Question about Magic Chef CTB1722 Top Freezer Refrigerator
Fridge does not get cold enough
Hi. I have a Magic Chef model no. CTB1925GRB and the refrigerator runs, but does not get cold. The doors do seal well. Not sure if I need to cleans coils or replace a part.
Thanks for you help.
  • boomsooner4 Dec 31, 2007
    I checked what you suggested. However, there was not frost on the evaporator nor was there any clogs that would bother the airflow.
    I do hear a click every few minutes. It is almost like the system wants to come on, but cannot. Perhaps this is the problem.
    President:
  • 1,314 Answers
First the freezer does all the cooling there are air vents in top of the refrigerator that the evaporator fan draws air through then blows it down to cool the fridge in the fridge section you should see an air vent if you don't have a defrost problem then you have an air flow problem first do you hear the fan running if you see heavy frost on the back wall of the freezer wall where the fan is then you have a defrost problem and that's a different repair but if you don't then remove the four screws and pull the panel carefully as the fan is there see if there is heavy frost on the evaporator a large aluminum honey comb so much that air cannot come through it under that part will be an a tray with around hole in it make sure that's is not frozen and the drain hole is open then check that the square hole that goes down to the fridge is clear and check the two square styrofoam intake blocks are clea you an pull them out gently and see if its iced up under there after you check that reply to me on any fault
Posted on Dec 31, 2007
WHATs the equivalent of a door gasket for this magic chef refrig?
get the right one from the spares deaprtment of the service shop
There are people like "Door Seal" or fridge seal replacers who can make a seal on site to fit the door
May 12, 2015 | Magic Chef Refrigerators
MCBR1020W is the model number for the refrigerator in my apartment. The refrigerator fresh food unit is not getting cold enough to keep food cold, this results in food spoiling. What could be causing this...
You could have the lack of air flow or a door seal problem. Could you check the freezer for me, look for frost on the back wall. If not frost, is the fan running in the freezer?
Please get back to me
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sep 08, 2011 | Magic Chef Refrigerators
Freezer getting too cold. Refrigerator not cold enough
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 26, 2011 | Magic Chef Refrigerators
THE FREEZER WORKS BUT THE FRIDGE PART DOESN'T. IT'S THE SMALLEST SIZE 2 DOOR FROST FREE MAGIC CHEF FRIDGE. ABOUT A YEAR AND A HALF OLD. WHAT SHOULD I DO?
heatman101
Dec 16, 2010 | Magic Chef Refrigerators
My Magic Chef mini fridge temperature trouble
That can be very difficult to do with a mini refrigerator. There is just not enough separation between the freezer and the refrigerator.
You will likely just have to find a compromise setting and accept the results.
Oct 20, 2009 | Refrigerators
Bottom of refrigerator not getting cold enough, freezer is working fine, - Magic Chef -model MCBR1000w
have you cleaned out the coils underneath the fridge? it's very simple. pull the fridge out, look underneath(try pulling off the bottom grill from the front for more access), and start cleaning. to much dust and lint will hinder the coils from cooling. A vacuum with the brush attachment or little broom works good.
Jul 27, 2009 | Magic Chef Refrigerators
Need a defrost cycle i think
lots of frost may mean lots of moisture, check the door seals to make sure they are in good condition and sealing well. In high humidity climates interior frost is more of an issue too. If the seals are making good contact and not broken or split it could be a defrost timer or defrost thermostat malfunction. try to catch the fridge defrosting and ensure that the drain pan has water coming into it, a clogged drain will slowly but surely make a fridge ice up.
May 26, 2009 | Magic Chef Refrigerators
Does not get cold enough.
HI THANKS FOR YOUR QUESTION.tHE FIRST THING TO LOOK AT IS . iF YOU HAVE FROST BUILD UP ON THE WALL, OF FREEZER.#2. IS THE FAN RUNNING. #3. CLEAN ALL COILS AT THE BACK, OF FRIDGE, VERY IMPORTANT . tHANKS THE APPLIANCE DOC.
Oct 04, 2008 | Magic Chef Refrigerators
Refridgerator/Freezer will not get cold
Check to see if the refrigerator is clean at the condensor at the bottom or at the top of the unit. All fans running inside and outside the unit? Door gaskets sealing tightly. Put a dollar bill between the door gasket and cabinet and clost the door. Slight drag ok. No rsistane, bad gasket. No solution at this point, call for service.
May 04, 2008 | Magic Chef CTF2125 Top Freezer...
Magic Chef CTB1722 Top Freezer Refrigerator Logo
444 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
