Question about Office Depot Ativa D5772 Phone
L1 Extension In Use
The L 1 light is flashing on the base phone. I cannot get it to clear. I have the batteries out of the handsets. I have unplugged both corded phone from phone lines and electrical lines nothing changed. When I call line one I get a busy signal. When you pick up or hit speakerphone button the line sounds open.
inquestusa@sbcglobal.net
  • Anonymous May 30, 2008
    Same issue as yours
I had the same issue with TL76108. After trying to find the solution on the web, I called AT&T tech support: they tried to guide me to troubleshoot this issue. After some unsuccessful attempts, they advised me to return the phone where I bought it (luckuly I had the invoice and the original package) for exchange or refund. At Staples (that's where I bought the phone) I asked for exchange. As soon as I got home, I plugged in the phone and it started working perfectly.
So the solution for me was to return the defective phone and get a new one.
Hope this help.
Posted on Jan 14, 2009
3 of my 5 phones say "No Line"?
This sounds like a registration problem, the errant
handset(s) and the base have lost identification
with each other.
NOTE: the CS6429 works a maximum of 5
handsets, so you have a "fully populated system".
You will have to clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ).
( I ). First de-register each handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( II.) To clear the base of all handset registrations
1. press [Find Handset] on the base and hold
past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink. 2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration ===============================
( III.) To register each handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
Good luck !!
Apr 16, 2016 | Vtech Accessory Handset with Caller ID for...
Tip
How To Reset and Re-Register Your Uniden Handset and Base
<b>Clear the Handset's Base Data<br /></b>1.To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.<br />2.It will now be de-registered from the base.<br />Note: This requires that the base and handset can communicate with each other.<br /> <br /> <b>Clear the Base Handset Data</b><br />1.To de-register all handsets from the base, remove power to the base, and remove the handset from the base.<br />2.Press and hold the 'flash/find hs' button while applying power.<br />3.Wait for the beep and release the button.<br />4.The charge light will now flash.<br />5.Sit any handset in the cradle.<br />6.When the flashing stops, re-register the handsets to the base.<br /> <br /> <b>Re-Register a Handset to the Base<br /></b>1. Remove Handset Battery.<br />2. Reconnect battery while holding down "*" and "#" key.<br />3. Then press the right upper key under the LCD.<br />4. Press the "End" key.<br />5. Wait a few seconds and then the phone will be ready to register to the base.
on Feb 14, 2011 | Uniden DECT 6.0 Cordless Phone ID
Vtech cs6649 will not register more than one handset
The errant handsets must be de-registered from their
original base and then registered to your base.
NOTE: the CS6649 handles a maximum of only five
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
In that case, you can clear each handset ( I ) then clear
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
1. press [menu]
press [select]
replace the cover
( if needed, else skip ahead to ( III ). )
Good luck !!
Jan 09, 2015 | Vtech Lands Phones
I am unable to set handset to work with the base. Its panasonic KX-TG5933Al
Registering a handset
Important:
If you accidentally assign another
handset's extension number to the base
unit, the originally assigned handset
stops functioning. Confirm the extension
number of the handset by placing it on
the base unit or charger. Lift the handset
from the charger before registering.
1 Handset:
{MENU} i {0}{0}
2 Base unit:
Press {SELECT} until the desired
extension number (H1, H2, H3, or
H4) is displayed on the base unit, then
press and hold {CALL} until the
CHARGE indicator flashes.
LH4 can be used if you have 4
handsets.
LAfter the CHARGE indicator starts
flashing, the rest of the procedure
must be completed within 1 minute.
3 Handset:
Press {OK}, then wait until the handset
beeps.
For futher information, see the phone manual at: http://dl.owneriq.net/3/3cd5d5a0-865d-4a28-8a1f-91f144108d9d.pdf
Mar 22, 2011 | Panasonic Computers & Internet
I have the phonemate 2970 answering machine/phone and satellite extension phone. When I turn the sat phone on I get a series of beeps and the HOLD light flashes for about 6 times then shuts down. I...
1. Remove the AC adapter plug from the back of the base unit (not from the wall); leave tel cord connected.
2. While holding down the "set code" button under the cassette lid, plug the ac adapter back into the base. The screen will then display some numbers (110) etc.
3. Hold down the HANDSET keys 1 and 2 simultaneously and then press the speaker button on top within 20 seconds.
4. Press any 3 digits on the handset i.e. 1-2-3.
5. After hearing a BEEP from the handset and base, press 2 on the handset. The base should then say "twenty-five", and the handsets will beep, confirming the new security code is enabled. Press talk or speaker on handset to confirm communication.
6. The time/day stamp and remote access code will be cleared.
7. Best to do this with the answering mach turned off.
8. Restart this procedure if anything goes wrong (may hear a series of error beeps).
I saved my manual and in it I had a fax Casio sent me with these instructions (i had this prob a few times years ago). Good luck!
Jan 18, 2011 | Casio PhoneMate PMP3875BK
My uniden DSS7855 with 1 base station and 3 handsets wont connect when i dial a number and hit the talk button it tries to connect and then comes up "'out of range" much appreciated for any help...
  1. To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.
  2. It will now be de-registered from the base.
  1. To de-register all handsets from the base, remove power to the base, and remove the handset from the base.
  2. Press and hold the 'flash/find hs' button while applying power.
  3. Wait for the beep and release the button.
  4. The charge light will now flash.
  5. Sit any handset in the cradle.
  6. When the flashing stops, re-register the handsets to the base.
Nov 12, 2010 | Uniden Lands Phones
My vtech cordless reads out of range or no power at base, what is wrong?
Official solution to this issue:
Make sure base station serial number matches all handsets serial numbers.
If they don't match you will have to de-register the units.
De-register the base station by holding the find handset button for 10 secs or until the In Use light illuminates, release the button and then tap it once more. You should hear a short beep followed by a longer beep.
Press Menu Select and the press the following without pause - *7890#
You should now see Test Base at the top of the screen press the Vol up button until Test Handset is present.
Press Menu/Select and you should see SW Version displayed. Press Vol up button until you see regstr clear, then press Menu Select and then Menu Select again.
At the handset remove the battery for 15 secs and then place the battery back into the handset. You should see 1. Place handset ... 2. press # on the handset screen. DO NOT FOLLOW THE ON SCREEN DIRECTIONS.
Next place the Handset on the base station and press the find handset button for 4 secs until the In Use light shows up. Remove the handset and press the # button.
Your handset should now display Handset 1. You can do all the other handsets the same way.
Hope this helps!
Jul 25, 2010 | Vtech 9009111 Cordless Phone
Can not rec a dial tone, phone states no link to base move closer
If “No link to base. Move closer to base, try again.” is displayed
even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
• Make sure the base unit is not being used.
• Have both handsets and base unit nearby during registration.
• Follow steps 1–3 listed below. You have about 1 minute to complete them.
• Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
If you re-register the handset using the other handset’s extension number, the other handset will not function.
• If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
• You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
• The CHARGE indicator flashes.
2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
handset which has lost the communication.
3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
• When registration is complete, a beep sounds from the handset and the display shows the number.
• Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
Feb 23, 2010 | Panasonic KX-TG2357 Cordless Phone
Just bought an additional handset for GE 27951 expandable 6.0 DECT Cordless. I press and hold the Page button for 5 seconds but the new handset will not register. Error keeps occurring "no base."
This exact thing happened to me. Same model number. No matter what I did, the new handsets would not register.
The solution? Reset the entire system:
1. On the BASE - Unplug from wall both power and phone line. Unplug battery from base handset.
2. ON the Extension phone - unplug from wall and unplug battery from handset.
3. Wait AT LEAST 5 minutes.
4. Plug back in BASE power.
5. Plug back in BASE phone line.
6. Plug back in EXTENSION handset battery. Don't plug in BASE handset yet.
7. Follow steps to program EXTENSION. When successful:
8. Plug back in BASE handset battery.
Apr 02, 2008 | Lands Phones
Office Depot Ativa D5772 Phone Logo
293 people viewed this question
Top Office Depot Lands Phones Experts
ashburton
k24674
Zelio Picanso
Are you an Office Depot Lands Phone Expert? Answer questions, earn points and help others
