Question about Hitachi 43UWX10B 43" Rear Projection Television
My 43uwx10b is havin problems power light flash
Seems like a common problem. I have 1 solid red light 1 solid green. 2 flashing green lights. Previous post said something about cap C702 and fuse E994. I checked the cap (not exactly sure what to look for... and I can't find the fuse. any help would be greatly appreciated.
David
  • David Ishman
    David Ishman Dec 31, 2007
    do you know where abouts they are located? this is the first time I have tried anything like this, so please bear with me.
  • David Ishman
    David Ishman Jan 25, 2008
    I fixed this problem it was the IC convergance chips! everything good now. ;o)
    Genius:
  • 1,153 Answers
check relay s901, FJ00142 you may have to solder out part and solder in new parts.
Posted on Dec 31, 2007
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Red light and 2 green lights on front panel on.
This is an error code it means the TV is in protection mode. Which means it has detected a problem and is preventing power up so not to cause further damage. Error codes are generally 2 numbers 1 seq of flashes a pause and a second sequence of flashes. Most common problems for LCD are Video logic / Main input board or the power supply. For more info and possible solutions post your make and model.
For parts and info check.
http://www.RNS-Systems.com
or E-bay
Oct 20, 2009 | Televison & Video
I have a Hitachi 43UWX10B that won't turn on. When I try, the red power light flashes, and I hear intermittent chirping. Any way to verify the problem and estimate repair costs?
Your convergence chips have failed.
Sometimes when they fail the TV will look 3D or distorted and sometimes it will just loose video and audio and chirp.
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly. 4) TV Chirps
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Battery light flashes red 4 times
Check your users manual. Normally if it is blinking it is powering up, but may be different depending on model.
Jan 01, 2009 | Dell Inspiron E1505 Notebook
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Power wont turn on
check that usb connections are not shorted to ground...
Aug 27, 2008 | Microsoft Xbox 360 Console
Thomson dti 6300 freeview box will not come on just shows constant red/orange light flashing all the time, tried leaving power off etc....anyone know?
What to do: if you have a solid amber light If the power light on the box will not change from solid Amber to solid Red then it is possible that a problem has occurred with the current in use software. Before attempting a fix, power the box off and on at the power socket and then wait at least 5 minutes for the solid RED lamp to appear.
If it still remains solid Amber and the box will not come out of standby to ON (Green light) then this can be corrected using the software revert procedure which is done using the box front panel buttons as follows:
1. Remove power to the unit by removing the power cable from the back of the box.
2. Wait 20 seconds and then restore the power cable while pressing the standby button repeatedly on the front panel of the box.
3. Release the standby button immediately when you see a lamp flash on the box's front display, and then immediately press the following front panel arrow buttons in this sequence:
- Menu
- OK
Note: you have to do this quickly and in sequence
4.The Orange light will flash and the STB will then reboot and should return with the previous version of software.
5. The box will now be running with the previous software version but it will automatically update with the latest version within approx 2 hours and you will be notified by message which will appear in the Message area within the Main Menu.
If you're still having problems please call 08444 159 159 and a member of the Technical Team will be happy to help.
Apr 13, 2008 | Televison & Video
Solid red light after flashing firmware
These are the 3 things listed as being wrong for the status light being solid red:
1. Media is out. Reload a new supply. Press feed button to
continue.
2. Power-up failure. Switch power OFF then back ON.
3. Printer ready to receive flash programming during
firmware download.
There's a programming manual available for download on Zebra's website: https://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
It might help.
Feb 15, 2008 | Zebra LP 2844 Thermal Printer
Hitachi 43UWX10B 43" Rear Projection Television Logo
71 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
