Modems
Problem for Modems
Generic problem for all Modems
Siemens SL2-141
By yitzchak on Dec 31, 2007
I have the above router and my ISP claims that the Internet infrastructure provider had me set it up wrong when I originally got it. It now longer lets me on using the Admin password and user name
Same Problem
Sep 11, 2008
-   I am facing the same problem on sl2-141 modem.
Unable to locate the reset switch - can you pls help with any diagram.-   Guest
Best Solution
posted on Jan 02, 2008
Very Helpful)
McIndia
Rank: Guru
Rating: 86%, 124 votes
Go thro' the manual of the router there should be a resetting method for the router, ( a small hole thro which you should use some object to press a push button) in order to reset the router to factory setting, when this is done the user name and password is reset to the original factory settings with the default username and password then you can log in and re-configure your router for your ISP services.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on May 24, 2009
Very Helpful)
Samball
Rank: Apprentice
Rating: 100%, 1 votes
Answer for the reset button:
It is not a button but a small hole next to the actual power button.
Get a paperclip and insert it into the hole (about 2mm width). This should reset your modem.
Was this helpful?
Yes
No
Solution #3
posted on Aug 01, 2009
Not Rated)
CA Aadarsh
Rank: Apprentice
Rating: 0%, 0 votes
AT the bottom side of the modem there are many bosex. all are square except one which is round. that is your reset buttun
Was this helpful?
Yes
No
Popular Solutions for Modems
Questions and Unsolved Problems for Modems
Answer
My NU monitor is from 2005 and it keeps beeping and blacking out and turning on over and over??
Answer
PC will not fire up with new USR 5699B installed
Answer
How do I setup the firewall setting on my Motorola SBG900 wireless cable modem to send and receive... (More)
Answer
What happens is when i plug in my power chord lights turn on that shut off in 5 second which i am... (More)
Answer
What is the max RF input level to the modem? Most people say + and - 15 is the range to be in,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Modems Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
