Question about Dishwashers
Roper dishwasher model "wu3000v2"
Where does the jet dry go?
  • znaut Dec 31, 2007
    Where does the jet dry go in a roper dishwasher model "wu3000v2?" I moved into a house that has oine and the dishes are always spotty. Someone told me to use jet dry but I do not see a place for it to go.
    Zargonaut
    President:
  • 1,314 Answers
Open the cover on the place where you put
the soap. There you should see a round piece that you turn and pull out fill the reservoir with jet dry. Once it's filled put the plug back in it should be good for 30 washes. Most have a sight glass that will turn from green when full and clear when empty jet dry will help.
Posted on Jan 01, 2008
My dishwasher do not dry the dishes
First, make sure you are using Jet-Dry (or equivalent) rinse-aid. As part of this "green", ecological, environmentalist-wacko movement, dishwasher makers have cut down on the amount of heat generated by the heating element, and as a consequence, it is now imperitive that you use rinse-aid to help with the drying. Note: Finish Corp (the makers of Jet-Dry) now make a version called "Turbo-Dry". Try that (if you can find it). If you try that, and it still won't dry, then you may have a bad heating element, or else a bad controller.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Mar 16, 2012 | Kenmore Dishwashers
Dishwasher does not dispense jet dry. Is full all the time
If the jet dry dispenser is full, it will last you about 3 or 4 months depending on how often you use the dishwasher
Nov 09, 2011 | Maytag Dishwasher
In my GE dishwasher, the jet-dry in the dispenser turned brown. I emptied it all out and refilled it with clean jet-dry, but a few weeks later it was brown again. I guess somehow dirty water is getting...
Had the same problem, opened up the dishwasher, pulled out the jet dry container and found some kind of nasty growth in it. I honestly have no idea what it is, so of course I took a picture, and then threw the whole thing away._1813.jpg
Jul 17, 2011 | Maytag Dishwasher
Cycle isn't using Jet Dry
Open up the dispenser and there should be numbers inside[use a flashlite] change the setting to a higher number and try that!!
Jun 17, 2010 | Hotpoint 24 in. HDA3400G Built-in...
Our glasses are coming out with a cloudy film all over. How do we remove and prevent? Dishwasher has plenty of rinse aid.
remember all the dishwasher needs is 1. dishwashing soap. 2.the hottest water going to the machine. 3.the jet dry must be filled completely,some model you can turn up the jet dry is needed. hope this helps.
Mar 12, 2010 | Bosch Evolution 800 SHE58C05UC Stainless...
Soap not breaking down in dishwasher
Be sure to run kitchen water hot at faucet before starting dishwasher or you will get an entirely cold water washer. Also be sure the jet dry dispenser is not empty. Only use liquid jet dry. Pay no attention if soap says with jet dry. Does not work as well. Hope this helps.
Jan 31, 2010 | Frigidaire 24 in. FDBB840DC Stainless...
Bosch dishwasher leaves water at the end of its cycle cleaned filter and the impeller seams free and not blocked
check for over sudzing. dont use a cascade with jet dry in it. use regular dishwashing liquid and fill jet dry compartment. you can even jet dry level by turning the knob in dispenser.
Nov 12, 2009 | Bosch 24 in. SGS43C12 Classixx...
WHERE DOES JET DRY GO
the turn nob is a cap that you screw out and pour your jet dry liquid in then replace the nob/cap the jet dry will be dispensed automatically.
Sep 29, 2009 | LG Dishwashers
We bought a used Roper dishwasher not too long
I was having the same problem with a Roper dishwasher and the Palmolive Eco gel. After doing a little research, I found that the detergent I was using doesn't work well with hard water. I emptied the machine, then poured in 2 cups of white vinegar and ran it on a complete cycle. This cleaned out any hard water residue build up inside. I then begin using electrasol with jet dry tablets for detergent and filling the rinse agent reservoir with white vinegar. I have had no problems since.
As for the heated dry, is it really heating or are you just feeling the heat left over from the very hot water used in the washing and rinsing?
Jun 12, 2009 | Dishwashers
Where do i put jet dry
Check page 2, number 2 in the owner's manual...
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=DC4000&siteCd=MCF
A liquid rinse aid dispenser is only found in select models. Yours may not have a dispenser.
May 16, 2009 | Magic Chef 24 in. DC4000 Free-standing...
Dishwashers Logo
172 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
