95 dlp tv that now has a permanent white spot about the size of the lead in a lead pencil. What causes this problem and what parts would need to be bought to fix this issue?
I have a 65HM167 with permant white spots and they getting more everyday. what is the fix?
Posted on Sep 09, 2012
    President:
  • 4,402 Answers
can see it in certain lighting and even when the TV is off! It will appear lighter than the surrounding areas at times and can be annoying. I called Toshiba and had a service man come out and even though he acknowledged that this is common, Toshiba will not replace the screen.
Posted on Feb 11, 2008
Where are toshiba dlp 62hm95 fuses
I looked at the power board online and I do not see any glass fuses.
I only saw the pico fuses which you unsolder and resolder.
Here's an image of the power board: http://tvpartsandmore.com/wp-content/uploads/imported/46HM95-TOSHIBA-23764257-POWER-SUPPLY-UNIT-46HM95-52HM95-62HM15A-62HM95-62HMX95-191208846050.jpg
What is the problem with this TV?
www.aaatvservice.com
Aug 15, 2014 | Toshiba 62HM95 62" DLP HDTV
How to fix my 65" toshiba white pixel problem
Thats caused by the DLP chip. Unfortunately most Toshiba models will end up having to have both the DLP chip and the formatter board replaced at the same time to fix the issue where as other models only require replacing the DLP chip alone to fix the white dots issue
Apr 06, 2013 | Toshiba 65HM167 65" Projection Television
White spots
Replace the DLP chip at cost between $160-$300 for the part and about two hours of your own time to do it.
http://www.shopjimmy.com/samsung-mitsubishi-toshiba-4719-001997-dlp-chip.htm/
Jan 24, 2012 | Mitsubishi WD-65C9 65" DLP HDTV
Toshiba 52hm95 will not come on , red light blinks
It is the Light assembly engine. Happened to me It is $700 to fix and the wanartee on the new part is 3 mos
Aug 13, 2009 | Toshiba 52HM95 52" HDTV Projection...
I have a toshiba 52hm95 DLP tv and i am trying to get the souund to run through my tuner. i attached the digital audio out on the tv to the "digital audio in" in my tuner and i am not getting any sound....
More than likely you need to set the tuner up for this. On your DUI "Digital User Interface" you will need to go into the digital in assignment and select the digital input, you should have the option's of, coax, optical or analog. Select COAX and you should get sound.
Jun 23, 2009 | Toshiba 52HM95 52" HDTV Projection...
Numerous white spots on Smasung DLP TV
same problem for me ... check out this thread on AVSforums about it.
I have the same exact tv as you and had the same problem. I took it to a repair shop who told me I needed a new DMD chip and that it would be 850 to fix. I used the information in thread above to get the part number and bought the chip on ebay for under 200. Here is a link to the listing CHIP
People have had good success. I will be replacing mine tomorrow.
Feb 26, 2009 | Samsung HLS4676S Television
Toshiba 52hm95 DLP HDTV - no sound
What cables are you using? Some TV's and DVD players have options to set your audio source. My DVP5982 I have to set it to HDMI digital audio, check to see if you have that on your TV.
Jul 04, 2008 | Toshiba 52HM95 52" HDTV Projection...
Bright spot on my 52hm95
Feb 11, 2008 | Toshiba 52HM95 52" HDTV Projection...
Toshiba 52HM95 52" HDTV Projection Television Logo
174 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
