WHIRLPOOL MODEL ED5NHA NOT MAKING ICE, IN DOOR WATER DISPENSER WORKING FINE, ICE CUBES ARE IN THE MOLDING TRAY, BUT WILL NOT GET EJECTED. FILL TUBE DOES NOT APPEAR TO BE FROZEN?
You may check the coils under the front of the refrig , to make sure they are clean of dust , lint , pet hair , etc . If the coils are not clean , it will raire the freezer temperature so many degrees , to where you will not be able to tell the difference , but warms enough (6 degrees or highter ) , to where the ice maker will not dump . Ice maker needs to be 5 degrees , to harvest ( dump ) . If clean , then "sea breeze" solution , would be the next step .
Most likely the thermostat # 27 in photo below is defective. It tells the ice maker to begin its cycle by sensing the water is frozen. It is a replacale part.
Photo of thermostat 627985
You can see or order the thermostat Here 627985
Or you can order the complete Ice Maker Here 2198597
If you need more help feel free to let me know, Thanks Sea Breeze
the crisper drawer supports on the front have broken off how do I get them out ? fridge model #...
(More)
the crisper drawer supports on the front have broken off how do I get them out ? fridge model # FRS6LR5EW5 I found the replacement part here http://www.searspartsdirect.com/partsdirect/showPart.pd?partNumber=240423701&productGroupId=0046&supplierId=253&brandId=1428&documentId=R0608036&keySuffixId=NA&modelNumber=FRS6LR5EW5&keyId=0100&pageId=00003&productTypeId=0165000&searchModelNumber=FRS6LR5EW5&subCompDesc=Cabinet&brandDesc=FRIGIDAIRE&modelDesc=REFRIGERATOR&blt=11 but cannot remove the old ones. please help!
I have replaced my water filter several times to no avail. We have constant leakage from the filter...
(More)
I have replaced my water filter several times to no avail. We have constant leakage from the filter area. At first I thought the new filters were defective. (replaced 3) I have followed the Frigidaire manual when replacing the new filter...and gone through all the recommended steps...HELP !!
