Question about Mitsubishi MS12TN Air Conditioner
Direction of vane changes
No matter where you set the vane in a short while it changes to a position where the air flow is straight out. This happens continuosly. Now the vane does not respond to the remote control when you try to reposition it. This happens on both heat and cool cycles.
  • 236 Answers
Push the reset button of your remote control and try. If it wont work try to "off" and "on" the circuit breaker to reset the unit and try the remote control.
Posted on Jan 01, 2008
  • Felizardo Erilla
    Felizardo Erilla Jan 03, 2008
    PLEASE OBSERVE THIS IN OPERATING YOUR UNIT
    -When the air conditioner is operated in COOL
    or DRY mode, if the operation continues with air
    blowing down for 1 hour, the direction of the air
    flow is automatically set to horizontal to prevent
    condensed water from dropping.
    • In the heating operation, if the air flow temperature
    is too low or when defrosting is being done,
    the horizontal vane position is automatically set
    to horizontal.
  • Anonymous Oct 27, 2017
    Still have this problem in 2017. 100% useless feature. Mitsubishi never fixed this problem after seven years....
Ok had a question the other day about my 09navarra loss of power and blowing smoke it's like the turbo is not kicking in but I kno it works cause it worked in revers the other day getting over the cu
turbos on this vehicle have a variable vane setting activated by an actuator that is vacuum controlled by the ECM. At low rpms the vanes move to direct more exhaust gas onto the turbine wheel thus producing boost at low engine rpms. You will get boost at high rpms because if the vanes aren't moving then that will be the position they are set at. Check that the vane rod is moving, check that the vacuum hose is not leaking,cracked or loose and check that the actuator is doing the job.
Dec 21, 2014 | 2007 Nissan Navara 4.0
3/4inch air racheat air flows straight through in forward and reserve........
I'll bet your really talking about a 3/8 air ratchet, as 3/4 are used for sockets larger than 1 1/4 inch and are rated for more than 750 Ft= Lbs. of touque. The air rachet can be fixed by unscrewing the ractchet head from the motor barrell, inside the motor barell theres a rotor with air vanes in slots of the barrel. You'll find the vanes are stuck in the barrell as you haven't oiled the gun regularly enought, remove the vanes and clean them by rubbing them with air tool oil and slipping them into the slots they fit into. If they fal out you have them clean enough if their bent they will have to be replaced, clean the other parts by wiping them off with air tool oil till everything appears to be as clean as new screw it back togther and it'll work great.
Feb 25, 2011 | Garden
CK ENGINE CODE 1159
this code is for a pronblem in the intake manifold runner control system.
KIA use (as do many other manufacturers) the variable intake on their V6 engines.
It is a bosch developed idea that has an actuator which turns a vane inside the manifold creating either short runners or long runners for the air to flow into the head. The long runners help torque and HP at High rpms whereas the short runners help at lower rpms. The computer positions the vane by a stepper motor to the required position.
The actuator is underneath on one end of the manifold plenum chamber, you may need to clean or replace that item.
Jan 15, 2010 | 2005 Kia Sedona
Engine runs away
there is a plastic vane that moves in response to the air flow created by the flywheel fan ... the faster the motor runs the more air and the more the vane is deflected .. the vane is connected to the throttle thru a spring .. as the vane is deflected it reduces the throttle setting to maintain a set speed (which is adjustable by a screw) ... if that vane becomes stuck by a leaf or twig then you lose that speed control .. also if it becomes disconnected from the throttle the engine will run away .. the manual on your generator will call that a "govener "
Dec 23, 2009 | Coleman Powermate Premium Plus 6250W...
Engine starts easily, but runs flat out, no matter what the throttle setting is. Ignition cut out still operates correctly.
I am not sure what type or how old your mower is but most have whats called an "air vane governor". This system uses air flow and a spring to control a vane back and forth. One problem is debris sometimes collects in the system blocking air flow. When this happens the engine will over speed. The other is if the spring breaks or detaches from the governor.
You should avoid running the mower at all until you are sure you have found and fixed the problem. Over running can quickly cause catastrophic damage to the engine.
Inspect the governor and make sure it's moving freely and that there is no blockages in regards to the air flow. If you find that the governor is not moving freely you can attempt to control it manually when the engine is started but only after you have positively identified the governor as the problem.
If you are unsure where the governor is located please respond back with the make and model of your mower.
Hope this helps.
Dec 04, 2009 | Garden
My driver side ac blows cold, passenger side blows warm. whats the problem? 2004 ram 1500 reg cab.
A shutter is out of position, May be able to adjust under passenger dash. Move the controls to spot your target and then sync the contrpol with the shutter position, Good Luc,Ned
Sep 25, 2009 | 2005 Dodge Ram 1500
HVAC vent selector does not function. Air flow is
THe blend door seems to be stuck. When you change settings from defrost to floor air or, vent, the blend door opens and closes directing the air to the place you want it to go to. I have had some success spraying a lubricating oil such as WD40 under the dash on the blend door. You need to get under the dash with a flashlight to locate it. It looks like a flap. Spray it with a couple of shots of the WD40. Go easy on the spraying as you may be inhaling the fumes. Keep the doors and windows open to minimize the fumes. Wait about 1/2 hour and try the A/C functions. (defrost, floor, vent air)
Mar 09, 2009 | 2002 Buick Rendezvous
1986 VW Golf heater blows cold air
The heater in your car depends upon a flow of hot coolant going through the heater core in order to get hot air into the car. If the heater core is partially plugged, it will restrict the flow. If you have a head gasket that is putting exhaust into the cooling system, it will eventually get into the heater core. When this happens there is no coolant in the heater core to make the air warm. If the water pump vanes have corroded away the result will be very poor coolant circulation causing the heater to not blow hot air. If your car is equipped with a heater control valve that is not functioning properly, the coolant flow will be restricted. One or a combination of these factors is likely the culprit in your case.
if the car is not overheating, the thermostat is working fine.... replace or flush the heater core multiple times to try and eliminate sediment build-up.
Jan 14, 2009 | 1986 Volkswagen Golf
Vane control on Mr. Slim Remote
Pls put the vane on the position 2 and then manually turn the vanes to desired position it will not move until the time you turn the power off and you can enjoy the benefits of Mr slim....
Jul 30, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Air coming out the vents
The flow direction is accomplished with vanes that are dependent on engine vacuum to operate. You may have a hose off or cracked so the vanes are not answering to the settings you choose.
Jul 18, 2008 | 1997 Jeep Cherokee Country
Mitsubishi MS12TN Air Conditioner Logo
553 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
