At sign-on I will get a tone and the keyboard is locked out. If I then go to Last Known good start-up, it may or may not allow me to sign on but then a short time later it locks the board out and an intermittant tone beeps..What the heck is going on???
if it doesn't boot right and makes issues ..it means that you have some corrupted files or viruses in the system from what you describe ...reinstall the operation system and format the C partition to get rid of them ...
Comments:
Oct 25, 2009
- ok ,,,for reinstalling the operating system you have to use either the recovery cd-es that you got when you bought it ...this will get it to the stage it was then ,,,or ..use Boot-able cd with xp ...or vista ...what ever you use...and the partition formatting will occur during the installation at some point ..it will ask you if you want to keep and install over or delete the partition remake it and format it ...to continue the installation ....anyway ,,I will gave you a link about how to install Xp step by step ...to get familiar with ...but let me tell you that if you never do it before ...ask a friend of so to help you cause in the moment you started there is no way back .... http://support.microsoft.com/kb/316941 http://www.blackviper.com/Articles/OS/InstallXPPro/installxppro1.htm http://www.windowsreinstall.com/winxphome/installxpcdnewhdd/index.htm Either one of this 3 are pretty acurate and explain very well the process ...anyway keep in mind that you need to have in handy all the drivers you will have to install after ...sound , network , and image at least ...if its a laptop you need wireless , bluetooth ...etc...
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Thank you for your quick response but how do I reinstall the operating system and partition the c drive
" - gbarns12
Well...one thing to do is isolate if it is hardware or a software problem.
I think it sounds like a stuck key so vacuum out your keyboard is one thing. Clean your mouse as well.
But what you need to do is goto www.ubuntu.com and have someone download and burn you a ubuntu LIVE disk. Then watch when it boots and it will SAY press DEL to enter BIOS....you want to go into BIOS and switch the BOOT order so the CD-ROM boots 1st over your hard drive. Don't forget to save what changes you made in BIOS. Then put Ubuntu Disk in and boot with this. It will ask you to install or boot with LIVE Disk. Boot with LIVE disk.....if problem goes away then you can sort of eliminate that its hardware, its probably the operating system of windows. If same problem then you pretty much bet its a hardware problem.
instale windows 7,en mi compac empresario,pero no tengo el controlador de video,me puedes ayudar,soy...
(More)
instale windows 7,en mi compac empresario,pero no tengo el controlador de video,me puedes ayudar,soy zanche1940@hotmail.com dede venezuela,saludos
How do I stop or adjust the scroll feature on my touchpad ? I tried messing with the mouse in...
(More)
How do I stop or adjust the scroll feature on my touchpad ? I tried messing with the mouse in control panel and it didn't help.
Yes hello, my name is Ben and im having a problem with my laptop, its a v2000 a friend gave me, i am...
(More)
Yes hello, my name is Ben and im having a problem with my laptop, its a v2000 a friend gave me, i am wanting to fix it up and give it to my parents for Christmas, I can also understand everything u say to me about a computer, so u can reply computer talk. Okay, now i have been having a problem i JUST CANT FIX. its starting to make me mad, it is doing the following: When i turn it on the compaq screen starts up, but i cant press: Esc for boot menu F10 for setup or F12 for LAN boot. Sometimes if i turn it on and press Any one of those keys many times it will go to a screen that says press F1 to continue or F10 for setup, but still none of these keys do anything. It beeps twice on this screen, its a short non-loud beep. Now last, i have opened the laptop as i thought maybe the Cmos needed to be reset, so i took the battery out and back in. while i was in there i decided to look at the whole computer, so i looked at the processor, i had a little bit of what it looked like burned stuff on it. there was some burn marks on the metal looking thing and around it on the green part on the chip. what does this sound like to you. i think it is either 1 of 2 things: the processor is dead or the BIOS was corrupted and i cant flash it because i cant access the boot menu!!!!
powers on but stalls at screen saying Press to resume, to setup. Can't get into bios or anything,...
(More)
powers on but stalls at screen saying Press to resume, to setup. Can't get into bios or anything, no response from pressing any keys.
