Question about Mitsubishi WS-55807 TV
GREEN BLINKING LIGHT TV DOES NOT COME ON
GREEN BLINKING LIGHT BUT TV DOES NOT COME ON
    Genius:
  • 1,153 Answers
Check error codes by looking at threads here or ctechnicians.com
Posted on Dec 31, 2007
My tv doens't turn on the green light is blinking all the time
There are several problems associated with the blinking lights. Your tv is flashing a code to tell you what is wrong with your TV. I know that tvrepairkits .com has a blinking light kit but you will have to see if they have one for your model.Hope this helps,James
Mar 27, 2012 | Televison & Video
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Continuosly blinking green light and tv won't turn on.
Either bad capacitors -vented - on power supply board or bad E2P eprom board on DM board.Probably the capacitors-4-1000Ufd and 2-3300ufd.You should get expert help from reputable tv shop.Not really do it yourself fix either way.
Dec 15, 2008 | Sony KDS-60A2000 60" HDTV
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Blinking Green Light of Death
I had this similar problem TWICE!!!. I called around for a repairman and they charged over $300 dollars to repair (HELL NO). Anyways I took a trip to Vegas hoping to win some of the money to repair it and left the TV plugged in and BLINKING during my trip. When I came back it was not blinking anymore and I got curious. Well I pressed the power button and to my surprise IT TURNED ON!!!!. A month later I moved to a different house and unplugged my TV to move it and when I plugged it in the DAMN BLINKING GREEN LIGHT OF DEATH was back. Well I thought I'd get lucky again and leave the blinking on, well 2 days later the blinking was gone and ONCE AGAIN MY TV WAS ON...... I hope this helps and works for other people. My point is, before you pay for a technician to repair it and before you give up on your TV and unplug it, Try leaving it on BLINKING for a few days and see what happens.
GOOD LUCK GUYS.
Oct 07, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-55807 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
