Question about Kenwood KDC-MP228 CD Player
Vrvd630 car stereo
From car i have graywire -red(ign)blu/yellow-yellow(12v)br-bl(grnd)then rd/bl-blu(ant)also pnk/blu?where does it go and then theres green,black and a brown wire and i have brown(park brake)orange(rev/light).i've blown 3fuses replaced them and started all over,disconnecting neg from batt.hooked everything back up and reset the radio but ican put a cd/dvd in the unit but i have to reset it over to eject and i'm getting no radio power,,please help.
  • 78 Answers
SOURCE: kenwood kdc 3011 rests its self every time i turn the car off
This means that the power lead you connected the red and yellow to is a switched live and each time you turn off the ignition the power goes off and therefore resets. to fix this problem you need to connect the yellow to a permanent 12v supply that stays live when you turn off the ignition.
Posted on May 28, 2008
  • 50 Answers
SOURCE: wiring instructions for kenwood kdc-mp8533
dark blue is the remote for the amp
light blue is the remote for a power ant. (or amp)
orange is for the light dimmer (when you turn your lights on it will not be so bright, optional)
black is ground
brown is if you have a button in your car for a cell phone it will mute it when pushed (optional)
red is power (acc power)
yellow is always on power(for the clock and presets)
the rca jacks are for the amp they should be used if using an amp (there wattages are preset for amps anyway)
hook up the rca's to your amps along with the dark or light blue wires and when you turn the stereo on the amp will come on everything else should be hooked up as stated above. Hope this helps.
Posted on Jun 08, 2008
  • 113 Answers
SOURCE: Kenwood KDC-119 car stereo problem
sometimes, if you unplug the main radio harness out from the back of the radio-leave it unplugged for about a minute you can reset the electronics that are now locked up- after you plug the harness back in you shoud hear the cd mechanism moving- now press the eject button- if there is no mechanical problem the cd will eject. If it won't you can email me at or call me at (908)756-3544 if this helps you please give me a good rating
Posted on Jul 02, 2008
  • 306 Answers
SOURCE: the yellow wire doesnt work
probally have a bad fuse in the fusebox. check there first.
Posted on Feb 07, 2010
  • 256 Answers
SOURCE: I have an old Chevy and I'm trying to hook up my
The fact that your speakers have only one wire, indicates that they are the old negative ground type. You will have to buy new speakers, or try and connect the negative wires of your speaker wires from the radio to the car body (chassis) and try that. Normally you will get a bit of static when you start your engine
Posted on Jun 09, 2010
  • 70 Answers
SOURCE: i have a VRVD630 i cant watch dvds because i dont
the parking brake wire just needs to go to a ground other than the ground for the deck and the orange reverse light wire you shouldn't have to worry about it if you turn on the deck and you still can't watch movies try hook it up to the illumination wire.
Posted on Jul 29, 2010
0 characters
1 Points
Jvc car stereo KD-R570 flashing red
To test radio to see if its working you can bench test it. This means to combine red and yellow and run to 12V positive and Black to 12V negative. IF radio turns on, it would mean its working.
Aug 04, 2014 | JVC Car Audio Receivers
I just bought a DEH2400UB car stereo to replace factory stereo in a 2001 PT Cruiser. I went to Best Buy and got the wire harness kit. Wire colors are not mactching up and I need help connecting to the...
If you bought a Pioneer receiver, you should know what its connections are. Adapter harnesses sometimes do not have the same color wires, BUT the connections are correct. In the 2001 PT Cruiser, the LF speaker wires are DK GRN (+) and RED/BRN (-). The RF speaker wires are VIO/DK GRN (+) and DK BLU/RED (-). The LR speaker wires are BRN/YEL (+) and BRN/LT BLU (-). The RR speaker wires are DK BLU/WHT (+) and DK BLU/BLK (-). A RED/WHT wire supplies power to the radio when the ignition is on and a PNK wire is a fused B+ input which is always hot. An ORG wire provides panel illunination and a BLK/YEL wire from the headlamp switch prevents the panell illumination from turning on unless the parking and/or headlamps are on
Dec 11, 2012 | Pioneer Car Audio Receivers
I installed an older used stereo. I found the red wire is power, the black is ground, What is the yellow wire with the 5amp in line fuse for
The Yellow is your Ignition wire, It controls the stereo power when the vehicle is on/off. It can be spliced with the red wire, however I wouldn't suggest it unless all other options have been used.
I need diagram wiring from 1994 Honda accord to pioneer deh-p6500 stereo
Hello my name is Israel. The following diagrams should be able to help you out. The first is for the honda and the second for the stereo. Good Luck.
Constant 12V+ Blue/White Switched 12V+ Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Trigger Yellow/White Antenna Left Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6" x 9" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White
Feb 22, 2011 | Pioneer Car Audio Receivers
How to hook up without connectors
car colors
yellow 12v switched
orange 12v con
green rf-
lite green rf+
grey lf- paired with tan
tan lf+
blue rr+
lite blue rr-
yellow lr- Paired with brown
brown lr+
pink pwr antenna
brown alone illumination
grey alone illumination dimmer
black ground
radio wires
purples rr
green lr
grey rf
white lf
red switched
yellow 12 con
bluewhite stripe ..amp turn on
blue power ant
black ground
hope it helps
I am installing a stereo in my car and the previous owner cut the wires and the labels are gone. The stereo I am installing has 4 wires other than the speaker wires. They are: +Battery(Yellow), ACC (Red),...
Here you go.
Radio Side -- Car side
12v (Yellow) -- Orange/Black
ACC (Red) -- White/Black
Ground (Black) -- Black or chassis ground(bare Metal)
Pwr Ant (Blue/white) -- Pink
If your not adding and amplifier than your system remote should be used for power antenna which is the pink.
Hopefully this helps
Please Vote & Rate thx
Mar 08, 2010 | Pioneer 50W x 4 MOSFET Apple iPod...
Need to wire a new car stereo for ford 1991 fairlane i am having trouble working the colour coding of the old wires as alot of the new colours are different
colors are:
gry/grn + gry/blk -> rt frt
org/grn + org/blk -> lt frt
blu/red + blu/blk -> rt r
pnk/grn + pnk/blk -> lt r
+12V - grn/yel
+12v switch -> blu/wht
ant: ( if you have it) -> red/blu
lights: brn
earth- > blk
Sep 16, 2009 | Pioneer DEH-30MP CD Player
1998 ford el xr6, need stereo wiring harness colours
You did not specify if you wanted the wiring diagram for the Expedition or the Explorer, so I got you both. Good Luck
1998 Ford Expedition Stereo Wiring
Constant 12V+ White/Purple Switched 12V+ Black/Pink Ground Black/Green Illumination Blue/Black Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Light Blue/White Left Front (-) Orange/Light Green Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 6" x 8" Rear Doors Left Rear (+) Tan/Yellow Left Rear (-) Gray/Light Blue Right Rear (+) Brown/Pink Right Rear (-) Orange/Red
1998 Ford Explorer Stereo Wiring Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Door Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Feb 22, 2008 | Car Audio Receivers
I need a wiring diagram
to what car is it being fitted?
standard stereo wireing is as follows:
+White -White/black Front left
+Grey -Grey/black Front right
+Green -Green/black Rear left
+Purple -Purple/black Rear right
+12v Con Yellow
+12v Ign Red
+12v Antenna Blue
-12v Return Black
Tele mute brown
Illumination Orange
Hope this helps somewhat.
Dec 22, 2007 | Car Audio Receivers
Kenwood KDC-MP228 CD Player Logo
201 people viewed this question
Top Kenwood Car Audio Receivers Experts
xxxxxx xxx
Pablo Gonzalez
Are you a Kenwood Car Audio Receiver Expert? Answer questions, earn points and help others
