Question about Frigidaire FWS445RF
Frigidaire FWS445RBS loud agitator noise
The agitator noise on my washer just started getting louder. It's kind of like a knocking noise. The agitator is working properly. Is the motor going bad?
  • Charlie4345 Jan 01, 2008
    I just noticed the spin cycle does not work now. The washing machine went through the cycles, the water drained, however the softener did not dispense and the spin cycle did not work. Any advice?
I'm not sure...you've given me two different areas of concern. The first is the mechanical noise and then the nonfunctionality of the spin. That could be a pair of problems. Mechanical noise could be from any number of places. The fact that neither the spin nor the dispenser function occur could be the timer. If this is a mechanical timer (one you turn to get the unit to start), it probably is bad. I'd go there first. Once you get your functions back, then, find out where the mechanical noise is coming from. If the timer is expensive versus a service call...you might want to pay the service call, get your proper diagnosis and go on from there.
Posted on Jan 01, 2008
  • 833 Answers
The first thing I would check is whether the agitator is cracked. Often, there is a knob/nut you can remove to take the agitator out. If not that...you have a loose assembly or something in the transmission. Check the easy things first. Chances are that if you try to 'rock' the agitator yourself...it will show you that it is damaged.
Posted on Dec 31, 2007
Very loud noises
Check the rubber mounts under the compressor and look for any lines touching the sides of the cabinet. The gurgling and clunking are often normal. good luck. Roger
Jan 19, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Agitator drum is loose and making loud knocking noise
Hope this helps..The bearing has been worn out already connecting the drum..The washer might be too old or has been used frequently loading what is more than sufficient.loading excess more than its capacity..
Jun 19, 2011 | Frigidaire GLTF1670A Front Load Washer
Washer is loud, and won't spin or agitate
check the motor bushes,and also check for bearings in drum you can check this by lifting the inner drum up and down if you feel a knocking noise then this will be the bearings have worn.
Jul 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire tumble action frontload washer loud knocking noises
These are the stabilising blocks. They are there to stop the knocking and noise. You should be able to buy them. Try the manufacturer or go on Yahoo or Google search for wash machine spares. Hope this helps.
May 20, 2009 | Frigidaire 14 Cycle Tumble Action Washer
New washer, Maytag title, but RCA unit--knocks and clanks
Thank you for your complaint. It will be forwarded.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Washing Machines
Loud noise
it sounds like you have something stuck under the agitator thats causing a rubbing noise when it goes to spin or agitate.maybe a penny or something like that
Dec 28, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washer model PAVT244AWW agitation noise
Sounds like the motor is going bad. It will only get louder before it finally stops. There is a device that assists the agitation motion that may be bad or is going bad.
Dec 01, 2008 | Maytag PYE2300AY Electric Dryer
Front Loading Washer LOUD NOISE
IF IT ROARS LIKE A JET PLANE TAKING OFF, THE SPIN BEARING IS FAILING. PROBABLY, THE REAR SEAL HAS FAILED ALLOWING WATER TO GET INTO THE BEARING.
THE BEARING HAS LOST ITS LUBRICATION SO IT IS GETTING DRY. IT WILL CONTINUE TO GET LOUDER AND LOUDER THE LONGER REPAIRS ARE PUT OFF.
THE ENTIRE BACK HALF OF THE OUTER TUB WILL HAVE TO BE REPLACED. THE BEARING IS PART OF THAT ASSEMBLY. CAN BE A COSTLY REPAIR.
Apr 04, 2008 | Washing Machines
Knocking noise durng spin cycle
remove the agitator and inspect the main shaft on the gear box.and check the belt underneath.if the shaft is bend you will need a new gearbox. hope this helps.
Mar 26, 2008 | Maytag Dependable Clean Top Load Washer,...
Noise
sounds like there's something inside the tub, can you do a visual inspection and maybe run your fingers around the agitator..stranger things have happened.
Mar 04, 2008 | Frigidaire FLGB8200DS Top Load Stacked...
Washing Machines Logo
185 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
