Question about Zenith P42W34P 42 in. EDTV-Ready Plasma Television
Black vertical line on p42w34p plasma
The 42 inch plasma has a vertical black line that comes and goes. Only hook up to direct tv receiver (Video/s-video) connections. checked all lines (disconnected receiver and cable/black line on screen. help! I have the same problem - two large black vertical lines.  Any solution?
    Sergeant:
    Champion:
  • 298 Answers
Two large black lines is a different problem
thin black wavey type line that comes
and goes sometimes reaches the bottom
of the screen sometimes has white
streak at bottom is parisitc interference
stray signal not returning to ground
can be caused by cracked solder
joint somewhere loose cable connection
ground loop Basically it is an ac signal
that is not returning to ground because of
a marginal filter capacitor or any ground
return path. some power plug can be
reversed to solve when the plug is reversed
and the ground side of the plug is actually
connected to earth ground Best way to
trace it is with a good scope where you
can see the noise signal on the pulse
waveform
Posted on Dec 31, 2007
  • Eugene Merritt Dec 31, 2007
    With all the connections and cables involved
    in the new TV set each cable & each connection
    has the potential to create a problem,best way
    to avoid the problem is keep your connections
    simple, staight foward clean & uncluttered
    1 Try svideo to tv direct from dvd player
    2 Try rca from dvd player to tv (to eliminate tv as source)
    Does it disapperar, if so when ?
  • 265 Answers
I bought a TV that had a similar problem. I had the RCA certified repair technician out to fix it. He didn't know what to do. He had another technician come to his aid. He didn't know what to do. RCA exchanged my TV for a new one. It has had no problems.
LG's official statement in FAQ's:
"There are lines in the picture.
This may be caused by poor TV signal reception. Before calling an Authorized Service Agent, please check with your cable company, satellite company, or check your antenna." -- SOURCE
LG is Zenith's owner.
  • 579 Answers
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
2 Suggested Answers
lukster
  • 217 Answers
SOURCE: black vertical line on p42w34p plasma
could be a loose ribbon cable on a buffer board, or one of the buffer could be going bad
Posted on Feb 17, 2007
I HAVE THREE BLACK LINES AND A YELLOW VERTICAL LINE DOWN THE CENTRE OF MY SAMSUNG 50" PLASMA TV. ONLY 10 MONTHS OLD! WHAT CAN I DO?
The TV should be still under warranty. Most of the flat panel TVs come with a one year warranty from the manufacture. I wouldn't mess with the to void the warranty.
The problem most likely is the buffer/scan boards on the bottom connected to the screen. It controls the vertical image on the screen. The other possibility is the plasma display panel is bad.
Go the warranty route first. This may get expensive to fix.
Apr 01, 2010 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
1" black vertical line in center of screen. Sony Plasma.
NOT DEFECTIVE!!!
There are 4 or 5 ribbon cables on the bottom or on one side, they control part of the plasma screen. Check the ribbon cable2_bing.gifnear the black lines. Unplug the ribbon cable and look for black chipson the underside of it, I think they say 100 on them, you need toresolder both ends on each chip. Should fix the black line issue.
Aug 19, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Black vertical line 2 in wide on zenith p42w34p
Hello, I can help you fix your plasma TV. If you have Black vertical 1.5 inch line/s that come and go. Please feel to call or message me at 1-503-432-9904 or pleasefixitdave@yahoo.com Ask for Dave! Later guys!
Jan 02, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Black verticle line on screen of zenith p42w34
I'm sorry you have not been given a clear answer on how to repair your TV. I know how to fix the problem you are having (1.5 inch Black vertical lines that come and go) If you still need help fixing your Plasma TV please feel free to message me @ pleasefixitdave@yahoo.com or just give me a call @ 1-503-432-9904 and I'll help you fix your TV buddy! Ask for Dave! If your reading this post and you have a plasma or LCD type TV and need any type of help please feel free to give me a ring or message me with the problem your having. I'll do my best to help you!
Talk to you later!
Dave :-)
Nov 30, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Zenith P42W34P Plasma Display Panel
Hello, My name is Dave and I can help you fix your Plasma TV. Do you have Black vertical 1.5 inch line or lines on your screen that come and go? Then give me a call. Please feel free to give me a call @ 1-503-432-9904 or message me at pleasefixitdave@yahoo.com
Thank you!
Dave,
Nov 20, 2008 | Akai PDP-4247 Television
Black lines on sony plasma tv
go here, it will work.  follow closely and read entirely!  it worked for me on a gateway plasma!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Oct 27, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Black stripe down TV plasma screen
I'm sorry you have not been given a clear ansewer on how to repair your TV. I know how to fix the problem you are having (1.5 inch Black vertical lines that come and go) If you still need help fixing your Plasma TV please feel free to message me @ pleasefixitdave@yahoo.com or just give me a call @ 1-503-432-9904 and I'll help you fix your TV buddy! Ask for Dave!
Talk to you later buddy!
Dave
Apr 05, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Black line in a 42 inch panasonic plasma tv
I have a 2 black lines. One goes horizontal and one runs vertical. Is this something I can fix?
Jan 22, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Black vertical lines is there a fix
Oct 27, 2007 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Oct 03, 2006 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Zenith P42W34P 42 in. EDTV-Ready Plasma Television Logo
220 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
