Question about SanDisk Sansa e260 MP3 Player
My sansa e260 isnt turning on
I have had my sansa e260 for a while but one day i charged it overnight and the next day when i took it off the charger it wouldnt turn on by itself only when it is plugged into the computer. also when it is plugged into the computer it displays this message "there is not enough space for music DB please free 6 MB then it goes to the screen that says connected. please help me fix it.
  • gotabeusmc Jan 01, 2008
    mine is about 2 weeks old...was working fine...then NOTHING. It's dead. It will not turn on...computer doesn't even recognize that it was plugged in.
  • 27 Answers
Well for starters, clear some memory. It sounds like the player is trying to turn on but failing as there is not enough free flash memory for it to use in a RAM like fashion. If youre using windows enable the view of hidden files folders. [Start> Control Panel> Appearence and Themes>Folder Options then browse through the tabs until you find a list which has the option "show hidden files and folders". Then plug in your e260 and go into the larger removeable drive. Then go into the folder "VIDEO" or "PICTURES" or "MUSIC and delete some files. Then once you have deleted at least 100MB, unplug and restart the player. This should fix your problem if it doesnt. Consider formatting the removeable disc, or updating the firmware. [However take extreme caution with formatting the disk to ensure that it does not contain the program files needed to run the player.
Posted on Jan 01, 2008
Sansa e260 mp3 player won't charge
Remove the back and check and see if the battery isn't fully connected
I put a folded peace of paper and put it on top of the battery
Also push softly but firmly on the Rubber rectangle above the battery (This is the Chipset For the screen, Black screen Blue ring problem) and put the back on.
Apr 03, 2010 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
Ifferent charger
more than likly not but the only thing you can try is go to radio shack and ask them if they have a universal charger which they might but it might be a little exspencive another thing you could do if u have a ebay account look around on there and maybe find one or if worse comes to worse look up there website and order one.
Oct 27, 2008 | SanDisk Sansa e260 MP3 Player
My sansa mp3 player wot turn on
Actually there's none so think about buying a new charger and if it's not working then re-write to me so that I can help you more.
Sep 18, 2008 | SanDisk Sansa Clip MP3 Player
E260 Wont Turn On
on the desktop click right button and click properties.now go to the apperance below the windows and buttons chane it as windowsxp style.
Jun 14, 2008 | SanDisk Sansa e260 MP3 Player
Charger
Your USB port must be repaired. In the meantime, hopefully, your computer has another USB port that you can use. Battery is a replaceable lithium ion rechargeable battery. There are battery chargers that you can connect to wall outlets - the type that plug into the computer would probably require that you plug it into the USB port, which you said is broken - so that's a no-go. There are multiple vendors for battery chargers - one possibility is http://www.greenbatteries.com/
-Tha Mp3 Doctor
Jun 02, 2008 | SanDisk Sansa e260 MP3 Player
Sansa cant be detected by computer
i had the same problem with mine and my computer didn't detected it so try plugging it in and out a few time it might work.but if that doesn't work go on settings and change the usb setting
Apr 06, 2008 | SanDisk Sansa e260 MP3 Player
My sansa e260 doesn't even turn on
Had the same problem, blue light no screen, took the cover off found a small black rectangle block not completely pushed in. the block is located on the right center on the part above the battery and right behind the screen.
Jan 12, 2008 | SanDisk Sansa e260 MP3 Player
My sansa will not turn on
hold the power button for 20secs or try holding both the power button and the play button for20seconds
Dec 28, 2007 | SanDisk Sansa e260 MP3 Player
Refresh Database
This is happening alot aparently, Sandisk is telling everyone to just reset it but that aparently isnt really working. only suggestion is to set the USB mode to MTP and try it.
Aug 02, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
61 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
