Question about Quantaray QSX-DigiPro 8500 Tripod
Can't figure out how to straighten and level the camera
Once I put the camera on the tripod, I cannot figure out how to control the angle (heighth) of the shot - it seems there should be a screw to tighten, but I cannot locate it. I am afraid I have lost a part. I do not use it a lot, and cannot find the instructions. Any ideas?
  • mamacass65 Dec 31, 2007
    Thank you very much - I have the handle for the lateral movement, but it has to be a missing wing nut or handle for the up and down angle b/c there is an open hole that looks as though there should be a screw in it. I appreciate your help!
    Thank you, Buffalo! I am searching for a bolt / wing nut as we speak! I appreciate your response!
  • 625 Answers
If your tripod has extendable legs, at each juncture there is a sleeve nut and an "O" ring. One end of one of the legs looks like a drill bit chuck - a short length that is split in three places and tapered to fit into the nut. you extend the leg, then tighten against the taper to lock the leg. the center stem whether it is geared or just friction had a 1/4-20 or 5/15-18 thread with a right angled screw or wing nut. It may even be metric. If you don't have the wing nut, a standard bolt will work.
Posted on Dec 31, 2007
    Sergeant:
    Champion:
  • 310 Answers
If you have lost a srew or wing nut, it will be loose where there should be one. set it up and then try to raise or move it around in one spot. iof it moves than look for a screw hole. the handle itself sets the rotation try unloosing the handle..
How adjust the vertical viewing
are you just mounting a camera to the tripod itself? - you need to purchase a head as well - the head screws onto the top of the tripod, and then the camera fixes to the head, usually with a qr plate.
May 05, 2014 | Manfrotto Photography
Ravelli Ballhead Tripod APGL4 quick release issue
Hello, I have this same problem and I am at my wits end, can't figure out how to get this thing off! Have you figured it out as of yet!?!?!
Dec 12, 2012 | Ravelli APGL4 New Professional Tripod with...
Bubble level for Manfrotto 475B
Not quite sure what you are hoping to achieve here - the bubble is to help you level the tripod, and by its very nature when centred will indicate this. Once you have levelled the tripod, adjust the head (pan and tilt, or ball and socket) until the camera is also level. It is possible to purchase a three-way level that fits in the hot shoe.
Aug 05, 2017 | Manfrotto 475B Tripod
Sunpak 5800d tripod quick release plate. What is the correct position to mount it on the camera and the tripod? Also what is the push button on the plate and how is it used? Thank you
Go to this site and look at the plate mounted onto the tripod, do it that way, so the bubble level is on your side, and the second little push button opposite of you. The second button is there for larger cameras, many video cameras mostly, that have two holes on the bottom, to keep them from swiveling side to side on the plate. Also, makes it easy to ensure you put it on right in the dark, the extra button should go toward the lens. :o)
Apr 12, 2011 | Sunpak 5800D Tripod
How do you level your camera inclination (left and right) in order to level camera when tripod is on unlevel ground?
Hotshoe mounted spirit level ($10 -$20 USD) or Bogen distibutes a head leveler, similar to those found on surveying instruments.Approx $100USD)
Feb 16, 2011 | Sanford Davis & ProVista Airlift Tripod...
Once the camera is attached to the tripod, how do I remove the plate with camera still on it?
There should be a release button or lever at the back or bottom of the top plate to release the quick release
Feb 05, 2010 | Tiffen Kodak Gear Mid-Size 60" Tripod with...
Need manual for kodak Gear Tripod 60'' or instructions about it's
Look at the bottom of your camera and you should see a hole where a screw would screw into. That should be the screw on the top of your tripod.
Mar 17, 2009 | Tiffen Kodak Gear Mid-Size 60" Tripod with...
Tripod plate leveler thumb screw
Try tripodquickrelease.com. They sell some repair parts for velbon tripods.
Feb 27, 2008 | Velbon Victory 550 Grounder Tripod with...
Tripod hlep
Did you grab the hand screw on the bottom of the head? Loosen it and the head will swivel to level.
Sep 15, 2005 | Vinten ProTouch Pro-6DC Tripod
Quantaray QSX-DigiPro 8500 Tripod Logo
227 people viewed this question
Top Quantaray Photography Experts
JP Services
JP Services
jd83854
R.A. Ellis
R.A. Ellis
Are you a Quantaray Photography Expert? Answer questions, earn points and help others
