Question about Garmin StreetPilot c550 GPS Receiver
Turns off during "loading maps"
GPS
1) powers up.
2) States "loading maps".
3) Then unit goes off?
Is there a power problem or something more? Does this unit need a data card in place?
  • 2 more comments
  • Anonymous Jan 12, 2008
    Have the same problem on a c530.
    It's not a battery/power issue. If you pull of the face plate and reset it,that doesn't help
  • Anonymous May 16, 2008
    turn on and off
  • damyankie Jun 02, 2008
    when i power it on instead of the message if i agree to terms it says it is
    loading maps then it shuts off i folowed the directions and pushed the
    dots and it still shut down
  • nicegiant Jun 23, 2008
    Turn on the GSP Street Pilot c550 and it says Loading maps and then it shutsoff
I had a the same problem but my ended up being a charging issue. My charger was broken and was not making contact. Went to local store and purchase a new one. After hours of looking on line beatting my head against the was and with plenty of reset and curse's. All I needed was a new charger.
Posted on Jun 13, 2009
Stupid question # 1 - Is it plugged in or running on battery when this occurs? # 2 - Is it charged?
Posted on Jan 01, 2008
  • 4 Answers
Okay.... Here's what I had to do to get it fixed.
This is a software issue with the unit, btw.
Step 1. Get an SD card in a card reader attached to the computer. Get the latest firmware from Garmin... 6.00 at the time of this writing. (You can't use the web updater, since it won't work at this point).
Install the firmware to the SD card.
Step 2. Slide SD card into Garmin 550 and turn on power. You should see something that says "Loader" or "Loading" ... wait for this to finish. You may need to supply power to the unit for this to complete if your battery is down.
Step 3: You can access the file system now by plugging it into your usb port on the computer while the power is on. While you're there look for any files in the top level directory other than MP3 and Garmin directories. Remove those files. Make sure you safely remove the device from Windows.
The only files that should be in the top level directory should be the directories GARMIN and MP3.
And while I was there I completely emptied out the MP3 folder.
Step 4: I performed both resets .... the reset under the cover plate (look in the garmin manual for help with that) and the other where you hold the power button on for 30 seconds.
And then it started working. I'm not exactly sure which of the two resets was the one to make it reset completely but it is now working again.
I think it got confused by the files that were in the top level directory of the device. The only things that should be there are two directories: Garmin and MP3. I believe that it does get confused if there are any other files in that directory.
From now on I plan to just use an SD card to hold my MP3 files... and I won't write anything to the Garmin itself.
Posted on Jan 12, 2008
Hard reset on eagle fish elite
Elite 640C Reset 1. Turn unit OFF 1. Turn unit OFF 2. Press and hold the PAGES key 2. Press and hold the ZIN&ZOUT Keys at the same time 3. Press and hold the PWR key 3. Press and hold the PWR key 4. Release both buttons when the unit powers up to Full Map Screen 4. Release both buttons when the unit powers up to Full Map Screen Soft Reset (Does not delete GPS Data) Hard Reset (Deletes stored GPS Data such as Waypoints and trails)
May 27, 2012 | Eagle Industries FishElite 640C GPS...
When I turn my Garmin 550 on it says loading maps, then goes to the select a local: It's frozen their on United States i push OK and nothing happens can not change the Locale it's frozen I tried...
Hi tkfranks331,
Press the power key and hold it if the screen of your Zumo is frozen. Keep holding the power key while pressing the key that has a plus symbol ("+") on it. This will reset your device and unfreeze the screen. You can also try calibrating the screen by pressing the power key for one full minute.
If this does not work, please follow these steps.
1. Update the internal disk software. Download and install WebUpdater on the computer. Please visit this link to download the WebUpdater.
2. Open WebUpdater on the computer.
3. Connect the Zumo 550 to the computer with its USB cable.
4. WebUpdater will automatically search for updates.
5. Follow the prompts to download any pertinent updates for the Zumo 550.
Hope it helps.
Thank you for using FixYa.
Aug 17, 2011 | Garmin zumo 550 GPS Receiver
When I try to spell states it goes right to no matches found on the 1st entry
After powering up the unit and selecting address, the unit displays, "In What State is the Address? and Spell State. When I press Spell State, it has No Matches Found. When I press Back and attempt to enter the first letter of any state, the unit displays "No Matches Found".
Sep 17, 2010 | Garmin Nuvi 350 Car GPS Receiver
I have a Garmin Street Pilot C330 that is a couple years old. Keep getting reminders to update maps but haven't needed to. Now we are travelling to Vancouver Canada and would like to update maps to include...
I would suggest you reset the unit,if that doesn't solve the problem, then you will have to update your garmin nuvi, I think its out of date and needs to be updated. Follow the procedures below on how to update your garmin nuvi:
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Also, in case you don't know how to reset your garmin nuvi, you can follow the steps below: There are two types of reset;
Performing a Standard Reset
1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
2. Hold the switch in the position for at least eight seconds.
3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
1. Turn your Nuvi off by sliding the power switch to the left.
2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
Take care.
Jul 04, 2010 | Garmin StreetPilot C330 GPS Receiver
Will not load map. I plug it in an it starts and will not shutdown. Just says loading maps
Take care.
Jul 20, 2010 | Garmin nuvi 255W GPS Receiver
My Garmin Nuvi 1390 has frozen on the 'loading maps' page I turned the unit on holding down the bottom right hand corner clicked yes when asked do I really want to erase all user data. What if the device...
Take care.
Jul 04, 2010 | Garmin nuvi 1390T Car GPS Receiver
Garmin nuvi® 255W Car GPS Receiver. Problem: Reboots during Map
The simple way is to send the unit to Garmin they will load the maps for free.
If you keep trying - try this -
With your thumb in the lower right corner of the screen - pushing in - like there is an X there - [ push with your thumb before you turn it on] Turn it on -
when this screen comes up - push YES -
then try your maps.
If they do not load on your pc [ which must have the unit hooked up and a legit copy of the newest maps ] then send the unit to Garmin. They will load your maps for you FREE. 86278d7.jpg
May 11, 2010 | Garmin nuvi 255W GPS Receiver
Gps will not start up
Hello :
I recommend you to reset your device to fix the problem .
Here is how to reset your GPS :
1. Turn unit OFF
4. Release both buttons when the USA map appears
Here is how to hard reset your GPS . But be careful because Hard Reset (Deletes stored GPS Data such as Waypoints and trails)
1. Turn unit OFF
PLEASE DON'T FORGET TO RATE !
Apr 16, 2010 | Lowrance LCX-15MT GPS Receiver
Putting maps on sd memory card
(Untried)
For C330 owners that want to have both Canada and US 2008 map update on their GPS this is what you have to do.
Must have:
1 - Street pilot C330
2 - 512mb SD card
3 - SD card reader of some form (some cameras will suffice)
4 - Garmin 2008 Map Update North America
What to DO:
1 - connect the GPS to the computer
2 - Insert the Map update disk
3 - Install the Lower 48 states, United States
(Reason - the C330 has around 1000mb of memory and the "US 48 states" map uses around 900mb" while Canada uses 400mb...which is why you will need that 512mb SD card later)
4 - Once the GPS is updated with the US map. Browse the Map update disk contents. This can be done with going to "My Computer" right click on your CD/DVD drive and click on "Explore"
5 - Open the folder called "img"
6 - Copy the file called "gmappromU.img" file is around 430mb. (This is the map file for Canada)
7 - Insert your SD card into your card reader and connect it to your computer. A window should pop up. If not you should see it on your "My Computer"
8 - Once you have navigated your way into the SD card directory. Create a folder on the SD card named "garmin" (no caps)
9 - Go into your newly created "garmin" folder right click and paste the "gmappromU.img" file. (This may take upto 20 to 30 mins)
10 - Once the process is complete, Rename the "gmappromU.img" file to --> "gmapsupp.img" (watch for spelling, no caps at all)
11 - Remove the SD card, Turn off your GPS, Insert SD card into GPS.
12 - Turn on GPS, let it load, and there you have it, the FULL North America Map.
When you are searching a state or province (depending where you are located) it will give you an option which map to use, Canada/Alaska or the lower 48 US states. Select your map and you are set to Go.
Feb 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
3,214 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
