Back to:
Tags:
VisionTek RADEON X1300,  AGP Graphic Card
Tried To Install New Card, monitor not responding.
posted by SherrieJ on Dec 31, 2007
Hi, i recently recieved a game as a gift and my old video card isn't strong enough to support it. It was a 64mb Geforce card. I bought a VisionTek X1300 pci video card. I went to install the card, the fan on the card starts up when i install it but it wont give me any signal on the monitor. I took it out, put my old one back in, installed the .net drivers on the cd and took it back out. Put the new one back in. No signal. Ok so i take it out once more to put the old one back in to give it another shot, and now it wont regcognize my old card now. So neither one of my cards are giving me any signal to my monitor. I finally got ahold of customer support and the only thing they told me was that i damaged my motherboard somehow while i was putting in the card! What!? Does anyone have any suggestions?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 02, 2008
Thanks for Trying (70)
map9966
Rank:Guru Guru
Rating: 89%, 1296 votes
Tech is suggesting that you pressed too hard while switching back & forth & may have hurt the motherboard by bending it. This a common problem. I can only suggest that remove your old card & clean the PCI slot with canned air. Carefully reseat the old card pressing evenly downwards till the card is seated. Use a flashlight & check where the card connects to the slot. It should be level across the PCI slot. Do this while the power cord is unpluged from the PC. Plug the power back in & start the PC.
Some video cards require extra power. Your newer card may need a four pin power connector to run. Please check the instructions that came with the RADEON X1300.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Tried To Install New Card, monitor not responding.:
I don't want to Accept this solution
Can you Help with these Graphics Cards problems?
Graphics Cards
I think my graphics card isnt working as good as it should...
Graphics Cards
windows vista ultimate, nec model nec versa S32001
Graphics Cards
Hello, Within Premiere Pro CS3 the footage (SD AND HD) is...
Graphics Cards
I lost disk driver car
Graphics Cards
My stamina/speed switch stopped working recently. The...
Loading problems.
Repair Service
Find Graphics Card Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
