Question about Acer Aspire 3000 Notebook
Acer aspire I have an older aspire 3000 with 17 g on c drive and 17 g on d drive my c drive is completely full and my d is almost empty. WHen I try to clean up c drive computor keeps shutting down. Can and how I ransfer data to d drive? Thank you in advance
    Problem Solver:
  • 9 Answers
HI!
You can not do something, if your computer will continuosly shutting down as you turn it on. so first and foremost, if it is still applicable, try to repair your OS, by rebooting on its original OS.
If this is not possible, run your pc, on SAFE MODE with COMMAND PROMPT, and try to copy the file you want to transfer from drive C to drive D. And to have a guide to do so, as you get in the command prompt, type xcopy/?
Posted on Dec 31, 2007
Acer Aspire 5735, the C drive is full but the D drive is empty, can you change the partition so that more is given to the C drive?
Windows - You can't it is the active partition and contains the OS.
Use 3rd party software like Partition Magic. Be sure to backup first. This was not a safe thing to try.
Nov 11, 2012 | Acer Aspire 5735 Notebook
I have an acer 5315-2326 and I reformated the hard drive and tried to load windows 7 pro. It cant find the hard drive. I can load ubuntu but when I try to load windows 7 it says no hard drive found.How do...
I have seen hard drives where people had screwed around the partitions so bad that their computer would recognize it. I would recommend since Ubuntu can see it. Boot into a Ubuntu Live CD and delete any partition info so that it's a completely empty disc. Then try to use the Windows 7 DVD to install Windows. Comment back with your results.
Oct 25, 2011 | Acer Aspire 5315 Notebook
I have acer aspire 5551 , my laptop battery charges fine but it stops on 91% and does not go further :( , what is the possible solution for it ?
Hi, Your battery needs to be calibrated, what you will need to do is charge the battery fully or until it can not charge more, drain the battery completely then recharge to full, doing so while letting your computer recognise and mark the full point and the empty point... the process depends on the version of windows you have and also if you have a bundled tool or a program that does this for you, search your laptop installed programs or check in your power options. vista is the only operating system I am aware of that does not have a built in tool, others should have it, just follow the tool instructions and you should be all set, if you can not find the tool or have vista let me know... Best of Luck
Jan 31, 2011 | Acer Aspire 5551 Notebook
Acer 5315 HD C is full HD D empty
Very likely the answer is yes, IF: 1) there is enough space and 2) that D drive is not being used for something else. Check on what is on the D drive. It's usually reserved by the manufacturer and contains OS restore files (used for restoring your system after a crash). Don't delete these, but if there is enough free space, just create a new folder and put your files in there.
Jan 31, 2010 | Acer Aspire 5315 Notebook
I need more space on my laptop
ahaaahhhhhhh......... you mention your partition drive D is completly empty...transfer your drive C files to your drive D. by that you can free space in your DRive C and also right now you are experiencing slow in operation of your laptop ryt? its because Drive C is almost full and your drive C is the partition where your operating system installed...
about your question of combining the drive c and D yes it is possible. for for me you have already the advantege setup currently i yopur laptop all you need to do is balence your files... make your drive D your storage files. your back up area. like your personal files, pictures, music, videos transfer it to drive D
Oct 08, 2009 | Acer Aspire 4720 Notebook
I have a 60gb hard drive on acer aspire 3690 but
you can transfer some of your files from My Document to D:/
Sep 12, 2009 | Computers & Internet
Low memory. C-drive full, but D-drive, which is of equal capacity, is empty.
I have been here too. You physically have one hard drive and the C: partition is full. I used a program called partition magic that will allow you to repartition your hard drive without erasing anything you currently have installed. It is a really cool program, it just takes a while to do the procedure. You can Google several ones, but I suggest the one from Paragon.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
May 03, 2009 | Acer Aspire 3000 Notebook
Acer Aspire 5100 Freezes
I am not sure which you are talking about either. But I will venture to say that I had a similar problem once where setup would not complete on my system either. I initially thought that I had a bad or dirty disc but later after running a few tests, I found out that my HDD was full of bad sectors. Thus I ended up replacing the HDD and all is well. I would try running a stand alone formatting software or you could try doing a complete format vs. a quick format during Windows setup. If setup still won't complete after a complete format then run a surface scan or a HDD regenertion program to verify the integrity of the drive. This will tell you if you have a bad drive or not.
Aug 20, 2008 | Acer Aspire 5100 Notebook
C memory full
not possible...you'll need to back up that c drive, which is the default for all Windows programs..try a back up drive, or move some of those high density(music and image) files to a back up system
May 25, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 3000 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
