Maytag Neptune FAV6800AW Top Load Washer
Problem for Maytag Neptune FAV6800AW Top Load Washer
Model FAV6800AWW will not pump water out if
By harrscot on Oct 25, 2009
Model FAV6800AWW will not pump water out if clothes are in machine but if I take out clothes, the water pump comes on and the machine pumps out water and spins. Codes DC and UC come on when it it is time to pump out water and spin when clothes are in machine, but it won't pump out water or spin
Best Solution
posted on Oct 25, 2009
Very Helpful)
FAV6800AWDIY
Rank: Guru  Maytag Washers & Dryers  Expert
Rating: 96%, 36 votes
I’m an owner of the machine and know it quite well. If the One-Way roller clutches in the clutch pulley hub and the upper roller clutch assembly (if your series use’s it) can be cleaned up and re-lubed you can be back in service today. See this post Clutch Fix. My roller clutches failed at the 3.5yr mark Dec 08 causing dc/UC errors for any size load. I cleaned up and re-lubed and it worked fine. I replaced the clutch to try this clutch assembly back in Feb 08 25001169 to see if it would work it does and I recommend it to all owners for your and mine FAV6800AW and the LCD flavor of this machine the FAV9800AW. The clutch will work for all series of those machines. If you have basic mechanical skills and want to save money try to clean up the roller clutches and re-lube or replace for $60. If you call in a repair service I think you will be in the $300 range to repair. I have changed my nickname from dh1200s to FAV9800AWDIY I have many postings on the clutch subject at this site and Fixitnow.com where my Clutch Fix posting has been posted for these machines.
Good Luck and post back if you need help to DIY. …. Rich
Comments:
Oct 25, 2009
- harrscot,
Thank you for the testimonial I hope you can give it a try it's a bit of tight work area but it can be done by many folks that want to roll up their sleeves and give it a try and save some $big money$. I almost junked the machine and then common sense kicked in….. $1K machine 3.5 years old. I began my education on the machine, anyone with basic skill sets can do this. I will offer to help speed up the learning process.
This machine also suffers from Left Lid Lock corrosion issues. You will see OP,OD,FA, LO error codes down the road. The DIY’er can handle these issues also. The Left Hand Lid Lock troubleshooting is for all of those error codes, here is a heads up of possible issue down the road.
Left Hand Lid Lock Troubleshooting
Also become familiar with entering into service mode and reading the diagnostic code blocks. So many posters to the FAV6800AW don’t post the machine model type or error code observed. You are on the ball. It’s a pleasure to help forum members such as you with solid info.
I forgot to post these links for you.
The Service Manual for reference. Sears Parts Direct for reference.
Schematic for the FAV6800AW and FAV9800AW
Wiring information (series 10)
Wiring information (series 13)
Wiring information (series 15)
Good luck Rich.... aka dh1200s
Nov 01, 2009
- joepereira Good job !!! Call a DIY’er ASAP and save a BIG $. I feel bad for folks that pay out $300 to $400 for clutch a repair. I had the WD-40 and bearing grease on hand so it was hard to put a cost estimate on it. $5 maybe $10 max. If you ever have to replace the clutch as I mentioned this Clutch will work for all series FAV6800AW and FAV9800AW. Again hats off to ya. Thumbs up to ya.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Very helpful. Thank you " - harrscot
Solution #2
Very Helpful)
57 varieties
Rank: Guru  Washers & Dryers  Expert
Rating: 88%, 627 votes
The DC & UC errors indicate that there is a a clutch malfunction. The machine shuts down and will do nothing while these errors exist and shows that the Tub Displacement Sensor is working as designed.
The Clutch Assembly malfunction is usually corrected by replacing the clutch assembly and there is no work around for this problem.
Call a repair man to do the work asap.
Was this helpful?
Yes
No
Asker's Testimonial
" Thanks...hope it's worth fixing...it's been a bit of a problem " - harrscot
Solution #3
posted on Oct 29, 2009
Very Helpful)
joepereira
Rank: Apprentice
Rating: 100%, 1 votes
I removed the lower clutch with the bearings cleaned them and greased the bearings. With the front and top covers off, I put the machine in spin mode and all seemed to work great. So I closed everything back up, replugged the machine in and started a small load in quick wash.. YAHOO IT WORKED GREAT!!! I saved a ton of cash and no one was needed to come help. Yes, its tight quarters to work in so be prepared to put something down over the lower sheet metal it might cut your arms... Joe
Was this helpful?
Yes
No
Popular Solutions for Maytag Neptune FAV6800AW Top
Questions and Unsolved Problems for Maytag Neptune FAV6800AW Top
Do you recommend Maytag Neptune FAV6800AW Top Load Washer?
Answer
Answer
Washer smelly musty and moldy. How can I get the smell to go away? Is there something we can take... (More)
Answer
Our washer stops at the spin cycle and doesn't cycle off?
Answer
Roper SM8280871 washer - Spin cycle seems fast enough, but the clothes are still somewhat wet. Have... (More)
Answer
Maytag neptune top load washer stops due to false lid open fault.
Answer
noise when it should first be filling with water noise willgo away when the water starts to go in... (More)
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
