Sony KP-51HW40 51 in. Rear Projection Television
Problem for Sony KP-51HW40 51 in. Rear Projection Television
Color is off-3Dlike
By sblake74 on Oct 25, 2009
Color is off. It looks like 3D.
Best Solution
posted on Oct 26, 2009
Very Helpful)
Skyassoc
Rank: Guru  Sony Televisions & Videos  Expert
Rating: 90%, 273 votes
You have a Convergence Circuit failure. Most likely the Convergence IC's are STK392-560 that need to be replaced as a pair and there is also a possibility that a Pico Fuse in the Convergence circuit or Power Supply also needs to be replaced. Because of the difficulty in getting the Deflection Board out, I recommend that only a Qualified Service Person do the repairs. You could call Sony at 1800-222-SONY to find a local Service Facility near you. I would estimate a repair cost around 350.00 to 400.00 to repair it.
I hope this helps,
Skyassoc
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 07, 2009
Not Rated)
louis66
Rank: Guru  Televisions & Videos  Expert
Rating: 89%, 15 votes
Projection TV sets have several common problems listed below.
Convergence problem.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some pics of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button try pressing the button. If it fails to align the video the convergence circuit has failed. See below for a fix.
SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
If you are handy you can do it yourself or you can call in a pro.
If you want to do the repair yourself check the site www.TvRepairKits.com. They have kits that include step by step instructions with photo examples, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, and email/phone support.
Problem #2: Lens Fluid needs replacing!!!
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant for the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Here is a pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant,step by step instructions, etc.
Was this helpful?
Yes
No
Popular Solutions for Sony KP-51HW40 51 in. Rear
Questions and Unsolved Problems for Sony KP-51HW40 51 in. Rear
Do you recommend Sony KP-51HW40 51 in. Rear Projection Television?
Answer
Answer
On all video inputs except the one I use for the Bell HD PVR the tv appears to be missing the Blue... (More)
Answer
My set has very poor (and getting worse ) convergence when cold. Convergence is good after 20... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony KP-51HW40 51 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 733
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
