Question about Intel Motherboard
Problem software not support motherboard
Hi i have a machine motherboard is intel 850 processer 2.0 with window2000 os on which machine software installed. motherboard is faulty now didnt boot. i had tried to run software on intel 865 with this processor there message appair's incorrect boot device blue screeen appair's. pls give solution on which board i can run my sotware. intel 850 motherboard is not available here.
    Sergeant:
  • 263 Answers
When the message say that incorrest boot divice means the boot order is wrong so go to bios by pressing the key F1 or F2 or F10 or DELETE when the computer try to boot up then go to boot order and change the order for the first your hard drive save it and restart the computer but if there is no operative system you have to re install it that message say it can not find the operative system on the boot order devices
Posted on Jan 01, 2008
Hi...my OS is Windows 8 and I can't install my motherboard Intel D915GEV graphics card...please help me... ... ...
Here is the official Win 8 Compatibility site:http://www.microsoft.com/en-us/windows/compatibility/en-US/CompatCenter/Home
Suggestion: Always test OS and software on VMware and keep checking Intel for updated drivers. Good luck.
Aug 24, 2012 | Intel D915GEV Motherboard
I need driver
Go to support.asus.com. Enter your motherboard name. Chose operating system. And download.
Aug 16, 2011 | ASUS Intel 440BX Chipset CUBX-L...
Hello Sir/Madam, My name is Ganesh. The problem i am facing is, i have the Intel D101GGC motherboard, and when i try to install all the drivers, the 'flexible integrated graphics driver' doesn't get...
If you have just installed the OS and you are having this problem. I suggest that you flash the bios. If not check your OS if it is 64 bit or 32 bit. For 64 bit OS you have to download a 64 bit driver for your devices to work.
Apr 05, 2011 | Intel D101GGC Motherboard
I have intel D845GLAD mother board. in my system i m not getting sound so pls help me
likely to b problem with driver..
often follows with software corruption/os failure/faulty ram/main board..
i guess u r using a licensed n updated antivirus..
download, install n run microsoft kb890830
check with the following step(s)..
1) try download n install the audio driver http://downloadcenter.intel.com/Detail_Desc.aspx?ProductID=830&DwnldID=5500&lang=eng
2) remove unnecessary items from boot..download n install 'Startup Control Panel'..in here uncheck unimportant startup items..
OR 3) replace the RAM with a standby..
OR 4) reinstall os..
OR 5) disable audio device from the CMOS/BIOS..install a fresh PCI Audio Card n see..
at any point of time, u may contact me/us, in case u require any guidance..
if u r not a professional, try contact ur system admin/vendor....
Nov 03, 2009 | Intel Desktop Board D845GLAD Motherboard
Installed a new processor and now it wont work
Is that an upgraded processor? If it is, then somehow, it could be its configuration problem with the older processor on software side. Your previous installation of OS remember its past processor and reporting error.
You can try fresh installation. Just for the input.
Apr 04, 2009 | Abit Fatal1ty FP-IN9 SLI Motherboard
Drever for ASUS INTEL 850 CHIPSET P4T-E - MOTHERB
Hey, you can download the driver or your motherboard from
http://support.asus.com/download/download.aspx?modelname=P4T-EM&SLanguage=en-us
Note: After each installation please restart your machine to take its effect.
Mar 10, 2009 | ASUS Intel 850 Chipset P4T Motherboard
Myself can't install win_xp sp-2in my pc
THE INSTALLATION OF WINDOW SERVICE PARK GOES LIKE THIS. IF YOU ARE USING WINDOW XP WITH SP1 THEN YOU CAN UPGRADE IT WITH SP2. IF YOU ARE USING WIN2000 FOR INSTANCE YOU CAN NOT IINSTALL SP1 OR 2 OF WIN XP ON YOU OS YOU MOST FIND SERVICE PARK FOR WIN2000 TO UPGRADE AND IT ALSO HAS TO START FROM 1 TO THE LATEST VALUE THAT IF YOUR WINDOW2000 HAS SP1 YOU WILL START WITH 2 YOU CAN JUNP TO SP3 OR 4.
Nov 20, 2008 | ASUS P5GD1 Motherboard
Sound driver can not found
well check the BIOS setting that if it is onboard sound then it is enabled or not.
i recommend that you restore the default settings for setup utility.
Oct 22, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Intel DG31PR Motherboard
Did you get an error message during install of the (system with the SATA 160GB drive)? Make sure the 160GB drive is shown in the bios. Than go to the title, Boot in the bios & make sure the SATA 160GB is listed in the boot order. (Preferred 3rd. boot device)
Please go to the SATA drive's manufactures site & download either their bootable floppy or CD setup software. (It’s free)! Use their software to setup the FAT & cluster size on the drive. You can even set other features that neither the bios or windows can do. Format the 160GB drive with the software as well. The manufacture's software does a better job than windows. If the 160GB drive is a SATA 2.0 leave the jumper on the drive alone. The Desktop Board supports four Serial ATA channels (3.0 GB/s) via ICH7, connecting one device per channel.
Again, please run the manufactures setup software for your SATA 160GB drive. (Disconnect any other drives that may be in the system until windows is installed).
Intel's web site here: http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2839&lang=eng
Good luck ameyaniks!
If I missed something, just let me know.
Mike
Sep 11, 2008 | Intel DG31PR Motherboard
Intel Motherboard Logo
167 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
