Question about LG CHOCOLATE VX8500 Cellular Phone
Keypad wont work
Keeps saying to unlock push slide key but goes right back
  • jimbomedic Dec 31, 2007
    keeps saying to unlock push slide key but go right back to begin locked everything lights up but that it
    Brigadier General:
  • 7,752 Answers
You need to do a master reset of the phone to set it back to the first time you purchased the phone.
That should correct the issue, if that does not help then have the keyboard an dnot the keypad replaced from any mobile service center or professional mobile technician
Posted on Feb 10, 2008
Buttons on control panel do not always work. Some work correctly, others not at all. Please advise solution
I have this oven, and had the same problem..only after a time it got worse..eventually all the buttons did not work. The problem is the keypad itself. It is very easy to change. Remove the 3 screws along the top of the oven. Then the vent pane will slide to the right. You will then see 1 screw holding the entire keypad assembly. Unscrew that, and the keypad will angle forward. There are 5 connections holding it..unhook all of them (you might need to, write on a piece of paper where they go)..BUT, you can try this first, reconnect the ribbon to the keypad by sliding the locking plastic up and then slide the ribbon out..then reinsert it back down as far as it will go. Push the locking plastic back down. Reverse the the screws back..and try it. If it works great, but it may not last. You can order just the keypad (here's the issue, it costs about $171) and replace it by removing the 4 screws holding the circuit board over it. The new pad just snaps into place, reattach the new ribbon. I think the problem is because the steam when cooking goes right to where the keypad is. My oven is over the range..so now I use the vent fan all the time..hope this helps. If you need better instructions..search YouTube with you GE model and the words replace keypad.
Dec 30, 2015 | GE JE1640 Microwave Oven
Tip
How to lock or unlock a Samsung Intensity
Many people like the Samsung Intensity because of its slide-out QWERTY keyboard. However, one drawback to the phone for some users is that, unlike a flip phone, the numeric keypad is always exposed. When the Intensity is kept in a pocket or purse, this can result in accidental phone calls, multiple all-black pictures, and sudden activation of the voice command feature.
Luckily, you can lock the phone's keypad to keep it from engaging any functions when you're not using it. Locking the keypad is easy. Just hold down the 0 (zero) button for about two seconds, and a message will pop up telling you that the keypad has been locked. While it's locked, you won't be able to use the numeric keypad.
The standard way to unlock the phone is to press the upper right options button (the one that you would typically press to bring up your Contacts list) and then press the center OK button. (You will see prompts for both of these buttons when the phone is locked.)
However, there is also a quicker way to unlock the phone -- just slide the keyboard open. Sliding the keyboard open will unlock your numeric keypad immediately, and even when you close the keyboard the phone will remain unlocked. If you want to lock it again, you'll have to hold down the zero button to re-lock it.
You can also enable Auto Key Lock mode, in case you think you'll forget to lock your phone. With Auto Key Lock mode turned on, your phone will automatically lock itself when it's not in use and the backlight goes off. You can turn Auto Key Lock mode on or off from the Phone Settings menu.
on Jun 28, 2010 | Cell Phones
How can i unlock my nokia 5800 . i slide the keypad down and it says ''slide keypad down to unlock '' i even took the memory card and battery out but still doesn't work ?
In Nokia 5800 there is slider key on left side wall of you handset.Press and drag it to down ward once to Unlock and to Lock Drag it once again .
Aug 16, 2011 | Nokia 5800 XpressMusic Smartphone
Cant open my programmable key pad safe. the code wont work
Locksmiths agree try replacing the batteries just slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Aug 12, 2010 | Sentry Fireproof Safe
When I key in the pin it says to proceed but the bolt wont open. do I have to change the batteries? If so, how do I change it? My safe is a fire safe S0607
Locksmith advice on how to install sentry safe batteries
Aug 10, 2010 | Sentry Fireproof Safe
The wired keypad shows key lock on it and we do not know how to unlock the keypad
Push and hold the lock button until the light goes off. If that doesn't work, unplug the A/C and don't plug it back in for 30 minutes, that should clear the lock feature.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Mitsubishi Heating & Cooling
Samsung keypad locked
Samsung UpStage SPH-m620
UNLOCKING YOUR KEYPAD
theirs a button that you slide up and down. ... (you may try to push it but it wont work... you need to slide the button.) I had to go to my sprint store to figure this out.. :)
Jan 29, 2009 | Samsung UpStage SPH-m620 Cellular Phone
G600 keypad not working
Take your phone to your local market & ask any market phone repair vendor to fit a new keepad membrane, if this doesn't work it's trobably irriparable damage either caused by water or the fumes of some kind of solvent for example super glue.
Nov 12, 2008 | Samsung SGH-G600 Cellular Phone
Unlocked?
Can you be more descriptive?
Dec 31, 2007 | LG CHOCOLATE VX8500 Cellular Phone
LG CHOCOLATE VX8500 Cellular Phone Logo
54 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
