Question about Mercury PVCLE266 Motherboard
Im trying to enter to my computer bios screen but
Im trying to enter to my computer bios screen but it dosent work useing f1 what to do i have motherboard mercury pvm266
  • 43 Answers
Press delete or what command it says... to enter bios set-up
Posted on Oct 25, 2009
SOURCE:
My gateway is stuck in configure 3 of 3 at start up
Turn on your computer. If your computer is already on, then reboot it. You need to see the initial display screen to get into the BIOS. Press the F1 key immediately in one second intervals when you see the initial screen displaying the BIOS provider information. The majority of Gateway computers use the F1 key. If, for some reason this does not work, then use the F2. All of Gateway's desktops use the F1 or F2 keys. this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart. Hope this helps.
Jan 22, 2013 | Gateway Computers & Internet
Cannot enter bios in the standard way with F2. I believe IDE controller is set to disable
hope this helps
Sep 17, 2012 | Gateway GM4019E PC Desktop
I have a hp p6203w how do I enter bios
"HP
Pavilion:
Method 1
Enter the BIOS: Press F1 during the blue HP screen for setup.
In the BIOS: Advanced to Peripheral Configuration to Parallel Port Mode. Use ENTER key to open menu and select EPP. Press F10 to save changes and exit.
Method 2
Enter the BIOS: Press F1 during the HP boot-up screen for setup.
In the BIOS: Advanced to I/O Device Configuration to Parallel Port Mode. Use ENTER key to select EPP. Press F10 to save the changes and exit."
source: http://www.easeus.com/disk-copy/faq1.htm
Apr 08, 2011 | Computers & Internet
How to enter bios setup, need to change boot option
try the delete key if that does not work try the f2 key
Jan 31, 2011 | EliteGroup RC410L/800-M2 (V1.0)...
Iam at black screen that said F1 to resume i pressed and sendme to bios utility how can i go back to regular screen windows
What was the error-message just BEFORE that 'F1' message?
Turn the computer off, wait, and turn the computer on.
If you get into BIOS SETUP,
use the "arrow" keys (UP, DOWN, LEFT, RIGHT)
to highlight the 'Load BIOS defaults' menu-item.
Press ENTER to apply that option.
Use the arrow keys to select "Save and Exit from BIOS setup".
Press ENTER to apply.
Oct 24, 2010 | Computers & Internet
How do you get into the bios on a 785gt-e63 msi motherboard? read the book it said at start up press f1 did not work.
As soon as you turn on the computer start tapping (not fast, but steady) the F1 key, you could try F2, DEL, and other various keys that work on other boards.
Usually the screen will show you what to press in the corner or somewhere on the screen.
F12 for boot / F2 for BIOS / etc
Or it might say Press F1 or F2 or something to enter Set-up.
You have to catch it before the computer starts to boot into your operating system.
At this point you can push the power button for half a second and the computer should turn off instantly as you have not started booting up the computer.
Then you can try another key to enter the BIOS.
After locating the manual and skimming through it, I see that it states you need to press the DEL key to enter setup (BIOS).
Hopefully that helps.
Aug 26, 2010 | Intel Motherboard
Cpu doesnt recognize new drive
ok i may be able to help, first of all i must ask if you plugged the cables in correctly and didnt forget the power connector.
secondly, have you been into the BIOS and checked weather or not the device shows up there? to access the BIOS (basic input output system) usually you have to repeatedly press the delete button or F1 button as as the PC boots up(before windows loading screen). If you see the device in the BIOS then you should unplug the drive and return it to it manufacturer. If it does show up in BIOS, also check to see weather the drive is compatible with your current version of windows, this also includes the service pack you have installed. if the device does not show up in BIOS then check the cables again, check for any phsyical damages and return to manufacturer. if this dosent help you im sorry, but theres not much you can do if hardware decides it dosent wanna play.
Mar 14, 2009 | Lite On Lite-On LH-20A1L-06 SuperAllwrite...
Entering BIOS settings, Easy-Access, after POP, with external KB
The Power On Password problem is near impossible to crack. It is designed to prevent unauthorized access to the Thinkpad and removing the BIOS battery will not remove the password because the password is stored on an EEPROM chip.
There are no backdoor passwords available, the only option is to ask the person who set the password.
OR
There is a way to hack into the Thinkpad to see and remove the password but it requires electronic skills, a program and a working computer.
For details on how to do this go to :-
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Feb 03, 2009 | IBM ThinkPad 600X Notebook
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
Mercury PVCLE266 Motherboard Logo
210 people viewed this question
Top Mercury Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Davit Mamyan
Davit Mamyan
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
