Question about Sharp ZQ-800PC
Unit memory My unit will not start even whe pressing esc and reset. help
MY ACER ICONIA A500 WON'T EVEN SHOW A DISPLAY. I BOUGHT A NEW POWER ADAPTER, DID A MASTER RESET AND STILL NOTHING. CAN SOMEONE HELP ME BEFORE I GO CRAZY?
Im not pretty much sure if your acer is like mine; ASPIRE V3****. It has an option here while i am pressing keyboard F6 key,, the display become blank, the display was shown back by pressing F6 again. Or your Acer system cannot properly detect the memory.. before you use the unit, remove & clean the connector surface of the memory card/s with soft cloth or tissue paper. THen insert the memory card on it's slot properly, Start up you ACer and wait for the good results. GOODLUCK!
Aug 20, 2014 | Computers & Internet
Waypoints
Hi there
Sounds lie it has a memory problem... perhaps a failed internal memory chip... are you using an external mem card with it as well?
robotek
May 07, 2008 | Lowrance iFinder GPS Receiver
Shows ERR when turned on
Hi, If you can't get it to work, try to do a factory reset.
Turn the unit off, then Hold the PRINT and ESC key down and then Press the power button. KEEP HOLDING THE Print and Esc key down for 2 seconds and then release both of them. You should see a message in the display INT?, Press SET to Reset your printer, or Esc to cancel.
Hope this helps.
Mac =)
Dec 28, 2013 | Casio KL-60 label maker
Shows ERR when it is turned on
Hello, If you can't get it to work, try to do a factory reset.
Hope this helps.
Best wishes
Mac =)
LCD display is fading
Run self test and LCD test:
Power unit on while holding MENU/ESC-
press down arrow to TEST then right arrow to start.
When self test is complete use down arrow to go to LCD TEST, then right arrow to start. Press MENU/ESC for a while screen the MENU/ESC again for vertical gray bars. Press MENU/ESC 3 times to exit. The LCD unit is pn 000-145-512, $175. I strongly suggest you not attempt replacing the LCD yourself unless you are a qualified Furuno tech.
Feb 14, 2013 | Furuno 1623 Radar 16nm Range
Bypass code for dual xdvdn9131? is there a bypass code for this new unit?
dont need a code just get a toggle switch and hook that to the yellow/blue wire and with the other side ground to the small lil screw where you will see a small lil short wire and then all u have to do is fallow the screen with the e brake but just flip the switch 3 times with the whole one sec then off for 3 sec then on
Feb 18, 2010 | Jensen VM9510 Car DVD Player
My ACER netbook turns on but the screen remains
After switching off the aa1, when trying to turn it on again, it just shows blinking leds and the fan is turning. But the screen remains black.
If your aa1 does like this probably its BIOS has been damaged...
Luckily the Acer Aspire One has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore.
Please note that the process I'm about to describe is only meant for emergencies and may void your warranty, so use at your own risk.
1) Format a USB memory key with the FAT mode.
2) Download the latest version of the BIOS from Acer support website:
3) Extract the files from the zip and put both the FLASHIT.EXE and the BIOS file in the root directory of the memory key.
4) Rename the BIOS file to ZG5IA32.FD and then remove the disk.
5) Turn the AA1 off, insert the battery and connect the AC adapter.
6) Insert the USB Memory Key into one of the USB port of the Aspire One.
7) Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on.
8) Release Fn+Esc after a few seconds, the power button will be blinking.
9) Press the power button once. The AA1 will start the BIOS flash, do not interrupt for any reason. After some minutes the power button will stop blinking, and then the AA1 will reboot. Wait till the AA1 has completed all this operations.
If everything has gone right, the BIOS is flashed and all settings are reset to default.
Nov 16, 2009 | Acer Aspire One Netbook 8.9" Notebook
I have a casio kl-60 EZ-LABEL Printer my batt was low tried to print and labeler said ERR. Changed Batteries still said ERR. Please help lost manual. Tried to find manual online. would be nice to have.
to reset memory
1. Make sure that label printer is off
2. While holding down the PRINT and ESC keys, press ON?OFF to power on.
3. KEEPING PRINT and ESC held down, release the ON?OFF key only.
4. Release PRINT and ESC keys.
5. Press SET to initialize the Label Printer or ESC to Abort
http://ftp.casio.co.jp/pub/world_manual/ds/en/KL_60_E.pdf
Aug 14, 2008 | Casio Computers & Internet
Sharp wizard oz-730
Hi, I has this problem but I found in the user manual this instructions and works ok: 1. Press and hold the Start key.
2. While holding down the Start key, push the RESET button
on the bottom of the Organizer using a pen or some other
pointed object. The following message will appear.
"Do you really want to initialize the organizer's memory (this will delete all data)? Yes:[ENTER/No:[ESC]
3. Press to initialize the Organizer.
The message .Working... Please wait.. appears while the
Organizer proceeds with the initialization procedure.
The Welcome message then appears.
Oct 10, 2007 | Sharp Wizard OZ-730
Sharp ZQ-800PC Logo
15 people viewed this question
Top Sharp Computers & Internet Experts
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
pontelemon
pontelemon
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
