Question about Koss EQ50 Home Equalizer
Bass frequncy I can't get a good bass sound. I record at EQ default settings then adjust them when mixing. The signal is always too lo and if I crank it the signal distorts. I am recording through a direct box to Zoom HD 8 track. The EQ's are EQ Hi G=?/ EQ Hi F=? EQ Mid F=?/ EQ mid Q=/ and EQ Lo G=/ EQ Lo F=
  • 31 Answers
Also bear in mind those are crappy eq's in that zoom, personal recorders are great but aren't known for pre-amp and eq quality, etc. If you're recording at proper levels and with no eq and there's no clipping on playback either then I would say you may be tweaking the eq more than it can handle when you use it. Try not boosting freqs so much, generally anything over a 6db. boost is drastic, especially with the lousy Q of cheap eqs. Try attenuating highs instead of boosting lows so much, I'm afraid yer just gonna have to live within the limitations of the equipment or get an outboard eq in front of the D.I. box and eq it during tracking or get an external recorder for mixdown and put the eq between the zoom and mixdown recorder and eq during mixdown. Here's a little trick that may help - when mixing turn the volume way down low for a minute till you can barely hear it then turn it up a bit more and see if the balance of the highs and lows is good, it will give you a general balance wich will sound good at higher levels. Volume level when mixing affects the way we hear, the frequency response curve of the human ear is totally nonlinear, we hear freqs differently at varying levels, mix too loud and it will tend to be bass light, mix too low and it will tend to be bass heavy, the fletcher munson equal loudness contour curves wich express the ears frequency response graphically, indicate that the nearest to flat response is at 85 db. spl
Posted on Aug 06, 2008
Check that the wiring to the monitors are in-phase: Pos. to pos., neg. to neg. - from the amplifier.
Posted on Jul 29, 2008
  • Winecellar Jul 29, 2008
    Also, if your negatives are not properly connected to the amp's negative but connected together instead, then they are "floating ground" which will kill the bass reproduction when the speakers are in phase. It gets even worse if you have this situation and the music source is monaural.
  • 185 Answers
Although I am not familiar with the Zoom HD 8 Track I am a former sound engineer so may be able to offer some general advice.
Firstly, because the wave pattern of low frequencies is very long, there are a number of things that will greatly effect bass response caused by standing waves.
1) The position of your bass monitors. Ideally these should be low down but not directly on the floor, especially if the flooring is wooden.
2) Try your monitors/speakers at a slightly different angle. Bass can bounce off walls, back towards the sound source and phase out the signal, rather like a noise cancelling system.
3) Try listening to the sound in different areas of the room. You will be amazed at how the sound pressure level will vary, simply by you moving from one position to another.
4) Never put bass tracks exactly at centre, always offset them slighly by a few degrees left or right.
5) Do some of your mixing using headphones, you will not have to worry about standing waves. But remember that things sound very different on speakers in free space.
Strangely, the reason you are getting distortion when you turn things up is probably because your bass is on the verge of over modulation to start with. Really bass is felt, not heard. You could try is to decrease your mid and high frequencies a little. The ratio between high frequencies and low ones will then increase by default and your bass may feel heavier.
What are you mixing?
Posted on Dec 31, 2007
What are the frequencies that the bass and treble controls on a Yamaha AX-396 amplifier control? I recorded alot of music direct from the amp to my pc with the bass and treble controls at max and need to...
The bass and treble controls (as well as volume) have no effect on the recorded output if you're using the traditional jacks a tape deck would use. Only PRE-OUTS get massaged by sound controls.
Even if you DID affect the recorded signals, WHY are you using such exaggerated settings? Or was it by mistake?
In theory, passing the modified output back through the same controls (set to Minimum this time) would undo most of the unwanted effect. Assuming their precise and mirror image for gain and loss.
Aug 23, 2011 | Yamaha AX-396 Amplifier
Creative zen xtra 60GB mp3 player question...
First thing I'd do is compare the sound coming from your MP3 player to the sound of the same songs playing from your computer speakers, to eliminate any possiblility of the audio files being at fault (I realise you haven't altered them yourself but they could be faulty at source)
Then check the graphic equaliser in your player and see what the current setting is. Most audio devices these days come with a range of presets and these often include a karaoke setting so I'd check thats not been toggled by mistake.
Then have a play with your EQ settings to see if you can bring the vocals back up in the mix, vocals tend to lie in the 1-2kHz range of the audio spectrum so give it a boost in this region. You might also want to try cutting the bass end, too much bass energy in a mix can steal your headroom and lead to parts dropping out unpredictably like this. N.B. if your player only offers EQ presets rather than a proper hands on EQ then look for presets with names like Mid boost or Bass cut, even a general POP preset should be OK, just avoid things like Dance, Hiphop and the like.
Dec 04, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Im a candidate sound engineer, im strugling to set the bass drum from the mixer. how do i set it?
Bass drum by convention is ch1 on the board.
You need a good drum and a good mic
First set eq flat and pfl ch1, set gain control so drum just hits peak/or red when hit hard.
Send ch to drum group (1+2) on board, or route to master (L+R), depending on type board. Then listen to drum ONLY through the system, and adjust eq so it sounds good at low level then turn it up and keep it sounding good.
If it keeps peaking the ch then turn down gain.
There are toys (inserts) you can use noise gates and compressors if available,
Sound is objective and can not be learnt without doing it , good luck. remember good low level sound will always be better than really bad lound sound, start low make it good then make it loud.
Good drums do not need much eq. Get the drum right first.
Hope this helps
Thanks for using FixYa
Aug 06, 2010 | Samson SX1200 Amplifier
I need advice on how to connect my very old BOSE 901 (with active eq) to this device: Martin Roland MA 3000K I see pre-out and pre-in but cannot locate main-in. Please help here is the back of its image:...
As you probably know, the Bose 901 Active EQ is there to modify the frequency spectrum fed to the 901's so they will produce a flat response. Without it, they sound acceptable in the midrange but lacking in bass. Since they have no woofers or tweeters, the modification is drastic and should never be applied to non-Bose-901 speakers or they could be damaged.
This setup should work for mixing and playing but I'm not sure if recordings directly from the unit's REC Out or Line Out would have the Active EQ effect on them. You'll need to perform a few tests to see how it all works for playback AND recording.
Remove the jumpers for Pre In >> Out
Insert the Active EQ in their place by running:
1. RCA cables from Pre Out to the Active EQ In (From Aux, Tape Out)
2. RCA cables from the Active EQ Out (To Amp, Tape In)
Use ONLY 901's on this amp with the EQ.
The Bose Active EQ has its own Tape Rec/Monitor loop to replace the one it normally occupies in a typical receiver application, so if you wish to record your mix you should use those connectors for your tape deck and there will be no problems with the Active EQ effect being recorded. The Monitor Tape/Source switch on the EQ functions just like a typical Tape Monitor. For playback of the recording, switch it to Tape.
The manual, available at http://lib.store.yahoo.net/lib/acekaraoke/MA3000K.pdf
doesn't get into any detail on the innards of the mixer.
In a typical integrated amp or receiver, the jumpers removed are between the Preamp Output and the Main Amp input, but BEFORE the amp's volume and tone controls, so manipulating them would not affect a recording. You should experiment with it by making recordings through both and adjusting speaker volume to see if it changes.
I would be curious to know what the functional difference is between the designated LINE Out, REC Out and PRE Out jacks in that regard. Normally, Line Out and REC Out will not vary with amp volume, but I expect in this mixer it does, or you wouldn't be able to control the volume from it. Experiment.
Of course, you probably want the mixed effects to be recordable, so I assume they'll appear at all outputs. Play back the test recording (at an initial low level, just in case) and see if you can detect an exaggerated low end (due to the 901 bass boost being applied in recording AND playback through the 901's. If the recording volume doesn't vary with speaker volume and the playback sounds as flat as the recording you're good to go.
If there is are volume variations or an additive effect, you may have to draw the REC Out to the deck's input and run the deck's output to the Tape In on the 901 Active EQ, monitoring only on deck playback.
Dec 02, 2009 | Bose 901 VI Main / Stereo Speaker
I want to know what an User EQ is?
Most Audio devices will allow you to adjust how the music is played. an EQ is just something that can increase or decrease audio Frequencies. there are usually preset EQ levels that will make Jazz, Classical, Pop music sound better. this is done by increasing the High notes or increasing the low notes to give you more of a bass sound. User EQ settings allow you to manage the frequencies more to your liking. If you want to here the high notes better or adjust the middle to hear the vocals better then you can increase those levels. Or if you love your bass sounds then you would increase the lower frequencies to give your music more boom.
Jul 29, 2009 | Coby Audio Players & Recorders
I can't figure out how to adjust the bass on the JVC KD-HDR30.
Hello hawk713, Like with many other JVC receivers, adjusting the bass is done from the "EQ" (equalizer) mode for one or all of 6 presets: ROCK, CLASSIC, JAZZ, HIP HOP, POPS, and USER. To adjust it, select the desired preset mode, use the left/right rocker (on volume control) to scroll to the desired frequency, 60, 150, 400, 1K, 2.4K, 6K, and 15K, and then turn the volume control up/down to set a level from -5 to +5. 60 and 150 adjusts the bass, 400, 1K, and 2.4K adjusts the midrange, and 6K and 15K adjusts the treble. Then you select whichever EQ setting sounds best with the particular music you're playing. Hope this helps.
Jun 06, 2009 | JVC KD-HDR30 CD Player
Having Trouble Accessing Bass and Treble Controls
Only parametric EQ OR Bass/Treble can be active at a time. There is a option to set which one you want, refer to manual. Follow this- Adjusting Sound Setting Mode (long press "sound-mode" button) -> EQ SELECT-> select either P. EQ or B/T
Feb 18, 2009 | Clarion DXZ785USB Car CD/ MP3 Player
I cannot get the functions on the remote to operate.ie pbass dsp/eq etc?
The P.BASS function is only available with 2 channel LPCM sources such as mp3,Divx,cd
and wma. Press P.BASS button and "POWER BASS ON" will be displayed on the screen.
The P.bass does not work with DSP/EQ or DOLBY PRO LOGIC ll modes.
If you press P.BASS in the DSP/EQ mode, the DSP/EQ mode is automatically shut off and the P. BASS function comes on.
The DSP/EQ function is only available in STEREO mode.
Press the PL ii mode button to show STEREO on the display.
This feature works with CDs, MP3-CDs, 2 channel DVD-Audio, DivX and Dolby Digital discs.
When playing a DVD disc encoded with two or more channels, multi-channel mode will be selected automatically and DSP/EQ function does not work.
Nov 04, 2008 | Samsung HT-Z310T Theater System
JVC KDG 340 Car stero
SOUNDS SETTINGS....OPRIME EL BOTON Q DICE EQ...EN LA PARTE SUPERIOR DERECHA....Y ADJUST BASS....PRIMERO OPRIMES EQ.....SELECCIONAS USER..Y LUEGO OPRIMES LOS BOTONES DE DIRECCION HACIA ARRIBA Y HACIA ABAJO..Y AHI SE LO PUEDES AJUSTAR
angel_lk2@hotmail.com
Mar 17, 2008 | Audio Players & Recorders
Cannot Set the Treble & Bass
I have an Alpine 9887 you have a different eq than just trebel and bass the only way to get you bass an trebel setings are to install the imprint stoftware now if thats the route you go it tunes your radio to what it thinks it should sound like it's for sound quality not for alot of bass been there done that I have the software but you need to take it to a good alpine dealer to have it installed good luck
Jan 05, 2008 | Alpine CDA-9887 CD Player
Koss EQ50 Home Equalizer Logo
125 people viewed this question
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Carlos L. Burgos
Carlos L. Burgos
Michael Galve
Michael Galve
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
