Dell Motherboard
Problem for Dell (E210882) Motherboard
Intel E210882 video issues\r\nHad a dual vid
By will10968 on Oct 25, 2009
intel E210882 video issues Had a dual vid card...lost it.
onboard vid does not work. power supply 100% no blown capacitors I can see. other pci vid cards do not work. no sounds or beeps...just wont work.
lights on board are on & green
What can I do to get this board up & running?
Solution #1
posted on Oct 25, 2009
Not Rated)
dlundmark
Rank: Wiz
Rating: 84%, 288 votes
The possibility that the video setting in the bios is blocking your video seems to be what could be wrong.
To reset the bios, turn off all power to the board or remove the power cord from the power supply. Find the bios and the jumper next to it, short the jumper for a few seconds, then replace the jumper to it's original position, and then try the computer with a pci video card.
I did some research on the Internet for this board. It seems that the cpu can have video problems, and if that is the case, you will never make video work unless you change the cpu.
Possible fix: Either change the cpu, if that is the problem, or change the mother board to another one which can fit or is a replacement for yours.
you may find a replacement of either one that fits or one which is an exact replacement on Ebay. Do a search for the board you desire. Prices vary, and are not too expensive considering. Prices are from a few $$ to over $50.00. Get one which is known to work correctly and try to get a cpu at the same time, if that is your final choice. One example on Ebay
My suggestion, if I had to do this would be to get another mother board with a cpu which will fit this computer, then re-install what is needed and make the operating system work. A complete restore should not be necessary, if you change the mother board, but many things will have to be re-installed.
A note: It may be a good idea to back up your boot drive on another computer and set it as a slave drive. This way you can save any data which may be destroyed when you re-install, if it is necessary to do that.
Remember, a Windows OS in which you have saved a lot of data to "my documents" will be all removed, and destroyed should you need to re-install any of the operating system. That is why you should consider to backup your original data before starting a new mother board.
Was this helpful?
Yes
No
Popular Solutions for Dell Motherboard
Questions and Unsolved Problems for Dell Motherboard
Do you recommend Dell (E210882) Motherboard?
Answer
Answer
dell rev.aoo aa a85538-702 cant power up need terminal diagram
Answer
my optiplex gx240 suddenly wont hold bios settings. changed the board battery...no joy. confused!
Answer
Ik heb geheugen bijgestoken, deze zijn correct, nu start pc niet meer op, f2 of booten helpt niet,... (More)
Answer
Display only shows low 8 bit 800 by 600 Cant get on internet on this machine so need motherboard... (More)
Answer
necesito saber el numero impreso del circuito Q8F1 de la tablilla dell E210882. si alguien es tan... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
