go into analogue tv press menu move down to settings you should be able to enter plug and play in menu press ok( if you can not enter it you are not in analogue )
if not solve problem try this !! warning !!
you will enter the service menu DONT ENTER OR CHANGE ANY OTHER ITEMS THAT ARE DISPLAYED AS TV WILL NOT WORK IF YOU DO
With tv in standby press INFO / MENU / MUTE / STANDBY on remote
then use ONLY DOWN nav-key move to number 12 FACTORY RESET
press RIGHT nav-key will reset all tv settings to factory ones
PRESS STANDBY TO EXIT on remote
you will have to RETUNE after tv after
my tv shows 480 i all of a sudden and i cannot find where to set it to 1080, i've changed view mode...
(More)
my tv shows 480 i all of a sudden and i cannot find where to set it to 1080, i've changed view mode to s stretch, zoom, stretch and the display still shows 480
i have a samsung ln46b530 tv and i also have a 4240hd receiver from scientific atlanta. i keep...
(More)
I HAVE A SAMSUNG LN46B530 TV AND I ALSO HAVE A 4240HD RECEIVER FROM SCIENTIFIC ATLANTA. I KEEP GETTING FLASHING CHANNELS ON HD. I AM USING AN HDMI CABLE TO CONNECT THE EWO.
I had the TV for less than 5 hours and it died on me. Horrible horrible horrible. It won't power...
(More)
I had the TV for less than 5 hours and it died on me. Horrible horrible horrible. It won't power up. and yes i already checked the outlet and made sure that the power cord is plugged into the tv.
screw bolts provided in kit too little for opening in back of television which the wall brackets...
(More)
screw bolts provided in kit too little for opening in back of television which the wall brackets have to be screwed into - where can I find what size screws - is there an on line manual - have been to three home improvement/hardware stores - no one has that size
